Only one side of 4wheel drives is working - Computers & Internet
    Sergeant:
  • 258 Answers
Laptops do not have any wheels. What's wrong with you?
Posted on Apr 17, 2014
My 89petrol talc won't come out of 4wheel drivE
Try to Manually move the Shifter with your hand on the Transfer Case.. Does this work?
Apr 15, 2013 | Toyota Land Cruiser Cars & Trucks
No light on 4wheel dr control
There are a few things that would cause this problem.
The first and most common would be the switch itself is bad. the next would be a bad 4wheel drive encoder motor, this is the motor on the transfer case that is used to operate the 4wheel drive. The last would be the 4 wheel drive module.
You will need to do some testing, if the four wheel drive is working and goes in and out of 4 wheel drive then i would say it the switch. if it does not work correctly it may still be the switch or one of the components i listed above.I have enclosed a wiring diagram, you will need to do some testing to check system, first make sure all fuses are good. the fuses that operate the 4wd are listed on diagram, it will also tell you the location of each part. you will need to test front axle actuator and selector motor and switch, you will need a test light and a meter. hope this is helpful, good day.4_26_2012_10_13_14_pm.gif
Apr 26, 2012 | 2002 GMC Envoy
2000 suzuki grand vitara 4 wheel drive will not engage
2000 Suzuki Grand Vitara rear Wheel Drive working but 4wheel
is not working, dash 4wheel sign light not working
Jan 12, 2011 | 2000 Suzuki Grand Vitara
I have a 99 Chevy Blazer, I have had it for about six months or so. The past month and a half, it pops out of 2 wheel drive and into 4 wheel drive (sometimes blinking back and forth between 4 hi and 4 lo)....
I have the same trouble. It seems a relay is keeping it in 4wheel drive. I havne't solved the trouble yet. It may be a loose or corroded wire in the connector to the TCCM located in the passenger kick panel. Dealer part about $450 or more. For the moment I took out the fuse for the 4 wheel drive. It is located in the lower right hand side in the fuse the box under the hood. It disengages the 4wheel drive and I replace the fuse if I need the 4wheel drive.
Aug 26, 2010 | 1999 Chevrolet Blazer
How to loctae a crank shaft sensor for a 4wheel
Sits on the side of the engine block, held on with a 8 or 10mm bolt, remove bolt and sensor slides right out.
Jun 04, 2010 | 2002 Chevrolet TrailBlazer
4wheel drive light is blinking
there is NO '4wheel drive emergency' light on a 2006 Tucson.
Sep 10, 2009 | 2006 Hyundai Tucson
Part-time 4wheel drive
you have a bad or faulty sensor that communicates the 4wd position to the dash the sensor is on the top front of the transfer case. Find a large open area and drive in reverse for about 500 feet then put car in drive and pull forward this might enable the sensor to know what position the transfer case is in The transfer case is connected to the transmission and also to the front and rear axles by means of drive shafts. If this doesn't work change you sensor on the top front of your transfer case. hope this helps you please rate me and for further assistance you can always ask me. wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Apr 10, 2009 | 2003 Jeep Liberty
4WD not working
There is a switch on the side of the 4wheel selector. This will indicate the posistion of the 4wheel shift on the dash just get a meter and check out the wiring. The burnt wiring should not affect your 4wheel drive.
Apr 07, 2009 | 2000 Suzuki Grand Vitara
2005 jeep liberty 4 weel drive will not engage
I just bought a jeep liberty, 2005. It's automatic with 4wheel drive option. I do not have an owners manual. Do not know how to engage the 4wheel drive. I have never had a 4wheel drive vechile before.
Jan 15, 2009 | 2003 Jeep Liberty
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
