Question about Spark Plugs BR4HS Plug 10/BX #3322
My 1996 blazer wont accelerate past 30 what is the issue
I just replaced the spark plugs, wires, cap and rotor
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 72 Answers
Check the timing... small adjustments can be made by turning the distributor... check fuel filters... partially clogged filters can allow enough fuel to pass to keep the engine running good untill more juel is needed for acceleration. double check that plug wires were put on in right order.
Posted on Feb 11, 2014
Engine died while driving, no spark, replaced coil, now starts, idles, runs well at low rpm, but misfires when accelerating. No check engine costs thrown. What should I check next.
Change your ignition module. The distributor is a weak point of the Honda, I will always change out the whole thing than just try the coil.
Jun 05, 2015 | 1996 Honda Civic
1999 chevy blazer not starting
Check the plug wire from the ignition coil to the distributor cap.
If you haven't already, replace the distributor cap and rotor.
The GM Vortec's have issues with moisture getting inside the cap and rotor and causing problems.
I’m happy to help further over the phone at https://www.6ya.com/expert/jason_00b31cc8f593773a
Apr 24, 2012 | 1999 Chevrolet Blazer
1996 blazer wont start
Have you checked the coil?
Dec 03, 2011 | 1996 Chevrolet Blazer
Hi. i have a 1994 s10 blazer and it will not start for anything. i changed the injectors and the fuel pump, spark plugs are fine and tubes are in the right posisioon, do you know what it could be.
Anytime a car wont start its missing one of the key things it needs to start. Air, Fuel, spark or compression. The first thing to check is to pull a wire off the spark plug and put a screw drive in the end of the wire. Lay the screw driver on the engine near metal. Crank it and look for a large blue spark it should make a nice popping noise.
If no spark try the same thing with the coil wire. If spark its the cap or rotor. No spark its the coil or module.
If the plugs have spark, try pouring a small amount of gas in the throttle body and see if that starts it. If it does, fuel problem check filter and pump.
If it wont start with either or gas in the throttle body and the plugs have spark then it is either a timing or compression issue. Remove the plug wire from the center of the distrib cap and then remove the cap making sure no wires come off. Have someone crank the engine and see if the rotor spins. If it does not you need to replace the timing chain/belt. If it does spin rent a compression checker and check each cylinder.
Hope this helps.
Aug 25, 2010 | 1994 Chevrolet S-10 Blazer
It wont turn over
Coil, ignition fuse, or a bad rotor/cap issue.
Jul 18, 2010 | 1996 Chevrolet Blazer
Blazer wont start
You are getting good spark to the plugs? Have to assume you retimed it after you changed the rotor and cap. Wires are good?
Could be the ignition module, but they usually are either good or bad and not itermittent(sp)...
If it trying but just not 'catching'.. seems like a timing issue, or possibly the coil (although coils tend to be good or bad as well)
Mar 06, 2010 | 2000 Chevrolet Blazer
No start, no spark, no signal to the coil
there is a fuse that works the battery try checking if it is still good
Mar 03, 2009 | 1996 Chevrolet Blazer
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
55 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
