Question about Kyocera FS1320D Laser Printer
How can i reset FS-1320D
Hello, I need help with an error. The printer shows that the print unit is not installed or not detected. I have reinstalled the printer unit several times with no result.
Soulvisitor
  • 1113 Answers
SOURCE: FS-3900DN Error 0150:0000000
This is a common error but I have done heaps and fix has always been use clean formatted stick, get lastest engine firmware
copy to root of usb stick or CFlash card(side), power on printer with stick in socket I double check your copy engine firmware
I use engine S2F9_1000008002.x and system, S2F9_3000008002.bcmp . allow to complete, remove stick, youre done, if this fails and I've done probally 100 and yet to see a fail then try with CF card if that also fails then you will need new eprom from kyo
Posted on Jan 15, 2008
SOURCE: FS 920 printer
HI
I HAVE Error red light on all the time.cannot print anything.
THANK YOU VERY MUCH
ZIAD
Posted on Jun 06, 2008
acdr
  • 1913 Answers
SOURCE: I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Posted on Mar 21, 2009
  • 46 Answers
SOURCE: Printer KYOCERA FS-1030D not geting connected to my local Netwok.
I cannot remember the name of the utility but I know on the new drivers for the newer machine it is built into it it discovers the machine baised on its mac address and you can change / set the ip from there.Try some of the utilities from the kyocera support sitehttp://www.kyocerasupport.co.uk/index/download_center.html
Posted on Jun 11, 2009
  • 46 Answers
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Posted on Jun 12, 2009
My kyocera FS-1035 is displaying error message: The developer unit is not installed. What can I do, it won't allow me to enter the menu
Hello, you need to check that the developer is installed properly. Also check that all the contacts are clean.
How did this error happened?
Nov 25, 2016 | Kyocera FS-1035MFP Printer
Install MK Kit Kyocera FS-9130 How to reset MK Kit Counter
you can reset the counter but on the falcon engines if you go past the maint. cycle they will eventually fall down and print solid black copies.
Feb 04, 2016 | Kyocera Office Equipment & Supplies
Ip address for kyocera fs-1320d
Contact your IP Provider for the information you require
Mar 30, 2015 | Kyocera Mita Ecosys FS-1320D - 37 PPM...
I need to add an IP address to a Kocera 1320d that has been hooked up as a USB printer, how do i do this?
You can print a status page by pressing for 5 seconds the green button and see what IP address has the printer. Then you can modify it through your PC. The most important is that you have a NIC (network interfade card), because this printer (FS-1320D) comes from Kyocera without a NIC. Unless your printer is already intergrated with a NIC.
Aug 21, 2014 | Kyocera FS-1320D
How to set ip address for kyocera 1320d
Print a Status Page by pressing the green button for about 5 secs. Check the IP Address on the Status Page. If the IP Address is similar to your local network, you type that IP Address in an internet browser to open the Command Center (web interface).
If it is not similar, then you can change PC's IP to be similar to printer and via the command center, you change the printer's IP to a desired IP (similar to your local network) and restore then the IP of the PC to the one before.
How do I install a new genuine kyocera developer unit (dv-172) in a Kyocera Y FS-1320D?
1-5-4 Developing section
(1) Detaching and refitting the developing unit
Procedure
1. Open the top cover.
2. Open the front cover.
3. Remove the developing unit (with toner container).
4. Check or replace the developing unit and
refit all the removed parts.
5. When the developing unit is replaced with a
new one, carry out the following procedure.
6. Perform toner install mode in the service
mode (see page 1-3-12).
May 26, 2014 | Kyocera Office Equipment & Supplies
FS-3900DN rear unit paper jam
Hello, Power down the unit.Unplug power from wall. Power back up, if the error still happens, there is a small piece of paper somewhere, take toner out and look, or pull down back cover and look in there.
May 22, 2014 | Kyocera FS Office Equipment & Supplies
Kyocera FS-2000D shows call service 7410:0130324
7410 is an error (all numbers following : is the number of pages printed.
- indicating the Drum Unit is not installed properly or you have a defective curcit board. Tyoically it is drum drum is not fully seated.
If you open the door on the left hand side of the printer, where your waste toner container goes and press firmaly on the drum which is loacted behind the waste toner container and close the printer backup. If the drum is properly seated the error should close.
I hope this is helpful,
Shawn
Feb 07, 2011 | Kyocera FS-2000D Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
ERROR CODE 7410:0004729
Hi, switch off printer ,just open cover(door) on the left side of the machine and push Drum Unit in machine(to proper seat)
You have to hear "click" sound.Switch on printer.
Regards...
Mar 08, 2008 | Kyocera FS-2000D Laser Printer
Kyocera FS1320D Laser Printer Logo
69 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
