Question about Samsung SP 56 K 3 HV 56" Projection Television
Chip 1272-5003W 6AARC3Y-190704E
What are chips
chip:
noun
plural noun: chips
  1. 1. a small piece of something removed in the course of chopping, cutting, or breaking a hard material such as wood or stone.
    "granite chips"
    synonyms: fragment, piece, bit; More
    • a hole or mark on a hard object or surface where a small piece has broken off."keep an eye out for any scratches or chips on the bodywork that might need treating"
      synonyms: nick, crack, snick, scratch; More
  2. BRITISHwood or woody fibre split into thin strips and used for weaving hats or baskets.
  • 2. BRITISH
    a long rectangular piece of deep-fried potato.
    "he always enjoyed fish and chips"
    synonyms: chipped potatoes, potato chips, game chips; More
    • NORTH AMERICANa potato crisp.
      noun: potato chip; plural noun: potato chips
  • 3. short for microchip.
  • 4. a counter used in certain gambling games to represent money.
    "a poker chip"
    synonyms: counter, token, disc, jetton; More
  • 5. (in football, golf, and other sports) a short lofted kick or shot.
    "he made no mistake with a chip and a par putt from four feet to seal victory"
  • verb
    3rd person present: chips
    1. 1. cut or break (a small piece) from a hard material.
      "we had to chip ice off the upper deck"
      • (of a material or object) break at the edge or on the surface."the paint had chipped off the gate"
        synonyms: break (off), crack, fragment, crumble More
    2. cut pieces off (a hard material) to shape it or break it up.
      "craftsmen chipped the blocks of flint to the required shape"
      synonyms: whittle, hew, chisel More
  • 2.
    BRITISH
    cut (a potato) into chips.
  • 3. (in football, golf, and other sports) kick or strike (a ball or shot) to produce a short lofted shot or pass.
    "he chipped a superb shot over the keeper"
  • Jul 07, 2014 | Office Equipment & Supplies
    How do i remove write-protection from a micro chip
    If the micro chip is a rom then you can not remove it. If the chip is a flash then you can. I need to know more about the chip ie number on the chip to see how it is done. The number on the chip will tell you if it is a eprom flash rom controller, basically what kind of chip it is and its function.
    Apr 03, 2014 | Dell Computers & Internet
    Replace drum in xerox phaser
    asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
    chip-b.jpg" ]
    Version: No area limited
    Yield: 5,000-10,000.
    Printers Model compatible: Xerox Phaser 3450B
    Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
    Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
    And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
    1.Replace new Toner cartridge for Xerox Phaser 3450B:
    - If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
    - With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
    - When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
    2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
    khe-chip-b.jpg" ]
    - If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
    - With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
    - When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
    3. Reset Toner cartridge chip for Xerox Phaser 3450B
    If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
    The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
    -"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
    -"Tone life end", "Replace new unit"
    - "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
    How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
    We use unismart device toreset Drum chip for Xerox Phaser 3450B
    Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
    Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
    unismart1.jpg" ]
    Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
    current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
    In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
    Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
    Who sell cheap pokerist chips??
    Hi Darrel...
    Amazon offers pretty large number of poker chips for sale. Take a look here Amazon com poker chips set (and pick ones you like it) Hope this was helpful.
    enjoy
    Apr 22, 2012 | Kama Games The Pokerist club — Texas Poker
    Xerox Phaser 3500 - installed new toner still says it needs replaced. Is there a way to reset the message? We have powered off/on and it still says that it needs replaced.
    the only way to reset the message is to replace the cartridge CHIP with new one or reset the chip with proper CHIP reseter(but i don't think that you have reseter).
    This printer can write on cartridge chip and sometimes when you replace cartridges the printer writes directly the information from empty chip to new chip and that makes new chip EMPTY. This is some kind of bug. SORRY!!! CHIP is cheep so don't worry...be happy
    pifonski
    Mar 03, 2011 | Xerox Phaser 3500/DN Laser Printer
    Where do i install the chip on 2002 monticarlo
    the chip go's inside the ecu or the car's computer (most newer cars the computer is located passenger side in the engine compartment front disconect battery locate the access plate should be 1/2 x 2 see chip pull chip streight out DO NOT TOUCH PINS static will kill chip take new chip (note the way you pulled old chip out chip must be installed the same direction reinstall cover plate connect battery start car
    Dec 06, 2009 | Chips Computers & Internet
    Have a 2.8 ghz 478 chip, but ive never seen a pinless chip???
    I do not know of any adaptors.
    You have two options
    Get a board that takes the CPU
    Get a CPU that fits the board
    Sep 11, 2009 | Intel Motherboard
    PC does not recognize the chip
    recover your data from the chip in your camera and format the chip via the digital photo camera you have do not format by windows any time.
    this is a format error. the fault is master boot record sector 1.
    of the chip where info about the chip is stored.
    Jan 10, 2009 | Computers & Internet
    Magic Singalong Song Chips - question please
    Not exactly, magic sing comes in different models with different song chip. Old magic sings uses Black with metal song chip, Black song chips, Silver song chips and Gray song chips.
    For your Magic sing II (I believed it has four song chips slot) the compatible song chip is the Silver song chip.
    Oct 26, 2008 | Magic Sing Along Consumer Microphone
    Samsung SP 56 K 3 HV 56" Projection Television Logo
    Henry  Thomas
    Henry Thomas
    Jerry Greenberg
    Jerry Greenberg
