Question about Epson stylus nx110 All-In-One InkJet Printer
My epson stylus NX110 is printing blank pages
I cant print anything. When i try to print something out it doesnt print anything but one small black line about 2 inches long. when i print color it prints nothing but the color and has blank lines through the color
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
Printer heads clogged or cartridges are empty or defective.
Posted on Mar 20, 2014
ohms
  • 1879 Answers
SOURCE: epson c1100 print problem
you can try this:
remove the toner and photoconductor then tip it GENTLY from side-to-side
reseat them and print
Posted on Jan 04, 2008
  • 4 Answers
SOURCE: Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Posted on Jan 08, 2008
MerlinTech
  • 197 Answers
SOURCE: Black ink not printing...
same on a test page?
Posted on Jun 16, 2008
tigertail
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
gwbm
  • 353 Answers
SOURCE: Epson stylus C88 makes black horizontal lines on the print
This "banding" is caused by uneven ink flow through the print nozzles.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no perfect results, are you sure you have good ink cartridges properly installed? The printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the "chip" on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly. To eliminate this possibility, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old ones later if it turns out they DO have ink in them.
If none of the above works, then you may have blocked print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any black ink on the nozzle check, then there is hope! Repeat the process until you get a full black nozzle check. If nothing, repeat the process once more.
If still nothing, post a new comment detailing what you have done and the results.
Posted on Apr 08, 2009
Replaced the ink cartridge now it will not print
*** I'll be more than happy to help you on that.
there is a great possibility that the nozzles of your printer are clogged by dried inks.maybe cause by the previous inks that you just replaced. we can check that by printing a nozzle check pattern.
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX110 Series. 3. Hold down the nx110_tx110_ug.1.98.1.jpg Stop button as you press the nx110_tx110_ug.1.98.2.jpg On button to turn the Epson Stylus NX110 Series back on. When the nx110_tx110_ug.1.98.3.jpg On light begins to flash, release the nx110_tx110_ug.1.98.4.jpg Stop button. nx110_tx110_ug.1.98.5.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx110_tx110_ug.1.98.6.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Using the Control Panel 1. Load a few sheets of plain paper in the sheet feeder. 2. Make sure the Epson Stylus NX110 Series is on and the ink light is off. 3. Hold down the nx110_tx110_ug.1.99.1.jpg Stop button for three seconds to start the cleaning cycle, which lasts around one minute. The nx110_tx110_ug.1.99.2.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus NX110 Series during a cleaning cycle or you may damage it. 4. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 4 times. You can also turn off the Epson Stylus NX110 Series and wait at least 6 hours. Then try printing again.
Feb 16, 2010 | Epson Stylus NX115 All-In-One InkJet...
Printing blank pages
To mutch time the printer stopped. first check ink level, and use clean internal program
Oct 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Prints blank pages
check if there is still ink in the cartridge.also use a soft cloth and little water to clean the nozle of the cartridge.
Jul 02, 2009 | Epson Stylus C62 InkJet Printer
Gradually stopped printing, first colors, then black. New cartridges no help.
check all the catridge installed ok after finding the gatridge ok if the problem not solved , then uninstall the printer driver and restart after restarting the machine then again reinstall the printer driver properly
May 27, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus C45 not printing
common issue, the printer will still shoot blanks even if you try another ink or do several head cleanings.
i got a lot of them with that problem, but since epson prints beautiful photos, i don't mind exchanges or getting a new one.
Feb 07, 2009 | Epson Stylus C46 InkJet Printer
My Epson Stylus CX5400 won't print.
hii,
u printhead block..that why cannot ink cant not get trough from the print head..or try clean the print head using printer properties under maintenain .for informations epson print head are sensetif..
Oct 25, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Prints blank pages
make sure u have the printing options from printer settings set to black only and not colour..
Sep 09, 2008 | Epson Stylus 880 InkJet Color Printer
RX500 EPSOM STYLUS PHOTO PRINTER Won't Print
I used some less expensive generic ink cartridges on my RX500 and had a similar experience with the black. If you're already using the Epson brand, done the head cleaning, realignment and nozzel checks, I'm not much help. Try Epson's support at their web site.
Mar 25, 2007 | Epson Stylus Photo RX500 Printer
Epson stylus nx110 All-In-One InkJet Printer Logo
181 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
