Question about Jandy 7953 AquaLink RS One Touch Control Panel - White
Jamdy RS Shuts off heater too soon
I have a pool and spa controlled by a Jandy RS One Touch Controller and the spa won't get hot enough. I set the temp to 103 on the one touch control pad and everything works like it is supposed to. When the heater reaches 99 degrees, it shuts off. The controller reads the water temp as 104, but it is not that warm. I replaced the temp sensor and hte problem hasn't improved. I used the temp calibrate function to try and adjust the temperature, but is is always reading 85. I adjust it down as low as it will go (81), but it won't stay at 81: it always reverts back to 85. PCB, ECB, ??? Help please
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
When using the aqualink make sure heater is in tstat mode if not for your heater then turn heater all the way up make sure the wires are connected to pool and com then make sure the wires 5and 6 are connected to the heater then the aqualink will command heat if the red light is lit on controller
Posted on Oct 09, 2014
What would cause my pool heater to get so hot that it melted the black plastic on the outside of the unit.
check the inside for foreign objects like mice, nests, snakes etc. Check the exhaust is clear, and also the air intake. Does it have an air filter?
May 03, 2015 | Hayward Industrial Products Hayward...
Not enough hot water ge smartwater water heater gas
1) Copy following links:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Low temperature setting, extremely cold incoming water, Water leak or broken pipe running hot out of tank, crossover caused by bad faucet cartridge or bad recircirculation check valve,, bad gas control valve thermostat.
Feb 19, 2013 | General Electric GE SmartWater Household...
Water won't stay hot long
1) Thermostat may be bad, or out of calibration. Set temperature higher, and/or troubleshoot by type of gas control.
Copy following link to troubleshoot by type of gas control valve:
2) Dip tube broken
http://waterheatertimer.org/Water-heater-dip-tube.html
3) Water leak running hot water out of tank.
Turn off all taps and put ear against pipe listening for water leak.
Dec 08, 2012 | Water Heaters
No power to pool heater
make sure wiring is correct then make sure breaker is on
Oct 08, 2012 | Jandy LXi Pool Heater Lxi-250 Propane
Our Infinity RX26 is cutting out soon after the hot water tap is turned on, we get a few seconds of hot water then nothing. We are cold! please help!
sounds like faulty thermostat controller disconect from hw unit and try the water again if it stays on the controller is faulty if you dont mind not having controll over the temp of the water you dont need a controller to opperate the hws
Jun 10, 2011 | Rinnai Digital Remote Water Heater Control...
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
May 17, 2010 | Rheem Tankless Hot Water Heater...
The temperature indicator changes as soon as I begin to take a shower. How can you help me.
try unplugging the controller to see if it's a glitch in the contoller. If not you probably do not have enough gas running to it so it can't heat the water fast enough due to lack of gas
Oct 03, 2009 | Rheem Tankless Hot Water Heater...
INSTANT HOT WATER ISN'T HOT ENOUGH.
http://homeappliance.manualsonline.com/manuals/mfg/rinnai_corp/reuva3237ffu.html
http://www.houseneeds.com/shop/HeatingProducts/RoomHeaters/rinnai/rinnaimanuals.asp
Here are two links to get the manual for your unit. Since I don't have the model number for your unit, you can find this in one of the two links. If you have the manual, you will know if you are skipping a step or not. If you have done everything, then I would call Rinnai to find an authorized tech for your appliance. Hope this helps.
Mar 20, 2009 | Rinnai Digital Remote Water Heater Control...
Jandy 7953 AquaLink RS One Touch Control Panel - White Logo
50 people viewed this question
Top Jandy Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Jandy Water Heater Expert? Answer questions, earn points and help others
