Question about QSC GX5 2Channel Amplifier
The red led is on
The chanel 1 the led red is on
Samsung users manuals
TUNING MANU CHANEL SETINGS MANUAL AND 5 ON REMOCON TOO THE PLACE FOR CHANEL NO
Sep 05, 2014 | Samsung 32" Class 1080p 60Hz w/ 120CMR...
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
What is the av input chanel?
THIS IS GENARALY THE GAME MODE OR WHERE THE RED WHITE AND YELLOW WHOLES ARE YELLOW BEING THE VIDEO AND RED AND WHITE BEING THE SOUND YOU WILL USE THE INPUT BUTTON OR TV/VIDEO BUTTON TO SWITCH FROM CHANNEI 3 TO AV 1 AV2 AND SO ON
Dec 20, 2009 | Daewoo Televison & Video
The ant light and the other light light up red when i key the kic
the tx/rx liight is green when your radio is recieving signals and turns red when you are sending signals. the ANT light is red when your SWR is too high (over 3)
1. turn the knob labeled swr cal all the way counter clockwise
2. set the rf swr cal switch to the CAL position
3 key up the mic and hold it while you rotate the swr cal knob until the needle reaches the swr cal postition
4. set the swr cal rf switch to the swr position
5. key up the mic while on chanel one (record the the number)
6. switch to chanel 40 key up the mic (record the number)
if the number on chanel one is lower than the number on chanel 40 then your antenna is too long.
Sep 14, 2009 | Cobra 29 LTD CB Radio
Hi. I have an old RCA tv, model # T09081bc. I was hoping to hook up my Playstation 2, but the best result I've gotten was a black screen. I have two different cables for it, one that plugs into the cable...
After you plug the Yellow (video),Red (audio 1) and White if Stero (audio 2) turn the Playstaion on, now turn to chanel 3. does it work? if not look for selector on TV (video input,aux) or use up-dn chanels until you get playstation screen.You can also plug the round antenna cable from TV to unit and set TV to 3 or 4.Good Luck.
Sep 05, 2009 | RCA T09081 9 in. TV/VCR Combo
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Ihave a hdr1600t i want some help to record one chanel and at the same time how to record the 2nd chanel. please send us easy to understand information thank you
1. Just tune to the 2nd channel you like and press red (record) button. You'll see rec sign on top left.
Do not move to other channel.
2. Press List and scroll up and down to select the record in the list and press OK.
Aug 01, 2008 | Televison & Video
Dual xpa 4100 2/3/4 chanel amp
make sure power and ground are where they are suppose to be and speaker wires are not mixed up. but it sounds to me like the amp is junk
Jun 09, 2008 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Audio out problem (magnavox MWD200G)
yellow to yellow that is video and that is ok.
red and white are the audio chanels left and rigt try to change it and your soun will be ok
Feb 07, 2008 | Philips Magnavox MWD200G DVD Player
QSC GX5 2Channel Amplifier Logo
Top QSC Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Gil Shultz
Are you a QSC Audio Player and Recorder Expert? Answer questions, earn points and help others
