Question about Stanley Tools GR100 Pro Glue Gun Kit/Sticks Professional - Each
Stanley 6-gr100 - burned resistor (R5 in the PCB)
Can someone help me to find the value of this resitor (R5), so I can change it? Thank you so much.
Need Help with burned resistors value. Please.
have you repaired the component that burned these resistors out? if not then you cannot replace them as they will just cook again.
Nov 06, 2015 | Cobra CPI 1575 1500 Watt 12 Volt DC to 120...
Burnt resistor on Lincoln 1210 battery charger base
Dear Anon,
A R5 Resistor Might Be 1K ohm.
Sep 15, 2014 | 1210 110 Volt Charger
Need the instruction manual for a Stanley GR100 glue gun
I do not believe there is a manual. there are instructions on the package. Insert the glue stick and turn on the gun. When the glue melts and the trigger moves glue will come out the front tip. This model has 2 temperatures so if it delivers too fast or runny you can lower the temperature. You pull the trigger to push the glue stick into the heating element to melt the glue. It is pretty straight forward. As the glue stick is consumed you stick in another glue stick. I suggest testing on something before using on your project. Do be careful of the hot end. It will definitely burn you if you touch it and the glue coming out is nearly as hot as the metal.
Jan 17, 2014 | Stanley Gr100 Glue-pro Dualmelt Glue Gun
What is the color code for resistors
Enter the colors in this calculator to determine the values you need.
Apr 05, 2012 | Cars & Trucks
Hello i have incubator brand suro 20 com king its running but there is no heating a parts burn inside the main controler i like to ask if you can supplied me with the schematic diagram to find the suitable...
I have a king surro with a temperature control fault 2 resistors next to power transistor on pcb burnt out I can tell values of any other components on pcb but does anyone have a controller board who can tell me what value resistors are steve-- protodezine@gmail.com
Jan 06, 2011 | Heating & Cooling
Sharp TV. over heating resister near power supply
If the wattage rating is less it will definitely go hot. Resistor overheating may be due to leaky capacitors also. If input voltage is higher also this could happen. If the performance of the TV is fine not to worry.
If smoke comes from the resitor, you have to be alert. If you find the TV performance is OK , you can increase the wattage of the resistor, keeping the same resistor value.
Do not flush mount the resistor to the PCB. Mount it at a higher level and solder.
Sep 03, 2010 | Sharp Televison & Video
Burned resistor, need value for replacement
I re-drew the schematics from the PCB-layout and did some backward engineering to determine the resistor value. The machine is now again in excellent working order.
Jan 20, 2009 | Sewing Machines
Burned resistor... no clue what is its value
brYze,
take a look and get the resistor number printed on the pcb. i might be able to give you what you're asking for.
Francis
Aug 31, 2008 | AOC 4 Vn 14" CRT Monitor
Convergence
Nana
Look under the chassis on the bottom right side. I found a sheet that describe most of the componet values
Good luck
Sep 26, 2007 | Televison & Video
Stanley Tools GR100 Pro Glue Gun Kit/Sticks Professional - Each Logo
73 people viewed this question
Top Stanley Crafts & Hobbies Experts
Steve Mason
Tony Crow
Are you a Stanley Craft and Hobby Expert? Answer questions, earn points and help others
