Question about Dishwashers
Indesit ide 750 a03 error - Dishwashers
4 Suggested Answers
SOURCE: Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I've had the same problem on my Indesit (IDL-730, IDL730) and after pouring in salt until full for ages, without the light going out, I finally decided to do the reverse.
I left it to run down the salt over a couple of months, until well empty (not ideal, but I was getting desperate!), and then finally refilled it.
Problem solved - salt error light was no longer on
All I can figure is that a blockage had set in and casued the issue. Leaving it to clear over time sorted it.
Hope this helps in your situation.
Posted on Nov 18, 2007
  • 184 Answers
SOURCE: Indesit DE43UK dishwasher. Water only
INCREASE THE WATER TEMP AT THE HOUSE WATER HEATER SO YOU WILL HAVE 120 DEGREE WATER COMING INTO THE DISHWASHER. IF THE DISHWASHER IS NEXT TO THE SINK, PURGE THE HOT WATER LINE AT THE SINK UNTIL YOU ACTUALLY GET HOT WATER. THEN, START YOUR DISHWASHER.
Posted on Apr 03, 2008
  • 867 Answers
SOURCE: HI our Indesit IDE 750 dishwasher gets stuck on the first cycle and the timer doesn't count down. Switching it off and restarting drains the water, but it gets stuck at the same point in the cycle
This sounds like a heating element issue, If the water doesn't get warm it just keeps trying to heat but won't advance past this point until it has reached a set temperature. You dishwasher may or may not be fitted with a thermal overload that may have tripped, Unplug the dishwasher, Remove the lower kick panel and look for a small circular metal sensor with 2 or 3 wires on it attached to the basepan of the dishwasher, Check to see if it has a red button in the middle and if it's there push it then re-assemble and try again, otherwise it's a visit from the serviceman unfortunately.
Posted on Mar 04, 2012
My dishwasher shows error code A03 can u help me?
What is the make and model number of your dishwasher?
Oct 15, 2014 | Indesit Dishwashers
My dishwasher shows error cod A03
A03 - Short circuit on thermistor or Time-out drain- Check filter for blockages then book a dishwasher repair if the problem persists.
Also check that the nothing has managed to get through teh filters into teh drain pump and block it or that drain hose is not crushed and or blocked,
IBM 9068-A03 microcode update fail.
Use the oldest computer you can fine with Windows98 or event 95
Mar 15, 2012 | Computers & Internet
Mar 04, 2012 | Dishwashers
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
Indesit IDE 1005 error code
Replace the control board
May 22, 2008 | Dishwashers
Indesit DE43UK dishwasher. Water only gets lukewarm, intermittently gives Fault code A03 - "thermistor short circuit". Indesit says no such part as thermistor listed for this model. Indesit will...
Apr 03, 2008 | Dishwashers
I think I have the answer.
On Yahoo Answers Blue Rizla Girl put up the idea that the sensor is some form of hydrometer. (i.e. floats in salty water sinks if not salty enough)
Based on this thought I postulated that the sensor is some form of hydrometer float in a tube with perhaps an optical sensor.
If this is correct why is it not working?
Is it because the float is stuck at the bottom of the tube, perhaps by some food debris? If so how can we fix it?
This is what I did on my Hotpoint FWD60:-
I took the salt filler cap off. There was no salt in the reservoir as it has been a problem for months, and I was only refilling it when dishes were not coming clean.
I poured 2 litres of hot water into the salt reservoir.
I then put the empty machine on the intensive 65 degree wash, half load and with the reservoir cap still OFF.
When finished I filled up with salt and HEY PRESTO the salt light is OFF!!!!
Just hope it stays that way until the reservoir really needs refilling.
While I was down on my hands and knees I took the opportunity to clean the filters in the sump. They do get full of bits!
I also flushed the sump by dashing a couple of cups of hot water into it and then bailing it out with a small yoghurt pot. I repeated this until the water in the yoghurt pot and the sump no longer had any signs of bits in them. (Dashing = vigorously pour)
I was amazed at how many bits I got out, especially considering I had given the machine a good clean in the past 6 weeks.
I even got part of a paper label!
So there we have it, try it out and report back.
Sep 14, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Dishwashers Logo
73 people viewed this question
Top Dishwashers Experts
