Question about Fujitsu fi-4120C Path-Through Scanner
After scanning for a few hours i get error code: DS41003
After scanning for several hours I get error code DS41003 and I have to restart my pc to be able to continue scanning
My 2000 F150 V8 fails to restart after a sustained trip at 70-75 miles an hour. After several hours of cooling down it will restart. Have flushed cooling system and replaced fuel filter.
Well the first things you need to check are when it will not start check the fuel pressure at the fuel pressure test port on the fuel supply rail to the injectors, after doing that hook up a scan tool and read the fault codes if any exist in the PCM memory.
Jun 26, 2017 | Cars & Trucks
0xc000185 error
How to fix The Specific Code Is 0xc0000185 errors? There are several methods of fixing The Specific Code Is 0xc0000185 errors. You may need to try more than one method before you're successful.
Download the (The Specific Error Code Is 0xc0000185) repair tool. avg-linkscanner-verisign-safe.jpg Install the program and click on the Scan button. Fix any errors it finds once the scan is complete. Restart your computer.
• Manually edit your Windows registry. Start the registry dditor by clicking the Start button, typing regedit in the Search box, and pressing Enter. Open the HKEY_LOCAL_MACHINE folder ==> "Software" folder ==> "Microsoft" folder==> "Windows" folder ==> "Currentversion" folder. Click on the Run folder ==> Click on the The Specific Error Code Is 0xc0000185 file. Delete the file by pressing Delete The Specific Error Code Is 0xc0000185 key. You can then reinstall the file on your PC
• Update the drivers for the device. It's possible that installing the latest drivers for the device could correct the error. If this works, it means that the existing drivers you reinstalled in the step above may well have been damaged.
• You can also download the Windows The Specific Error Code Is 0xc0000185 recovery utility which has proven successful at fixing this error..
Feb 17, 2014 | Samsung Computers & Internet
Canon 8400F will not scan, error code 5, 155, 45
If it passes 'test' from the computer, then it should be listed in the Device Manager. Uninstall / Remove that device, then Restart and Re-install it.
Tallon41
Aug 22, 2012 | Canon CanoScan 8400F Film Scanner
Twain error ds41003
it may be d driver of the scanner is missing or u didnt install ot properly or the usb cable is not working well
Apr 09, 2012 | Office Equipment & Supplies
Today I tried restore my computer to a previous state using HP recovery manager. After the restoring process ended a sign appeared saying that the restoring couldn't take place due to some 0xc000022 error....
before restoring the computer run a through scan on the harddisk all the drives in the hard disk should be throughly scanned the error you reciving is due to the hard disk problem first scan the hard disk in windows then restart your computer press f8 and click safemode command mode you will see files running wit for few minutes till the comand prompt comes in the camand prompt type chkdsk /all after the scaning is type exit then restart the computer and try restoreing
Jan 29, 2011 | HEWLETT-PACKARD HP Pavilion DV7-4190US
Laptop keeps restarting
  1. See if you can start in Safe Mode (hit F8 before Windows loads - best way is to keep tapping F8 after you power it on. You should get a menu with "start in Safe Mode" as an option.
  2. Once booted in safe mode go to Control Panel, System, Advanced, ;Startup and recovery'.
  3. Click the Settings button and remove the tick from the "Automatically Restart" box.
  4. Click all the OK's to get back to Control Panel.
  5. Reboot as normal and the system should display an error code. Post that error code here and we can have a look at it.
Sep 07, 2009 | Compaq Presario 5000 PC Desktop
Error message: Physical memory dump
The error code is pretty general and could indicate a few problems. You can try the solutions posted here: http://www.updatexp.com/0xC0000005.html .
Mar 21, 2009 | Acer Extensa 4620 Notebook
Dell inspiron 1720 reboots randomly
there are several reasons why a pc restarts: 1. there might be a virus that causes this, thry to scan your computer using the updated anti virus. 2. your power supply might be faulty, if your pc frequently restarts the 12volts supply is having a problem, you need to replace the power supply. 3. operating system error, you need to repair your OS. what i have suspected from the problem you relayed is that your power supply, you need to replace this.
Apr 29, 2008 | Computers & Internet
ACER 620 P SCANNER
I Want Mercury Scanner 620P windows xp Driver
Aug 16, 2007 | AcerScan 620PT Flatbed Scanner
Fujitsu fi-4120C Path-Through Scanner Logo
48 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
