Question about Nordic Track NordicTrack T9 ci Treadmill
Won't start All the lights on my Nordic track t9 treadmill work but the buttons don't work apart from incline 6 and 7. It's 3 years old. Please help
SOURCE: Buttons doesn't work...
you more than likely need a new keypad
www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
Gackmaster
  • 12 Answers
SOURCE: I have a Nordic Track EXP 1000X treadmill and the
Probably 85% of the time, it's the sensor.
1. remove the screws from the bottom of the enclosure case. 2 or 3 in the front and 1 on each side
lay it back down, and power it up, and actuate your incline. watch the end of the motor, to see if the shaft is moving. It probably IS turning but only a little bit. NOT enough. In this case I'd say it is the sensor.
2. Unplug the unit of course.
3. the incline motor is in the middle of the pack,..you'll see a black tube looking thing sticking up.
4. on the bottom side of this, you will see,..or feel for a black square sensor attached to bottom of the motor casing.
5. follow the wires and unplug this.
6. pry it off with a screw driver. Remove incline assembly, if you cannot reach it.
7. replace sensor and try it again.
if the MOTOR does NOT turn when using the incline buttons, the problem backs up to possibly a bad control board. or a bad motor on your incliner, however, i'd say that's the last thing to go.
Order of failure: 1. sensor 2. control board 3. motor.
good luck
Posted on Jan 26, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
  • 3 Answers
SOURCE: C2155 treadmill 1 1/2 yrs old, Nordic track. Panel
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Posted on Oct 31, 2010
  • 3 Answers
SOURCE: We have a Nordic Track NTL09007 C2500 that has
Got beeping? I JUST figured out how to fix it. Take the console apart and pull the connector from the back of the iFit card adapter. Plug back in, should be good as new!
Posted on Oct 29, 2011
Why wont my (floor model) nordictrack T9 Ci work? unplugged it and plugged it back in and it keeps going through the start up and then the buttons don't work.
Likely your incline switch is jammed or defective. Could also be that the panel circuit is defective and needs replacing. This panel circuit would need to be removed and tested to pinpoint the exact issue.
Oct 16, 2014 | Nordic Track Nordictrack T9 Ci Treadmill...
Lights up, start does not start on console, belt won't move , decline , incline does not work, age goes down but not up, speed does not work...pulse on handles work,,,
Do you have the iFit component on your treadmill? We had a similar issue and I unplugged the iFit component (requires opening the console and unplugging the ribbon cable that attaches the iFit component) and the treadmill started working again.
Jun 08, 2014 | Nordic Track NordicTrack Treadmill, A2550
Not incline or declining
I expect there is a limiter switch that tells the treadmill when it has reached its maximum elevation. The switch is probably either malfunctioning or broke.
Feb 27, 2014 | Nordic Track Exercise & Fitness
Speed not steady, and not reading on console. Incline not working or reading.
Proform Treadmill Incline Problem Fixed How to reset re calibrate your treadmill
Please see this video for to help you to fix it in incline and calibration incline motor
Blessing
cuadra2016@yandex.com
cell+whatsApp: +50588611441
Jan 21, 2018 | Nordic Track Exercise & Fitness
None of the touch buttons work. Fans, volume, speed, incline etc etc. The only two buttons that work are incline buttons 6 & 7. Power comes on and key turns on and off though. Can anyone advise??
sorry but i dont have a solution for you!! i bought the t9ci back in nov of 2008, like you none of the buttons worked had to wait till march of 09 for nordictrack to send me a reprogram card, which did not fix the problem. i then recieved a new console, in april 09, which stopped working in feb 10. a service tech came out and had no clue, so the sent another new console which did not work. in march 10 they sent a whole brand new treadmill, and when i got on it last week the console was not working once again!!!!!!!!!!!!! i hope you dont have as many problems as i did
Nov 05, 2011 | Nordic Track NordicTrack T9 ci Treadmill
How to activate my ifit
I will try to help you, the feature of software is the same. you can do it, activate your ifit. Nordic Track C2050 ACTIVATE IFIT -The Nordic Track C2050 is a treadmill that was targeted toward the budget-minded fitness enthusiast. It is a model of treadmill that is no longer being manufactured by the company. When it was still being manufactured, it developed a reputation for being an entry-level treadmill that featured a console that was easy to read because of its brightness. 1. Incline Change
o The Nordic Track C2050 allows users to change the incline of the treadmill with a simple touch of a button. This treadmill features both increase and decrease buttons for the incline. The incline of the machine will change by .5 percent every time the buttons are pressed. With each press on the incline buttons, the machine will take a moment to actually reach the incline setting that was just selected.
Capacity of Weight
o Users who are larger than or weigh more than the average person will be pleased with the added capacity of weight that the Nordic Track C2050 allows. Unlike most treadmills in its economy class that only allow a weight limit of 200 to 250 pounds, this model lets users who weigh as much as 300 pounds use the machine safely. Larger people can get the benefits of a cardiovascular workout on this treadmill without worrying about damaging it.
Heart Rate Measurement
o This Nordic Track model allows users to measure their heart rate. All the machine requires is for users to place their feet on its foot rails and grasp the metal contacts with their hands. The Nordic Track C2050 then works to determine your pulse, and the symbol of a heart will eventually show up in the display. After a couple of dashes show up, your heart rate will be displayed. Users who want to be certain of getting an accurate reading should ensure their hands are clean when gripping the metal contacts.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 22, 2011 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track exp 2000I. Consol lights, buttons do not work.
If the console lights up but the buttons don't work, then unfortunately it's probably the console and they're not repairable that I know of. You may want to check the wiring harness and the connections at the console and at the controller under the motor hood. Pull them apart and check for bent pins. If they look good, the console is most likely bad.
Mar 04, 2010 | Nordic Track Nordictrack Apex 4100i...
Treadmill incline stuck @ steepest level (highest)
MAKE SURE YOU STAND TO THE SIDE OF THE TREADMILL WHILE PERFORMING THIS
1)Connect the wall power to the treadmill
2)Remove the safety key
3)Hold down the red stop button and red increase speed button (this is the red triangle next to the start button)
4)Insert the safety key while holding both buttons down in step3
5)The treadmill will now go into a diagnotstic calibration mode
6)Let go of both buttons in step 3 and press the oval stop button once
7) Now press the up arrow green incline button once(This is located to the left of the yellow program button)
8) Allow the treadmill to go through a calibration cycle, once it completes and stops moving remove the safety key count to 3 and reinsert.
Jan 08, 2009 | Exercise & Fitness
Nordic Track NordicTrack T9 ci Treadmill Logo
98 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
