Question about Gateway 4026GZ Notebook
Gateway 4026gz doc in ethernet port board
Installation instruction for above board
    Master:
  • Gateway Master
  • 788 Answers
It is in here:
Posted on Mar 01, 2014
I need to replace the battery for my gateway laptop model 4026gz. I already have the replacement battery. Can you show me directions how to open the notebook and insert it.
Hi apaner...
Flip your notebook upside down...look for a slidling toggle maybe even two.
Push the toggles out to release the battery, reverse procedure to install the new battery.
Please take time to rate me
Aug 28, 2011 | Gateway 4026GZ Notebook
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely 192.168.0.1)
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Cannot connect to web.
Follow this steps
1. Connect the provided power adapter from the gateway's POWER port to an electrical outlet. The POWER light on the front of the gateway should be green. 2. Connect the provided gray phone cable from the gateway's PHONE LINE port to the DSL filter jack labeled DSL/HPNA. 3. Connect the yellow Ethernet cable provided with the gateway from the LOCAL ETHERNET port on the gateway to your computer's Ethernet port
With your computer completely started, verify the POWER and ETHERNET indicator lights on the front of the 2Wire gateway are green. If they are not, see "Understanding the Indicator Lights" on page 15. The INTERNET indicator light will not turn green until the gateway software has been installed and an Internet connection has been established.
Mar 22, 2011 | 2wire Computers & Internet
Gateway 4026GZ Notebook is over heating the fan seems to work but might only be working itermitttenly
Hi there, it could this simple solution!....check all the air vents in/on/around the laptop...make sure thse are all dust and debris free!...My dell hasd 2 little vents, one on eachside of the keyboard and then a large vent area underneath the laptop itself...
This could not be your problem, but a good chance of it !
If this helped you (or not) then please rate3!..Thank you!...
Apr 16, 2010 | Gateway 4026GZ Notebook
I installed two 512 MB DDR1 333MHz PC2700 memory modules in my Gateway 4026GZ laptop. They all cause the laptop to freeze up with the screen not working. Tried different memory modules (same 512MB)
Hi
Thank you for your query
According to the spec of the laptop that should be ok, it may the memory modules are bad
Please try the following
1) Try putting just the one module in, in turn, if it starts to freeze with the one or the other you will know which one is faulty
If this has been useful please leave positive feedback/vote/testimonial - Thank you again
Feb 15, 2010 | Gateway 4026GZ Notebook
System can't read hard drive nor the CD Rom drive can't read CDs. Can this be a bad system board problem?
First you cheack the HDD and CD connections. after reapeet the sam problem then decide the bad sysem board problem.
Nov 21, 2009 | Gateway 4026GZ Notebook
Ethernet port on laptob gateway not working
http://support.gateway.com/support/drivers/search.asp?param=MX6447&st=kw
From a computer that has internet access, download the appropriate ethernet driver for your network card from the link above. As for the recovery disk, you'll have to contact Gateway for a replacement disk.
Apr 14, 2009 | Gateway MT3705 Notebook
Keyboard
You first have to remove the bezel that is between the keyboard and screen. Sometimes this is held on by a couple of screws on the bottom of the laptop. Once you get that thing off, there will be 3 or 4 little screws just above the F keys that hold the keyboard in place. Remove them, and slide the keyboard towards the screen until it is free. Be careful not to damage the ribbon cable attached to the mb.
Mar 12, 2009 | Gateway 4026GZ Notebook
Ethernet driver for gateway 830gm
Insert computer serial number here to download the drivers.
Alternatively click driver download here: Gateway Support - 4659 Gateway 830GM
Click on the drivers, download them , then install them one by one.
Follow instructions from setup program.
Mar 04, 2009 | Gateway 830GM PC Desktop
Cpu
use unknwon device identify or google "free system information utilities" download one and see what comes up.
Dec 12, 2007 | Gateway 4026GZ Notebook
Gateway 4026GZ Notebook Logo
41 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
