Question about Element Televison & Video
Element tv elcpo371
Will not turn on. Not even the standby light & the fuse to the power supply is not blown??????
  • Element Master
  • 10,045 Answers
Check the voltages on the power supply board. If they all are present and correct, then the main board isn't sending the On signal to the power supply board. Replace the main board.
Posted on Feb 15, 2017
SOURCE: Element LCD tv with no power. I replaced fuse,
You probably need a new power source. Take it to you repair shop. That's what I had to do and it was relatively inexpensive.
Posted on Mar 23, 2009
  • 41 Answers
SOURCE: tv stuck on standby
Power supply probably needs to be replaced if you don't even hear the relay click after the power is switched on.
Posted on Mar 30, 2009
  • 280 Answers
SOURCE: HARWA LC37W18S LCD TV using KAS200-5S241812XLS
Check all the caps on PSB. if any look puffed , replace them. If you are getting 14volts to the ivnerter board PS is good and the inverter is bad.. good luck
Posted on Apr 10, 2009
  • 21 Answers
SOURCE: LCD TV, No Power, No Standby LED, Buzzing sound from Power supply
sounds like either way your power board is bad- do you intend on replacing a component? I would look for Puffy caps- you know- leaking from the top-
Posted on Aug 21, 2009
budmrtn
  • 11361 Answers
SOURCE: My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Posted on Oct 24, 2009
Westinghouse tv stopped working
Hi
If no standby light is on (red), maybe a blown fuse that can be replaced with a new one of the same value. If the blown fuse is blackened, some componet is bad inside the power supply.
If the fuse replacement does no result, the problem may be in the power supply (IC power supply switching controller, switching transistor, startup resistor or even an overload in the supply line output) which requires a technician to fix it.
Sully
Sep 28, 2013 | RCA 27V530T 27" TV
I have a 42" Proscan standby light comes on but the tv wont turn on
I see so many here with no sound/no picture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo
Aug 26, 2012 | Proscan 42LA45H 42 in. LCD TV
Just bought the element pulg it in and it won't come on
I see so many here with no sound/nopicture issues:
ISSUES:
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.6_11_2012_2_17_41_pm.jpg6_11_2012_2_18_09_pm.jpg
Jun 10, 2012 | Element Electronics Televison & Video
Element tv Model ELCHW402 won't turn on
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_25_2012_3_07_58_pm.jpg5_25_2012_3_08_17_pm.jpg5_25_2012_3_09_15_pm.jpg
May 24, 2012 | Element ELCHW402 40 in. LCD HDTV
40 in 1088plcd Element tv stop working
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_19_2012_2_45_43_pm.jpg5_19_2012_2_46_20_pm.jpg
May 19, 2012 | Element Electronics Televison & Video
Timer light
ISSUES:
Answers to issues:
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_19_2012_2_36_48_pm.jpg
Apr 18, 2012 | Hitachi C29-F100 29" TV
It won't turn on
hi; try to check the power cord ,
if power cord has no problem it has standby light coming from the TV
when no light or dead set. there a fuse blown on the power supply section.
if there's standby light wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help.........
Sep 05, 2011 | Mitsubishi LT-55265 55 in. HDTV LCD TV
WONT POWER ON?
Sep 05, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
Will not turn on
Without even a standby light on, it means that there's no power being fed into/out of the power supply. If it's an external power supply (a little, or large, black rectangle attached to the power cord) then it can be easily opened and checked for blown fuses. If it's just a blown fuse, then that can be replaced for less than a dollar in most situations.
Jun 03, 2010 | Imation MT2028DBLK 20 inch TV
My Element 32 is frozen in standby... won't turn on!
blown caps in power supply they will be puffed up on top easy fix
Sep 17, 2009 | Element Electronics FLX3210 32 in. LCD TV
Televison & Video Logo
35 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
