Question about Dell Latitude C640 Notebook
How to change battery on Dell latitude c6400.14inch laptop
No charge in battery 2min at most
  • 1 more comment
  • Ken Lewis
    Ken Lewis Feb 10, 2014
    Hi Ken Lewis, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Ken Lewis
    light flickers when adapter connected. goes out after a time. disconnect from mains. screen shows charge battery
  • Ken Lewis
    when charger connected charge light on . charger out screen shows charge battery
  • 56 Answers
I think the Laptop you have is E6400,
Steps to Remove the Battery.
They are 3 Release Latches to remove the Battery.
1) Make Sure all cables including Power cord is unplugged.
2) Please look at the image attached.
how to change battery on Dell latitude c6400.14inc - 1a2dca20-03d2-447a-9f36-95e42448fc94.jpg
3) Turn the Computer Upside Down.
4) I have numbered the Latches.
Latch# 1 - Slide the battery door release latch# 1 into the unlocked position and Slide the battery door release latch# 1 toward the base of the system.
5) Latch# 2 and 3 - Slide the battery release latches into the unlocked possition.
6) Open the battery door on Latch# 1
7) Using the battery pull tab slide the battery out of the system.
Let me know if you need any other help.
Thanks
Posted on Feb 21, 2014
  • 998 Answers
SOURCE: Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
billspeer
  • 180 Answers
SOURCE: override laptop automatic shutdown after inactivity
Easily done! Right click your desktop and choose Properties. Select the Screen Saver tab and at the bottom choose Power. In the Power Schemes drop down box choose Always On and the PC will never turn off. You might also want to disable or set the time higher for your screen saver.
Please rate this solution accordingly. Thanks for using Fixya.com.
Posted on Jan 10, 2009
SOURCE: Dell Latitude D510 will not charge battery
HI, check soldering on Fuse 1 right next to the power inlet plug, just fixed mine.
you will have to dissassemble it completly to get acces to it
Posted on Feb 13, 2009
SOURCE: dell latitude d600 blinking battery light
Sometimes a systemboard will cause this,
Posted on Mar 16, 2009
  • 3940 Answers
SOURCE: My Dell Latitude D610 Battery Stopped Working
The battery light flashing RED/AMber is an indication of a failed battery.
Portable batteries have a life expectancy of 300 to 500 recharge/discharge cycles. (roughly 18 months under normal use) After that, the charge life starts to drop off and eventually it will not hold a charge. Because of this, the battery is considered a consumable item and is only warranted for one year from the manufacturer.
Since all the systems listed in the post are D610's (4 to 5 years old) it is not surprising that the batteries are failing.
Dropped Puck, if you replace the battery and a new battery doesn't charge/run the system, then the charging circuit on the MB is failed.
Posted on Apr 14, 2009
Dell latitude D420 wont charge when plugged in
If the laptop works without the battery, just the charger, the charger is OK.
Jan 13, 2014 | Dell Latitude D420 (DELLD420) PC Notebook
Mine is dell latitude d620 laptop.battery is new.problem is it was running both on ac and battery.suddenly battrey is not taking the charge but my laptop runs on ac power. can i remove the battery and run...
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Sep 27, 2010 | Dell Latitude D600 Notebook
I have a dell D510 latitude. AC power OK - doesn't charge battery
The battery of the dell D510 latitude is completely bad and need to be replaced. i suggest you get another one and avoid the battery running completely down before charging it.
Compliments and I wish you best of luck
Dec 24, 2009 | Dell Latitude D510 Notebook
Dell latitude c600, battery not charging even charging sign is shown in windows (battery is ok and checked by another dell laptop) whats problem?
hi im josh in cebu phils.may i help you. friend try to check the small wire white near the batt.or check the connections if it is not shorted or disconnected. or try to replace new batt. good luck
Feb 22, 2009 | Dell C600 (002UH) Motherboard
Dell Latitude D 600 battery is not being charged
some problemwith ur motherboard circuit..so check up in service center...
Dec 01, 2008 | Dell Latitude D600 Notebook
Dell latitude D 610 battery dead
dell latitude batteries have a built-in battery life indicator on it. Press the button to see how much charge is left or if there's no charge at all. It sounds like your power adapter isn't charging
your battery. visit: http://accessories.us.dell.com/sna/batteryconfig.aspx?c=us&cs=19&l=en&manufact=694&s=dhs&stype=4&family=Latitude%20Laptops and choose the model of your latitude laptop.
u can get it cheaper on ebay or any 3rd party vendor. hope this helps.
Jun 16, 2008 | Dell Computers & Internet
Dell Latitude C640 Notebook Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
