Question about Sony Bravia KDL-32ML130 32 in. LCD TV
SONY KDL-32ML130 has sound but no picture
Tv has sound but no picture, back light is working.No display whatsoever.
SOURCE: Sony TV KDL-32L4000 Turns Pink
My Sony tech says it's most likely a bad cable box. Try a DVD and if the DVD is fine then it's for sure your cable box. Needs to be replaced by the cable company.
Posted on Aug 10, 2009
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
SOURCE: Sony KDL-32S3000 32in LCD TV.
Hi Chris,
I used to have the same issues with my 32S3000 but I've managed to fix it by factory reset.
It's described in a different post here:
http://www.fixya.com/support/t2222933-complete_factory_reset_sony_bravia_kdl
Good luck.
Rob
Posted on Dec 18, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
  • 28 Answers
SOURCE: Sony Bravia with really bad ghosting
The little board on top attached to panel.
Posted on Jul 05, 2010
No picture, no sound display though back light lamps are ON.
Contact the authorized service center for Sony. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 16, 2015 | Sony Bravia V-Series KDL-52V4100 LCD TV
I have a Sony Bravia KDL-32ML130. I turn on the tv and the colors are really red and the pictures seems like it's moving in slow motion. It does this with the Direct tv, dvds, and vhs. The sound is...
LCD Panel (screen) is defective and need to be replaced to solve this problem.
Click YouTube.com to watch similar problem in lcd tv that brought to my repair shop.
Thanks.
May 30, 2011 | Sony Bravia KDL-32ML130 32 in. LCD TV
Distortion and horizontl lines
If same lines/ distortion appears in every input of tv then it is lcd panel (screen) problem as question shows it is Sony KDL-32ML130 lcd tv.
Can you please post picture of tv screen to show distortion/ lines to diagnose it correctly?
Thanks.
Nov 16, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Eveything works except the picture ,it turns on only it has a very dimmly lit screen a void of any picture please help aaaaah
You have a weak electronic component called a capacitor. You have to let a tech replace it for you. This will cause your LCD to suddenly loose brightness
Aug 23, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Jul 05, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Theres no picture on my sony bravia KDL-40S4100
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Apr 05, 2017 | Sony KDL-46XBR5 46 in. LCD HDTV
Try pressing the TV/Video button. The problem could be that the TV is set to an input with no source.
Feb 11, 2009 | Sony BRAVIA KDL52XBR2 Television
Not really that tough. Sounds as though the backlight is shutting down, either from a power supply failure, or a failure of the backlight circuit itself. You can verify this by holding a flashlight to the screen in the area where the menu usually appears to see if it displayed on the LCD panel with no backlight. If you can faintly see the menu displayed, your backlight has shut down and the most likely cause is the backlight inverter board, followed by the power supply and the backlights themselves which are part of the LCD panel. If you found this information answered your questions, please be sure to rate it. Thanks!
Oct 24, 2008 | Televison & Video
Sony Bravia KDL-32ML130 32 in. LCD TV Logo
44 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
