Photocopier machine canon ir 5870c error code E000732-0001
PHOTOCOPIER MACHINE CANON IR5870C WITH ERROR CODE E000732-0001 IS STOPING MACHINE TO RUNING SHOW ME WHERE FAULT COMING FROM
4 Suggested Answers
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Posted on Feb 11, 2010
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
E003 Error code in canon ir2420 photocopier
Code E003-0000 Description Abnormally low temperature (detected by main thermistor)
After the temperature detected by the main thermistor has reached the specified value, it does not reach the specified value during initial rotation. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Error Codes Canon iR2420 Code E003 0000
Oct 28, 2015 | Canon Office Equipment & Supplies
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
Sep 04, 2014 | Canon Cannon Ir 2022 Photocopier
Services call sc530
Sir please tell me
Canon IR 5870c
how to remove this error code E000748-4000
my Email: snowman587@yahoo.com
Feb 24, 2014 | Ricoh Aficio CL1000N Printer
Error Code E000197
check the flat cable of dc controller to main drive pcb
Jan 13, 2014 | Canon imageRUNNER 2525 AllInOne Laser...
Canon ir 5870 c showing the error code E000003 - 00051
Canon IR 5870c showing the error code E000061-0003 please tell me how to remove error E000061-0003
Apr 24, 2013 | Canon iRC3100 Printer
I have System error E007 problem in my Canon iR-2016 copier machine
System error e007 for canon copier ir2016j copier needs solution
May 23, 2008 | Sharp AR-M350N Copier
220 people viewed this question
k24674
