Question about GE Profile PFCS1PJZSS Stainless Steel 20.8 Cu. Ft. French Door Refrigerator with Counter Depth
Refrigerator interior lights not working
The interior lights are not working. Bulbs are good and power is working.
    New Friend:
  • 41 Answers
Check the fuse and connections.
Posted on Feb 23, 2014
Frigidaire freezer, model: LFFH2067DW4. Runs constantly, 10 degrees inside, outside top and sides VERY hot to the touch, high temperature alarm will not turn off. What's the problem? Defrost timer?
I'm assuming Fahrenheit... (USA?)
If you can get down that cold... but not seize up completely in FROST your timer is MOST PROBABLY cycling correctly...
What can cause a refrigerator to work very hard... generate heat yet still fight to cool (Impressive when you think about it)...
I know this is going to sound crazy... but your INTERIOR LIGHT.
Never-mind trouble shooting... just take the light out to see if the WARM case situation improves immediately...
Else you need to give your coils a serious good cleaning
All else fails comment me back
Sep 16, 2016 | Frigidaire Freezers
Frigidaire freezer temperature alarm on but freezer is working
Good Afternoon Friend, this is Z. Thank you for your inquiry!
When your refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the alarm, you can depress the ALARM OFF button. However, if you have already done this, try once again unplugging your refrigerator or flipping the household circuit breaker. It is good to wait approximately ten minutes and then turn on your refrigerator. If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Jun 05, 2014 | Frigidaire Freezers
What type of a compressor that the sanyo SR - 36A uses? and can it work if remove a 110v compressor and replace it with a 240v compressor?
You can use a 220 volt compressor, just make sure the evaporator fan is also 220 volts as well as all of the bulbs, and anything else that is 120 volts. Everything must be 220 volts. including the start and run capicitors.
Good luck,
Marty
May 11, 2014 | Sanyo Counter Height, 3.6 Cubic....
The lights stopped working in the refrigerator. I thought both bulbs had blown and replaced them. Still no lights. Is there a fuse to replace? Not sure what's going on.
Check lights connection with thermostat for correct connection. if there is a short or arching then you will keep replacing these bulbs.
Jan 31, 2014 | GE GTS22KBPWW 21.7 Cu. Ft. White...
My refrigerator is warm but the light inside turns on and i have it set to cold, it just stopped working today
Have you unplugged the fridge sir? checked for any electrical disconnections? dust clogging your tubules in the back? Enough space between the wall and fridge in the back? sometimes these will do it. Your fridge needs air to oxygenate the tubules so that it does not overheat and not work.
Jan 07, 2014 | Danby DFF282WDB 10.0 cu. ft. Freestanding...
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
BLINKING light display on refrigerator
your internal light may be fused otherwise connecting wires are get damaged.
Mar 03, 2013 | Samsung RF217ACPN - 20 cu. ft. French Door...
J2GF-40S ColdTech display freezer merchandiser no lights come on
Sounds like a loose wire since the move. Check you have power at the switch (in and out). If you have, check the starters and ballasts
Apr 14, 2012 | Coldtech 40 cu. ft. / 1133 liter...
Fridge not cold at all.
check the adaptive deffrost control inside of the refrigerator compartment, more than likely thats bad.
Apr 05, 2009 | Freezers
GE Profile PFCS1PJZSS Stainless Steel 20.8 Cu. Ft. French Door Refrigerator with Counter Depth Logo
156 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
