Question about Olympus DS-2300 Digital Voice Recorder
How to delete index mark - Olympus DS-2300 Digital Voice Recorder
How do i delete a message on Microsoft outlook 7, for good. when i delete i just get a line thru the email.
Normally, when you delete a message in an IMAP account, it gets a line through it, until you completely eradicate the message by purging the Inbox. (Many consider this an irritating "feature".) The message does not go to the "Deleted Items" folder, the "Trash" or anywhere else. However, after purging, a message that was marked for deletion will be completely erased.
To permanently delete the items marked for deletion, do the following:
Click a folder in your IMAP e-mail account (e-mail account: The server name, user name, password, and e-mail address used by Outlook to connect to an e-mail service. You create the e-mail account in Outlook by using information provided by your administrator or Internet service provider (ISP).). On the Edit menu, point to Purge Deleted Messages. Do one of the following:
Click Purge Marked Items in "folder".
Only items marked for deletion in the folder that you are in are purged from the IMAP mail server.
Click Purge Marked Items in "e-mail account".
All items marked for deletion in any folder for this IMAP e-mail account are purged from the IMAP mail server.
Click Purge Marked Items in All Accounts.
All items marked for deletion in any folder for any IMAP e-mail account are purged from the IMAP mail server.
Please remember to click "Mark as Answer" on the post that helps you, and to click "Unmark as Answer" if a marked post does not actually answer your question. This can be beneficial to other community members reading the thread.
Feb 04, 2018 | Microsoft Computers & Internet
I deleted some data from my hard disk can i recover it?
You can often successfully recover deleted files from a PC, it all depends on what has happened since the files were deleted.
When you delete files the data itself isn't deleted, just the index entry that tells the system where the data for those files is located. The area containing the deleted data is also now marked as free space so it is available for any new files to be written there instead.
If and when that happens, then it is too late to recover your deleted files so it is very, very important to not save any new files or data to the device concerned.
One of the easiest ways to see if you can recover deleted files is to try some good file recovery software. One I used to use is this data recovery program which you can download from site below
http://www.asoftech.com/adr/
May 25, 2012 | Transcend StoreJet Computers & Internet
Deleting files
Im assuming you want to delete browsing history. You can go to Internet options in the control panel and delete browsing history there but to completely remove history files you need to delete the index.dat file.
This file, if you're using windows XP can be found in different places:
C:\Documents and Settings\<username>\Cookies\index.dat
C:\Documents and Settings\<username>\Local Settings\History\History.IE5\index.dat
C:\Documents and Settings\<username>\Local Settings\History\History.IE5\MSHistXXXXXXXXXXX\index.dat
C:\Documents and Settings\<username>\Local Settings\Temporary Internet Files\Content.IE5\index.dat
C:\Documents and Settings\<username>\UserData\index.dat
If you are using a different operating system, just search for index.dat and make note of the locations.
Once you've noted where the locations are you need to restart the computer and log in using safe mode. In safe mode pull up a cmd screen by going to start>run> then type cmd and hit enter.
In the cmd screen change directory by using the command cd C:\Documents and Settings\<username>\UserData for example and then del index.dat (to delete the index.dat file).
Restart and you're good to go.
Apr 06, 2010 | HP Pavilion dv6000z Notebook
Deleting Emails from Touch Pro2
hello,yes it is very possible,all you need do is just to mark the one's you intend marking after you have opened your inbox,then you mark them one after the other then you click on delete to delete the marked one's.or you kindly go to delete all read mails and mark all then you click on delete while it will delete all in split of a minute.
thanks,you are highly appreciated.
Mar 25, 2010 | HTC Touch Pro2 Smartphone
How do I use the index mark function?
Index marks work when the record function is activated, it puts a signal at the start of the recording. So when you put several tv shows on one tape, you can find them. Most video's have a scan button or index button, sometimes it's on a menu. When activated the video will go into fast forward or reverse till it finds an index mark. It will then go into play mode. Some videos will stop playing after a short period and the start searching again, unless you press play. Others have index numbers so you can search for the third recording for example. Commercial videos films etc do not have index marks on.
Feb 24, 2010 | Samsung Televison & Video
I need to mass delete my text messages
hello,
If you want to mass delete your Text...from either inbox or any other folder... open the folder eg. Inbox press options then scroll to mark and mark all, then press option again and delete, you will delete everything there...
Nov 05, 2009 | Nokia E71x Cell Phone
Is there any way to retrieve deleted pictures from the camera?
in the moment you deleted them from the memory card ..the action is permanent and irreversible...the only way to recover is if you saved 'em on a computer a cd or somewhere else...
Sep 04, 2009 | Cameras
Timing
Set timing on what??? I'll give you a generic answer pertaining to engines: Cam & crankshafts carry a index marks on them. Cam gear is indexed to a mark on the cylinder head, crankshaft indexed to "0" degrees on main damper pulley/timing mark on cover scale.Or, they are indexed to each other, example: Chevy smallblocks : cam gear indexes straight down to crank gear@straight up position (which is also, "0" when checked on timing index pad on cover) This info can be found in any general repair manual. A more complex way to establish positions is with dial indicators and a degree wheel, but in most cases this is unnecessary!
Dec 21, 2008 | Sport & Outdoor - Others
Deleting pics from memory stick
Option Go to list of pictures and check any menus like(mark ,mark all.delete all ) if have option mark menu -just mark all pictures and select delete. opton
2 if you have mark all -just -mark all -and delete
3.if you have delete all -just -delete all -it will delete all of your pictures in memory card
IF NOT OK
IF YOU REALLY delete all pictures and all datas
4.if you wish to do Formate the memory stick
now your Memory stick has Empty.
May 15, 2008 | Sony Part 996804671 Service Manual for...
Olympus DS-2300 Digital Voice Recorder Logo
23 people viewed this question
Top Olympus Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
