Question about Whirlpool Refrigerators
I replaced the water inlet and still nothing. the vavle is on and the connection was made on the new valve. the fridge is a whirlpool performa pbf1951kew
  • 1073 Answers
SOURCE: how to replace water inlet
get a plastic barb connector at lowes, or eq. inside the fridge side connect the end of the old tubing to the new tubing with the barb connector and pull the old line out from the back of the ref untill the new line comes out the rear of the machine to the water valve and reconnect tubing inside fridge
Posted on May 09, 2008
aborcass
  • 2651 Answers
SOURCE: Reconnecting/routing water lines after replacing inlet valve
different sized lines(should be anyway, but from the valve ,to the filter housing, then into refrig compartment(sits in a resivoir tank) then back out to the front of the freezer door hinge
Posted on Jan 12, 2009
  • 351 Answers
SOURCE: problems after replacinf waer inlet valve...
yea that is common just switch the wires and then try to get water out the door.. no biggie you wont hurt nothing... the water just wont come out the same place...
Posted on Apr 30, 2009
  • 56 Answers
SOURCE: ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
Posted on May 30, 2009
  • 1891 Answers
SOURCE: I have a jenn air fridge/freezer. The freezer is
if some water did come in after changing valve and you can hear the valves turn on and ice maker cycling / then the only thing left is water supply . now even though the water did come in for a short time . doesn't mean the supply is ok . so turn off water get a large bucket and remove the water line and open the valve . this will let you know if more than a couple of cups will come out . if the valve is bad the water will solw and soon the water willls stop .. ( the valve is the house supply not the frig units .. hope this helps . also if plastic ck for kink's in line or frig roling over line and pinching it . mm
Posted on Oct 26, 2010
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
Water And ice maker is not getting water. Have
there could be frozen water in the line.disconnect the water line coupler at the bottom of the door just inside the kick panel.once you disconnect this line try and dispense water if water does come out then you know where the blockage is if no water comes out make sure the water is turned on.last thing you may need to replace the fill valve i have had some new fill vavles be bad.good luck with you fridge i hope this helps.i would like to here how things turn out.
Jan 21, 2010 | Frigidaire FRS23R4C Side by Side...
My whirlpool american fridge freezers water dispenser is continually dripping what can I do to resolve this problem
Replace the water inlet valve , the piece that the wall water line connects to on the refrig .. Something like a grain of sand , piece of dirt etc , is caught in the rubber bellows , not letting the valve close completely . This will cause a scratch , which will collect anything else that comes thru , so cleaning it out will not work . ( it won't remove the scratch ) .
Sep 06, 2009 | Whirlpool Freezers
My Whirlpool washer won't go into the rinse cycle. The water inlet screens are clean and I replaced the timer but obviously wasn't the fix as I still have the problem.
Hi, When the water is suppose to be filling, Can you hear the inlet valve humming? You might need to remove the inlet vavle and check voltage to it. When the water is to be filling, you should get 120V to the valve. Please let me know if this helps or if I can assist you further.
Vic
Jul 15, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool fridge/freezer
probally need to replace inlet vavle. first check to see if valve powers up when you hit lever to recieve water. you can hear valve humm if not then replace micro switch above the lever inside dispenser housing
Jun 07, 2009 | Amana ARS2464B Side by Side Refrigerator
My whirlpool fills with water after the machine is turned off. How can I fix it?
sounds as if you have a bad inlet water vavle, it doenst complety shut off after use, and waer will trickle in( adding up to quite a bit in a day) youll need to replace the water inlet valve(directly behind themachine where the hoses hook into). in the meantime turn off water inbetween uses
Mar 17, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Water continuously running to fridge, overflowing?
Hi, if the only way you could stop the water was to turn it off at the water source, you need to change the water inlet valve. Make sure you check the water fill line for any leaks before you change the valve.
If I canassist you in getting the vavle, please let me know.
Thanks
Vic
Feb 18, 2009 | Whirlpool ET0WSRXML Top Freezer...
Water doesnt stop
defective inlet vavle or ( FILL VAVLE ) replace..onthejob
Feb 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WHIRLPOOL FRIDGE S/S MODEL #ED2FHGXKQ00
Hi Yamanayeemi,
"Dont forget to rate my solution to your STOVE!"- Fixya or helpful?
Before attempting any testing or repairs. unplug your fridge.safety first.! avoiding an electrical shock hazard.
It might likely be your water inlet valve that is bad , corroded or clogged.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink).
Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires.
The wires are connected to the terminals with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors.
Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting).
Place a probe on each terminal.
The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Does my suggestions help to solve your problem?
Aug 01, 2008 | Kitchen Ranges
Refrigerators Logo
13 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
