Question about Kyocera FS1320D Laser Printer
Fs1320d print unit not detected
Hello, I need help with an error. The printer shows that the print unit is not installed or not detected. I have reinstalled the module several times with no result.
2 Suggested Answers
SOURCE: Cannot print to network printer
Is this printer installed on a server and shared over a network? Or is it installed independently on each workstation?
If it's on a server, printing could be "paused", or set to "use offline" Go to the "printers and Faxes" dialog box, and 'right click" on the printer icon, is there an option to either "resume printing", or "use printer ON line"? If so, select this option.
If it's not on a server then it would be extremely unlikely that this condition would happen on all workstations
Other than that make sure that the Subnet mask is set correctly on the printer.
If that doesn't work....it's probably time to try re-installing the driver.
Posted on May 16, 2009
I have Toshiba e-studio 257 and have an error code C970 on the screen. Can you help me?
C3D2 EPU board memory old parts detection error: The EPU board cannot detect the new process unit when the equipment is started in the EPU replacement mode ([7] + [START]). C410 Thermistor or heater abnormality at power-ON: Abnormality of service call the thermistor is detected when power is turned ON or the temperature of the fuser roller does not rise in a specified period of time after power is turned ON. C430 Thermistor abnormality after abnormality judgment: Abnormality of the thermistor is detected after a specified period of time has passed from power-ON (including ready state). C440 Heater abnormality after abnormality judgment: The temperature of the fuser roller has exceeded the range of control or does not even reach the range. C450 Thermistor abnormality during printing: Abnormality of the thermistor is detected during printing. C4C0 Fuser unit new/old detection fuse abnormality C550 RADF I/F error: Communication error has occurred between the RADF and the scanner. C551 Document feeder model detection error: An optional document feeder that is not compatible to this equipment is installed. C570 Communication error between Engine-CPU and IPC board C580 Communication error between IPC board and finisher C5A0 EEPROM communication abnormality (LGC board) C8E0 ADF communication abnormality: The system has to be stopped because the control abnormality occurred C940 Engine-CPU abnormality C970 High-voltage transformer abnormality: Leakage of the main charger is detected. CA10 Polygonal motor abnormality: The polygonal motor is not rotating normally.
These are the error cods list. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 08, 2016 | Toshiba Office Equipment & Supplies
How do i install canon pixma mx320 series printer?
hello,
Remove all the printer settings, and swich off the printer.And restart your system. install the drivers with MX 320 CD. Once it ask you to switch on your printer, please switch on then the printer it automatically it will detect and it will finish this.This is the normal installation procedure .
If you want more help from me please give me the details of the OS and error code and other's.
Tks
Feb 10, 2015 | Canon PIXMA Office Equipment & Supplies
Drum reset
need to pump toner inside the dev unit
=open and close main door 10 to 15 times slowly.
May 21, 2014 | Kyocera FS1320D Laser Printer
I have a Canon IPF 700. After i clean the print head it showed error code 03800500-2F2F .what is the problem and how to fix it?
The head management sensor detected an ink discharge error.
A sensor sensitivity error was detected during head management sensor position adjustment.
Possible solution is to reinstall your old print head or replace print head with new one.
Aug 08, 2011 | Office Equipment & Supplies
Missing color ink cartridge...have full black cartridge...Printer won't print.
Hello, this is to be expected . You will need to have all cartridges installed and with ink in, even if you only want to print in black, or the printer will detect an error and won't work.
Regards,
nicam49
Jan 26, 2011 | HP Photosmart 3180 All-In-One Printer
MY Ricoh Aficio 2550 Printer I use it via IP in windows 7 and can't print Duplex Unit it said. Duplex :(Something conflict I can't Remember) Duplex: Unit not install
In Windows 7, you can right click on the printer under Devices and Printers, then select "Printer properties" (not "Properties"), then under "Device Settings" you can set the "Duplex Unit" to "Installed". Afterwards, you can go back to "Printing Preferences"->"Finishing"->"Print on Both Sides"->Print on Long/Short Edge.
Dec 28, 2010 | Ricoh Aficio CL7200 Laser Printer
Error message
Uninstall the printer driver from Device Manager, then scan for hardware changes and install the printer driver when it detects the printer...All the best
Oct 02, 2009 | HP Deskjet 6940 InkJet Printer
Lexmark Z11 won't work
Remove the software for the printer through ad remove programs in control panel
Then keep unit unplugged from usb. Install the device drivers then plug unit in when software asks or after it requests a reboot.
Jan 16, 2009 | Lexmark JetPrinter Z11 InkJet Color...
"PUT IN CARTRIDGE" error with cartridges installed
Hello Dear,
The Print Head in your printer is physically damaged and so even though it is present and installed it will not be detected by the Printer, you need to purchase and install a new print head for your printer.
Warm Regards,
Manoj Joseph
+91 9352008418
Mar 15, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Kyocera FS1320D Laser Printer Logo
44 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
