Question about Magnavox MWR20V6 DVD Recorder VCR Combo
Cannot get the dvd out of my recorder, will not eject with remote or the button on the recorder
I was recording a movie, but the recorder stopped after about 40 minutes. I didn't notice because I had turned the TV power off while recording, so when I powered the tv, that is what I seen an error message that it could not record on this DVD. My problem is I can't eject the DVD with the remote or the button on the recorder. After unplugging it, it will not even stay powered on, How can I get the DVD out?
  • Magnavox Master
  • 9,845 Answers
Look on the face of the DVD drawer. You will see a tiny hole in it. Straighten a paper clip and push it in the hole until it stops. Push further and the drawer will open mechanically far enough for you to grab it and open it completely.
Posted on Jul 28, 2017
SOURCE: i cannot record from tv ? how do you get the
This model does not have a tuner so you will not be able to record off of tv unless you run your cable box or dish satellite's audio and video outputs through the dvd recorder's front or back inputs(L1 or L2) and record from those sources. Even then the cable box or satellite box would have to be tuned to the channel that you want to record. If you choose to do this you must go to your on screen menu and under setup/general settings/video/video input you will need to select the video input source(L1,rear or L2, front).
Posted on Nov 02, 2010
  • 8457 Answers
SOURCE: I have a Magnavox Digital Video Disc Recorder
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
Posted on Mar 16, 2011
Kensolutions
  • 455 Answers
SOURCE: I Have A Magnavox DV220MW9
For recording purpose it is required to connect the Direct TV box to the VCR/DVD Combo unit and then to the TV using the analog Red, White and Yellow cables.
It is required to select the proper input to record in the Direct TV box and then press the Record button in the VCR/DVD Combo unit for recording the selected inputs.
To record using the Direct TV remote, it is required to program the Remote to control the other units. All the functions like recording may not work with the universal remotes. It is suggested to use the original remote for recording purpose.
Please feel free to get back to us for further assistance.
Thanks for contacting FixYa.
Posted on Jul 28, 2011
atang1
  • 734 Answers
SOURCE: Magnavox ZV427MG9 DVD Recorder VCR Combo plays vcr for about 5 second then stops and shut off, when turned back on it ejects the tape.
This combo has a problem with the vcr unit which take up wheel will stop working and spill the tape. the unit will stop and eject the tape. You have to replace the whole vcr assembly.
Posted on Feb 21, 2012
  • 6771 Answers
SOURCE: magnavox DVD recorder VCR DVD will not open
Unplug player for 2 minutes, now press and hold power for 30 seconds and release, plug back in and try again, if no! it must be dismantled to recover the disc.
Posted on Apr 04, 2012
How can I get the DVD out of the recorder, it's stuck?
Hi generally most dvd players have a small pin hole below the disk tray. It maybe covered by a dvd flap.
One you get to it just insert a pin and that will release the internal dvd player lock.
Thanks
Jul 28, 2017 | Magnavox MWR20V6 DVD Recorder VCR Combo
DVD side wont respond
I had this problem as well after recording a DVD. player might be in timer mode. press SET TIMER buttom to cancel timer function, press DVD to use player.
Jan 04, 2013 | Toshiba DVR620 DVD Recorder/VCR
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I have a philips DVDR3510V ( DVD/VHS Recorder) which is 16 months old. The problem is that the buttons on the recorder do not work ( except power button) . We thought we had got round this as the remote...
I can only speak to getting the tape out. If all else fails, you can take the player to your local best buy and have them remove the tape for a minimal fee of no more than 30$.
Jul 18, 2011 | Philips MWD2205 DVD Player/VCR
My panasonic dmr-ez475v has a dvd stock inside and will not open or eject the cd. what to do?
I had the same problem. It would not release the DVD because it was not ready. What worked for me, was to insert a VHS Movie and play it for a few seconds, than stop it using the remote, then Eject with the remote, and then after removing the Tape, I pressed the Open/DVD button on the unit and now it worked, it released the DVD
Jul 31, 2010 | Panasonic DMRES30V DVD Recorder/VCR Combo
Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
Apr 06, 2010 | Philips DVDR3370H DVD Recorder/HDD...
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Oct 16, 2007 | GoVideo Go Video DVD/VCR Combo
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Magnavox MWR20V6 DVD Recorder VCR Combo Logo
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
