Question about Dell 2150cn Printer
Magenta cartridge is stuck,Seems as though there is a cylinder that didn't retract or came out of Cart and shouldn't have. When I push the cart back to remove, the cylinder does not retract
4 Suggested Answers
  • 36 Answers
SOURCE: cartridge error
try reseating the cartridge & also reseat the power brick assembly.....also if u hv the factory installed cartridges....try installing those & chk if u still get the error...
Posted on Jul 06, 2008
  • 275 Answers
SOURCE: I have changed black cartridge but it says error
The cartridges have a piece of clear tape on them which needs to be removed before installation, keeps the ink fresh sort of. Take out the cartridge and then look for the piece of clear tape, remove it gently and re install.
Posted on Dec 03, 2009
  • 130 Answers
SOURCE: my office depot repl cart for Dell A960 will not print
Try using alcohol on a Qtip to clean the print head. It may be clogged and the sensor thinks the tape is still on.
Posted on Jun 06, 2010
I have a Canon iP6700D. I refill my carts. I have a resetter and use it every time. This time the printer won't recognize the magenta cart. I refilled it, reset it and replaced it as always. I...
If your printer did not good in times of reseting the cartridges do check the cartridge holder if the is some dirt inside or the terminal of your cartridge had wet by the ink when you refill the ink of your cartridges.
Aug 12, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
What's check M cart ( error : M cart ? ) dell 3110cn printer
Hi!
Check M cartridge is the magenta cartridge that's empty!!Replace it and you will be sorted!!
Good Luck!!
Feb 12, 2011 | Dell 3110cn Laser Printer
I have an MP830 printer and it keeps saying I have more than 1 of the magneta cartridge installed
Are you using recycled cartridges? It sounds like someone stuck the wrong chip on one of your cartridges. I suppose it's annoying, but it shouldn't hurt anything - you'll just have to check out all carts when a "magenta" cart is reported empty.
Nov 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
My printer will only print in magenta or black. It has two cartridges one black one color. I have preformed a deep cleaning and same result
Even in the test page there only magenta and black, then ink of the others colors are dried up in the cart you need change the color cart then try to print ...
Good luck...
Dec 23, 2008 | Office Equipment & Supplies
Epson C66 problem
Without the benefit of a response from any of rickyostrom, liusgarciaca, or hotdog233311, I think we can say the problem lies with the fact that your magenta cartridge isn't printing. You can confirm this by carrying out a nozzle check print.
If any of you would like further assistance in restoring your magenta to working condition, please do a new post to this effect.
Oct 29, 2008 | Epson Stylus C66 InkJet Photo Printer
Near empty Magenta
You have to press 1 (for Yes) when the display asks if you have changed the cart.
Take cart out and insert again. Watch display!
Feb 27, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printer won't print magenta
So what does the machine do: Not recognizing the cart (error: insert magenta) or does it not print onto the paper?
In 1# case: Reinsert the magenta cart and make sure that the support is secured above the cart top. If it is recognized: OK.
If not unplug mfc from power. take all carts out. Wait five minutes. Reconnect machine to power. wait until machine demands carts. reinsert cart as demanded and give the right answers (see display).
Machine should run a short cleaning cycle.
In 2# case: Insert full carts well. press menu then start mono (blue) then fourtimes arrow-up (te-index). machine will be in maintenance mode. press 7 then 6 then 4. machine will initialize the carts. after some cleaning cycles machine will be
in mentaenance mode again. Press 9 then 9 to leave mode. press ink etc. to run a test print. If it fails and you cant see any magenta, the valve or filter is clogged and cant be fixed anymore.
Nov 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
HP L7780 always reports empty magenta cartridge
Hi, The issue can be resolved by just shaking the ink cartridge slightly by holding the nob closed so that the ink mixes and then insert the cartridge back in the printer this should fix the issue... You can also power cycle the unit by unplugging the power chord and replugging it back by keeping the printer turn on and make sure that the all the cartridges are out while powercycling the unit, This will fix the issue check ..
Sep 05, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Dell 2150cn Printer Logo
24 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
