Question about RCA D52W19 52" Rear Projection Television
HD52W66 t.v . will not start...plug in tv, push power, light comes on, then goes out have done a visual check no blown caps.
  • renrab Oct 29, 2007
    model # is correct HD52W66
    Problem Solver:
  • 13 Answers
The Model # is wrong it Must be HD52W67 0r HD56W66. Set is going to shut down, unfortunately the trouble to me in many different areas you need to call an authorized RCA repair shop and have the unit trouble shot.
Posted on Oct 29, 2007
When I push the power button on the tv I hear a click and then another click but the tv won;t turn on. The white led on the front comes on momentarily the goes out. I have replaced the power suppy boa
sounds like a capacitor sometimes they look fine but don;t work. I had this problem in my lg replaced 3 caps and it fired up. caps are cheap.
Jan 23, 2015 | Televison & Video
Philips 42pfl7762d 12
It's not the fuse. Fuses have two states: sound and blown. If it was blown you wouldn't get any power. More likely a capacitor is swollen or leaking on your power board inside your TV.
Unplug your TV, lay it flat (carefully as it's a big mother - maybe have someone help you) on its front on a clear stable surface. Remove the back and visually check all the caps on the power board (follow the wire from the plug to find the power board). You're looking for signs of swelling - the tops of caps should be flat not rounded. If you find some, and you know how to solder, replace the swollen caps with the ones that have the same 'uf' number and the same or higher 'v'. If you don't know how to solder nor know a man who can, replace the entire PSU. Find the part number and search for it on eBay or on a tv parts site.
If you don't find any signs of faults with the board, it could also be a main AV board issue - that is the one with the video inputs but knowing whether it is the PSU or the AV board is impossible without a multimeter and the knowledge of how to use it. Replacing both would fix your problem but would cost about the same as calling out a TV repair man.
Jun 18, 2013 | Televison & Video
My television wont come on
On old projection TV's that wont turn on could be a bunch of things.
So if you plug your tv in and you not only hear nothing but also see nothing aka flashing light or anything of that sort. You might want to look at your power supply board. This is high voltage and i mean it, unplug your TV for about 3 days before looking into the back. The power supply board is the one that the power cord goes too from the wall. I would look for any visual damage such as blown capacitors or fuses. If your not familiar with electronics, capacitors are the cylinder looking things that stick out of the board with silver caps. If those caps are bend upward at all, they are bad. Here is an example of bad capacitors.jkoop144_0.jpg
If you are getting signs of life from it I could be something else. If you give some more info i will glaldly tell you where to go from there
Sep 08, 2011 | RCA R52WM24 52" HDTV Projection Television
I have a magnavox 42"
Problem could be in the Main unit Board, check out www
May 31, 2011 | Philips Magnavox 42MF521D/37 Television
Green light comes on for a few seconds then turns orange
If you have a popped cap then the mosfets are blown. They blow as soon as the cap shorts and pops. You need to replace both mosfets and the 220uf caps and test the fuse with a multimeter I would bet its blown too.
Corporate Computer
Dec 17, 2009 | Acer AL1916W 19" LCD Monitor
Power comes on but no pitcure then the power goes off
hori output Transistor maybe shorted you have no high voltage,so your Tubes are not lighting.
Dec 15, 2009 | RCA HD52W66 Projection Television
My polaroid TV will turn on but there is no picture or sound
blown caps in the power supply a 470m at 16 volt cap it will be puffed up
Sep 18, 2009 | Polaroid FLM-323B Television
My 42" LCD HDTV LNS40ID won't turn on PISSED!!!!!
I had the same problem. I work for a mother board manufacturer w/offices in New Jersey and brought mine into our engineering lab after Samsung told me tough luck. Anyway, one of my engineers fixed it in 10 minutes. Essentially, he replaced the 1000uF capacitors on the power supply board with 2 cent capacitors instead of the 1 cent capacitors that had blown out on the CHEAP SAMSUNG POWER SUPPLY BOARD. You can tell the caps are blown via visual inspection. The top of the cap should be perfectly flat and a blown cap will be convex on top. Unfortunately, there are also 2500 uF caps by the same cheap manufacturer on the board as well and we don't stock that value for our products. According to my engineer, those will most likely blow next since he replaced the others with better caps, but I'm getting samples of those and will replace them shortly. After that this piece of junk should last me at least another 2 yrs! It's been working for about 3 weeks now w/no problems. Hope this helps.
Dec 13, 2008 | Samsung LN-S4051D 40 in. LCD Television
TV will not turn on when power button is pushed.
check the main fuse in the tv. test it with a multimeter, not visually. if its the thermistor that blew the fuse, it is very difficult to see the break in the wire. replace if blown. if unit blown fuse again withing a couple of weeks replace the thermistor in the degausing circuit. good luck.
Jan 09, 2007 | RCA F36665 36" TV
RCA D52W19 52" Rear Projection Television Logo
174 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
