Question about Room Essentials Dresser: 6 Drawer - Maple
Need to replace roller bearing drawer slides - Room Essentials Dresser: 6 Drawer - Maple
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
Drum Bearing
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
The paper drawer is stuck on my new Samsung CLP 310
Turn the printer off. Unplug it completely. Very Carefully, roll the printer onto one side. Push the paper drawer in as far as possible, then, by grabbing the bottom of the paper drawer, and the front of the drawer with your opposing hand, slowing slide the drawer to release the pressure and slide it out at the same time. Pressure from the rollers pulling paper from the drawer will jam the paper between the drawer so tightly that the weight of the machine will act as a clamp. When your remove the weight of the machine by rolling it on it's side, you can slide the drawer out easier.
Nov 15, 2010 | Office Equipment & Supplies
I need replacement wheels for my casio t2000 cash register
I think you mean drawer rollers that help the drawer to slide open. You will need to obtain these from a Casio dealer. Look one up in your area
Aug 14, 2010 | Casio Parts Cash Register PC Desktop
The wheels are broke on the drawer and will slide
No, you don't need a new drawer. You need new drawer rollers. They are cheap. Just order them from your local dealer
Apr 16, 2010 | Casio Parts Cash Register PC Desktop
Have a frigidire FER34IACO and has a squeak when running, belt is fine. Think it is the tension roller, but not sure.
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Dec 22, 2009 | Dryers
Freezer drawer won't open or close properly. I've found ball bearings on the floor
Unfortunately if yu have ball bearings on your floor the slide assemblies are beyond repair. Replace the slides and you will be god to go. Eric
Aug 30, 2009 | LG LFX25960ST Stainless Steel French Door...
Worn seat wheels on Tunturi 202 need replacing
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
Jul 01, 2009 | Tunturi Exercise & Fitness
R205 Tunturi Rowing Machine, needs new bearing wheels under seat
Mar 31, 2009 | Exercise & Fitness
Rollers not spining on my kenmore canister vac.
Particles of the failed belt may be  trapped in the bearings which, if I remember right, aren't very well protected.
I'd remove the rollers, slide the bearings off (if they do slide off) and blow them out with a compressor or saturate them with WD-40 and turn manually until they are free again.
Jan 15, 2009 | Kenmore 22313 Bagged Canister Vacuum
Drawer beneath oven keeps falling off it's little wheels
I sympathise with your problem and sorry about your broken toe.. The drawer sits in a slide and the rollers on the drawer travel inside the track.. If your husband is reasonable handy ( or you ) ..empty the drawer and try to get the wheels into the track on the oven.. this process is similar to that used on some kuchen cabinet drawers and furniture so it is no different..just hard to see or get it started..
With the drawer out of the oven..use a flashlight and examine the track to make sure it is not damaged ( do the same thing on the mating slide/rollers of the drawer)..
If possible, can you return to the place you bought it from and have them show you how to do it? They owe you at least that much... Good luck and take care of that toe...
Sep 21, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Room Essentials Dresser: 6 Drawer - Maple Logo
67 people viewed this question
Top Room Essentials Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Room Essentials Furniture Expert? Answer questions, earn points and help others
