Question about Dell Computers & Internet
Battery change on Dell latitude c6400.14inchlaptop
No charge. Holding 2 or 3 mins at most
  • Ken Lewis
    Ken Lewis Feb 12, 2014
    i just need to change the battery
  • 56 Answers
I think the Laptop you have is E6400,
Steps to Remove the Battery.
They are 3 Release Latches to remove the Battery.
1) Make Sure all cables including Power cord is unplugged.
2) Please look at the image attached.battery change on Dell latitude c6400.14inchlaptop - 1a2dca20-03d2-447a-9f36-95e42448fc94.jpg
3) Turn the Computer Upside Down.
4) I have numbered the Latches.
Latch# 1 - Slide the battery door release latch# 1 into the unlocked position and Slide the battery door release latch# 1 toward the base of the system.
5) Latch# 2 and 3 - Slide the battery release latches into the unlocked possition.
6) Open the battery door on Latch# 1
7) Using the battery pull tab slide the battery out of the system.
Let me know if you need any other help.
Thanks
Posted on Feb 21, 2014
Testimonial: "Brilliant. Thank you for your help. Battery now changed."
4 Suggested Answers
SOURCE: Dell Latitude D510 will not charge battery
HI, check soldering on Fuse 1 right next to the power inlet plug, just fixed mine.
you will have to dissassemble it completly to get acces to it
Posted on Feb 13, 2009
  • 3940 Answers
SOURCE: My Dell Latitude D610 Battery Stopped Working
The battery light flashing RED/AMber is an indication of a failed battery.
Portable batteries have a life expectancy of 300 to 500 recharge/discharge cycles. (roughly 18 months under normal use) After that, the charge life starts to drop off and eventually it will not hold a charge. Because of this, the battery is considered a consumable item and is only warranted for one year from the manufacturer.
Since all the systems listed in the post are D610's (4 to 5 years old) it is not surprising that the batteries are failing.
Dropped Puck, if you replace the battery and a new battery doesn't charge/run the system, then the charging circuit on the MB is failed.
Posted on Apr 14, 2009
romsky79
  • 822 Answers
SOURCE: Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
Posted on May 29, 2009
I have a Dell E6400. I know, ancient! Is it normal that it gets slower when charging? Like when it's using battery power, it's noticeably faster, but when I plug the charger in it just gets slower..
1.Install the system again. If it works, over!
2.remove the battery, and turn on your notebook with charger. If it works, there may be
something wrong with your battery. You can change a new battery.
3.Install the battery,and plug the charger, power your notebook. Open the Power
management, change the Power plan to High performance.
4400mAh 6 cells Dell Latitude E6400 XFR Battery Replacement Notebook... 90W Dell Latitude E6400 Charger Power Cord Replacement AC Adapter Latitude...
Jan 12, 2017 | Dell Computers & Internet
Mine is dell latitude d620 laptop.battery is new.problem is it was running both on ac and battery.suddenly battrey is not taking the charge but my laptop runs on ac power. can i remove the battery and run...
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Sep 27, 2010 | Dell Latitude D600 Notebook
We have a Dell latitude d600 and the old battery had gone bad some time ago, would charge, but lasted maybe 10 minutes. We bought a new OEM Dell battery for it, and put it on charge all night. The charge...
Sounds like you should try a regular Dell factory refurbished battery. Or if not that, try a battery that you knows works for sure. Then try charging it up, if it doesn't charge up then you know its a situation with the motherboard.
Dec 29, 2009 | Dell Latitude D600 Notebook
I have a dell D510 latitude. AC power OK - doesn't charge battery
The battery of the dell D510 latitude is completely bad and need to be replaced. i suggest you get another one and avoid the battery running completely down before charging it.
Compliments and I wish you best of luck
Dec 24, 2009 | Dell Latitude D510 Notebook
Should a Dell Latitude D600 work properly with the AC adaptor only????--that is, with the battery removed?????
No, this is an indication of either of this two things:
1. Either your baatery is bad and needs replacement, or
2. The charging point of your laptop is faulty.
I would suggest that you test your laptop with a good, working battery first, if it works with it, then change your battery, but if it doesnt, get a technician to fix the charging point of your laptop for you.
Hope this helps.
Goodluck.
Oct 05, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 will not turn on / power on
it means not charging the battery pack, did you check the dc jack connector, or the.
charger check it if working properly, if the same problem open the laptop then check the baord
thanks
Jul 12, 2009 | Dell Latitude D600 Notebook
Battery charging
if it is the original battery, then the answer is buy a new battery. The average life of a portable battery is 300 to 500 discharge/recharge cycles. (1 to 2 years normally) If it is the original battery, then it is going on 5 years old and due for replacement
Mar 25, 2009 | Dell Latitude D610 Laptop Computer -...
Battery
The flashing light is telling you that your battery is not holding a charge. The fact that it goes dead when you unplug it tells me that the power adapter is working properly and the battery is the suspect. If your computer is under warranty, contact Dell for a replacement battery. If not, you'll need to purchase a new battery.
Hope this helps.
Mar 10, 2009 | Dell Latitude D620 Notebook
Power & Battery in a Dell Latitude C640
If the laptop does not run plugged into AC power, then you may have a defective power brick or a power problem with the laptop.
I would try another power brick. If that doesnt do it then your power jack inside the machine may be damaged and usually that means the motherboard is cracked. The only fix in that case is a new motherboard ($150-$200 plus labor) OR you can get the Dell C PORT II port replicator which has its own power jack.
Hope this helps!
Dec 28, 2007 | Dell Latitude C640 Notebook
Computers & Internet Logo
66 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
