Question about Siemens KA62DV50GB Side by Side Refrigerator
Siemens ka62dv70gb water not working
The cold water function has stopped working on the fridge. Ice etc seems to still work, pressing the water button some whirring and clicking can be heard.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My Siemens fridge freezer model
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 04, 2011
Hi i have installed my american fridge freezer DAEWOO FRAQ19DCB but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to t
The inlet water supply solenoid valve has two coils and valves. The icemaker valve is not functioning either electrically or mechanically. Best bet is to replace the complete assembly.
Jan 25, 2015 | Daewoo Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My maytag msd2657heb i could hear it running but the fridge and freezer not cold at all
It can be faulty compressor or issue with defrost.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
Exterior water function stopped working. This is simultaneous with me removing the ice holder to defrost, then replacing. Ice maker functions and all else seems normal.  It seems like water and ice...
ck the fresh food tempt it may be too cold . and has frozen water line . adjust to a warmer tempt and it should start working .. mm ps in 24 hr or so ..
Dec 23, 2009 | Refrigerators
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Admiral Fridge Freezer
i have solved the problem with lights onthe drinks dispenser itis in sabbath mode torelease it push and hold the lock andauto light buttons at the same time for 3 or 4 seconds it worked for me hope it solves your problem
alan stoker.
May 15, 2008 | Admiral 26 cu. ft. Side-By-Side...
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I had GE come out and look at it. I wasn't home to ask questions. The repair man basically said it was a 'loose connection' in the back which is where the motherboard is for all the electronics. It took him less than 5 minutes to fix and he was gone.
Thankfully - it cost me zilch. I told a small white lie and said we were still under warranty and they didn't ask to verify. Can I get an Amen!
Oct 20, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Siemens KA62DV50GB Side by Side Refrigerator Logo
110 people viewed this question
Top Siemens Refrigerators Experts
marlin siecinski
Mai Lor
Are you a Siemens Refrigerator Expert? Answer questions, earn points and help others
