Question about Buffalo Technology Computers & Internet
Buffalo hd pv320u2 hard drive
Making sound not working
  • 956 Answers
SOURCE: buffalo hard drive
Have you downloaded another prog recently, about the time you lost the HDD?
Have you pulled the usb restart poota, wait till fully setup, reinstall usb, it just might plug and play.
If not, you will have too re-install from install/setup disc.
Posted on Nov 13, 2009
SOURCE: Can't access Buffalo HD-HB250U2-WR 250gb Ext. Hard
I think I have the answer, plug your cable in. If windows 7 shows the message unknown device don't remove the usb. instead turn the switch on the back of the external hard drive off for a few seconds then back on. Windows 7 should then for some unknown reason find the correct drivers and your buffalo hard drive will now work. This worked on mine.
Cliff
hotdesignerwear.com
Posted on Jul 26, 2010
  • 10406 Answers
SOURCE: Everything worked fine until yesterday
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
Testimonial: "THanks - I'll give it a go!"
SOURCE: My Buffalo HD-PX320U2 External Hard
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Posted on Dec 11, 2010
  • 130 Answers
SOURCE: my buffalo external hard disk
it is a PNP (PlugNplay) device. Try using a different cable to connect to your pc. Should the problem remain, hook it up to a different computer and if it doesn't see the drive, it will be an electronic circuit failure inside the box. The data is still on the hhd but you will have to obtain a new circuit to bring the hhd back online for use.
Posted on Apr 13, 2011
How to access my Buffalo HD-PNTU3 external hard drive?
dropping it while turned on is fatal as it usually damages the write heads and/or the platters.
if it hit the floor, changes are it's physically damaged the mechanism.
recovering data from a drive with this damage is not cheap as you will have to send it away to be rebuilt. It's impossible to rebuild it yourself.
Feb 21, 2016 | Buffalo Technology Buffalo MiniStation...
My buffalo hd pntu3 hard disk is encrypted using the default software from drivenavigator , securelock easy manager. how to remove the encryption?
In the software Secure Lock Manager Easy is a tab "Setting the Encryption mode" Pressing "Releasing encryption mode" will remove the encryption. Make a backup of the data before please.
Nov 03, 2013 | Buffalo Technology Buffalo MiniStation...
HD-PE500U3/BK-EU does not work
Compatible
Windows 7 (32/64 bit), Vista (32/64 bit), XP (32 bit), Mac OS X 10.4 or later (*2)
You could download and use TrueCrypt. It's free and has very strong encryption. http://www.truecrypt.org/
Jan 01, 2013 | Buffalo Technology Buffalo MiniStation...
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
Popular issues: problem with Buffalo Technology (HD-CE500IU2) 500 GB USB 2.0 Hard Drive My laptop is no longer recognizing the Buffalo External Hard Drive. When I plug in the USB to my laptop,
HI guys, I found a solution to a similar problem with the buffalo portable HDD that I brought from my friend. I just changed the HDD cable with the cable from Western Digital My Passport HDD and all problems were sorted out. Physically the WD cable is bit thicker than the Buffalo HDD cable. So suspect the cable is the problem. Please check if this is the problem with your Buffalo HDD before formatting. All the best
Indrajit Pande
Dec 27, 2011 | Computers & Internet
My external hard drive (buffalo HD-PE320U2) is not working. when I plug it on the computer it says "windows does not recognize it" or it has malfunction. what will I do with it?please help I...
First uninstall the software,make sure the external hard drive is not connected to the PC and use your install disk to reinstall the software.You might all so try system restore.Thank you for choosing FixYa.com.
May 18, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
I got a Buffalo HD-PET500U2 external hard drive two months ago..I've a lot of files on it and I've used it yesterday. I didn't drop it or anything but today when I tried it in it would start making these...
schonie:
From reading on the Buffalo web forum just now, you need to try using a different USB cable. If that doesn't work, try using the device on a different computer. If it continues to not work, then the device has failed in some way.
Contact Buffalo as soon as possible to request an RMA to replace the drive (http://www.buffalotech.com/contact/). Information on Buffalo warranties are available here: (http://www.buffalotech.com/support/warranty/)
If you have data on the drive that you absolutely have to have, then you may want to consider sending the drive to a data recovery service like DriveSavers. There are many drive recovery companies available. I not DriveSavers as an example and because I have experience with them.
http://www.drivesaversdatarecovery.com/
Thanks for using FixYa.
Feb 13, 2011 | BuffaloShop Buffalo Technology MiniStation...
Will Buffalo Model HD-PE250U2 work with Windows 7 OS? Regards sandra
Yes, it is a "plug-and-play" device, and Windows XP/Vista/7 support "plug-and-play" devices.
Dec 31, 2010 | Buffalo Technology (HD-PE250U2/BK) 250 GB...
This might be problem with the cable. Try using another cable.
Sep 02, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
My PC frozen when I connect Buffalo Technology 250 GB HD
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Jul 08, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Computers & Internet Logo
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
