Question about Epson WorkForce 635 AllInOne InkJet Printer
Macintosh hd user template microsoft prints every time
Extra page printed with microsoft template warning
SOURCE: Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
Posted on Sep 24, 2008
Niraj Limbu
  • 183 Answers
SOURCE: Printing in page mode feeds extra blanc labels
Make sure,
you firmware is right one for that printer because in most of cases it happens due to wrong firmware and bad ADF kits. so check your ADF kids and if you find them fine the install updated firmware on in.
once you done with these all then turn your printer off and turn it back on.
post back if any thing changes and rate all answers.
Good luck
Posted on Feb 24, 2009
SOURCE: color test strip is printing each time before a legitimate print is printed
Press the Menu button and scroll to Printer Setup and scroll to Auto Cleaning and turn *Off.
Posted on May 15, 2009
kev1952
  • 26 Answers
SOURCE: Page size for CD printing
I use Surething to print my labels (I have a Canon IP4300) as it allows you to create your own custom templates. With the Canons the CD trays are different depending on model and I would not be surprised if the Epsons are the same. To create a template (in any software) you need an accurate ruler to get the exact measurements of the tray. Once you have them then it's simply a matter of setting your "page setup" to accommodate those measurements. You will need to specify page size, left, right and top margins. Top and left margins give the printer the start point and right margin gives width of print.
Using a graphics program to print CD labels is clumsy at the best of times and the task is a lot easier if you use a dedicated label print program. PrintCD is okay but Surething is the best! Download the trial version of Surething and then get the Canon templates (my creations) from my website here. Once you load them have a look at the page setup to see how to create your own (for your Epson).
Kev (http://www.kevsplace.com)
Posted on Sep 14, 2009
eric1121
  • 265 Answers
SOURCE: Maintenance warning/technical issue message stops printing
You just need to reset your printer. Google search a resetter program for your printer model.
Posted on Jan 14, 2010
Turn off hp officejet 4500 last printing report
You can turn that off within preferences.
Jun 11, 2017 | HP Computers & Internet
Word 2010 doc will not print. Will print with Wordpad.
Microsoft support describes several things to try. After checking to see if any new blank document you create could print or not, the next possibility is to rename the normal.dotm file that may be necessary to resolve this problem.
Procedure to check:
"Microsoft Windows 7
  1. Quit Word.
  2. Click the Start button.
  3. In the Search Programs and Files box, type Normal.dot or Normal.dotm depending on your version of Word.
  4. For each occurrence of the Normal.dot or Normal.dotm template that you find, rename it Normal.old. To do this, follow these steps:
    1. Click Normal.
    2. On the File menu, click Rename.
    3. Type Normal.old, and then press ENTER.
You can now print new documents that are created from the new global (blank document) template (Normal.dot). However, existing documents that were created by means of your old Normal.dot file may not print. If this is the case, go to the "Print the problem document" section to resolve problems with these documents.
If you cannot print this new document, there may be a problem that prevents Word from printing. If this is the case, go to the "Print the problem document" section.
Determine if the problem documents were created from the same custom template You may still not be able to print particular Word documents. Examine the problem documents to determine if they were created from the same custom template. To determine which template created the problem document, follow these steps:
Word 2010
  1. Open a document that you cannot print.
  2. On the Developer tab, click Document Template in the Templates section.
  3. On the Templates tab, look in the Document template box."
Jan 12, 2018 | HP Office Equipment & Supplies
Whenever I print from there is an extra page that prints after that includes: Filename: Directory: Template: Title: Author: Keywords: Comments: Creation Date: Change Number: Last Saved on: Last...
when you go to "print" a box should open asking if you want to print "all" or "pages" . click on "page" and then click "1" then you wont get the trailing page.
Feb 21, 2011 | HP LaserJet 4200n Printer
I have a Kodak ESP 5200 series printer. When I try to print Avery 8160 address labels the sheet comes out not printed.
Hi
You can try and download the label again from below link--
Avery 8160 label download
Click the "Download Template" button. Enter your info and click "Submit". Follow the prompts to download the file. After you download your Avery template, be sure to remember where you saved the file on your computer and the file name. Open Microsoft® Word or an Adobe® program for your template and select File > Open to navigate to the drive and folder to open your template. Use the program's formatting and printing features to edit and save your template. For Microsoft® Word users - If the template looks like a blank page, select Table > Show Gridlines to view the template layout.
Hope this helps... Please post back if you need more information.
Daniel
Dec 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I tried moving my word application to my desktop and now when I go to open it a error comes up that says that there was a problem opening word and it tells me to reinstall the program. I put in my office...
That's actually a normal problem. You don't need to reinstall Office Mac 2008. What you need to do is to put the the Microsoft Word icon from your Desktop back to Applications Folder. To create a shortcut on your Desktop, go to Applications folder, Right Click(Ctrl+Click) on Microsoft Word then choose Make Alias. Just drag the Microsoft Word Alias to your Desktop. From Desktop you will have Word as a shorcut icon without any problem. If the issue will not be resolved then you need to uninstall then reinstall Office. Here's the steps:
] > Macintosh HD\Applications
* Remove Microsoft Office 2008
] > Macintosh HD\Users\<username>\Library\Application Support\Microsoft
* remove folder called Microsoft
] > Macintosh HD\Users\<username>\Library\Caches
* remove all Microsoft related files
* remove Microsoft Folder
] > Macintosh HD\Users\<username>\Library\Preferences
* remove all the (com.microsoft.[....].plist files)
* remove Microsoft folder
] > Macintosh HD\Library\Receipts\Remove all Office 2008.pkg files
] > Delete Microsoft Office shortcuts from Dock
] > Restart
] > Install Office 2008
> Manual Install Updates
I hope this Helps! :)
Nov 25, 2010 | Microsoft Office 2008 for Mac: Mac
When I start any 2008 office programs they crash right away bad_exc_error I removed and installed a new program and it still does the same thing. Been doing it for about six months, I just bought the new...
If you have the installation disc,
Try this following steps:
Go to the following locations:
] > Machintosh HD\Applications
] > Finder\Macintosh HD\Library\Caches
* remove all cache files
] > Finder\Macintosh HD\Users\\Library\Caches
] > Macintosh HD\Users\\Library\Application Support\Microsoft
] > Macintosh HD\Users\\Library\Caches
] > Macintosh HD\Users\\Library\Preferences
] > Restart , empty your trash bin
Sep 12, 2010 | Microsoft Office 2008 for Mac: Mac
I have a HP PSC 1610xi All in One printer. I
you know what to do is dis, check your key board wether it has be press dawn or the upu had been shake when you are taken it home
Oct 16, 2009 | Office Equipment & Supplies
My HP printer is printing out an extra page with each print job. The extra page contains information...almost like a status report...it contains information such as filename, directory, template, title...
You need to check the mode your printer is printing in. It may be in diagnostic mode. Another reason for having an extra page with info. is the page isn't setup to print all info on one page. Run your setup allignments and testing options to get it all on one page. Hope this helps. -Jennifer
Jul 09, 2009 | Office Equipment & Supplies
Prints Extra Page
If you use Open Office instead or Microsoft Office, you may find that fixes the error.
Sep 16, 2017 | Canon Office Equipment & Supplies
Prints an extra sheet with specs on font, characters ....
click the printer button (shown above) and in the menu there will be an option to print banner page.
please turn this off
that should fix your problem.
May 08, 2008 | Copystar CS-2030 Copier
Epson WorkForce 635 AllInOne InkJet Printer Logo
14 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
