Question about Wagner Tools & Hardware - Others
Heat Gun repair? - Wagner Tools & Hardware - Others
Speaker wire sheath has split
There are a number of items you could use to cover (repair) the exposed wire. I agree the quickest repair would be to use electrical tape, everyone has it at home but I don't find it very durable. The easiest, most durable, waterproof, and coolest solution would be to use Bondic
Bondic The World First Liquid Plastic Welder Not Glue
I found it the other week at my Redmond's Home Hardware store and I keep finding things to use it on. It has a precise applicator and the flow of material is very controlled so it allows for very tidy repairs.
You could also use liquid electrical tape, it's messier but it will stick better than regular electrical tape
Apr 08, 2014 | X-1 x Interval 4G Waterproof Headphone...
Gun will not heat but the battery seems to be working because the light on the glue gun is on
something is probably wrong with the heating element. you can try to fix it yourself by unscrewing the plastic casing, or take it to a repair shop, or buy a new gun
Mar 06, 2011 | Crafts & Hobbies
After about 40 secs after startup the screen comes and goes and ends up diplaying grey vertical lines. The model is 1000h is about 2 and a half years old.
It sounds as your motherboard is bad. This is a common problem, where the graphic chip comes loose and some of its pins loses contact with the motherboard. The only way to deal with this issue is to replace the motherboard or do a reflow of the chip with a hot air gun. If you own a hot air gun you may do the reflow yourself. The trick is to protect the motherboard from excess heat by wrapping it with aluminum foil, and make a hole in the foil so that the graphic chip is exposed. Then, with the heat gun set to temperature of about 300-320 degrees centigrade, heat up the graphic chip for about 30 seconds while doing circular movements of the heat gun so as not to overheat one part of the chip while leaving the rest unheated. This should be enough time to melt the ball-pins and reestablish contact with the motherboard. This repair is considered an advanced procedure, so if you never did any resoldering it's best to take the motherboard to a TV repair shop and ask them to do the reflow. This should cost a fraction of a price for a new motherboard.
Jan 13, 2011 | ASUS Eee PC 1000H Laptop
How can i tell if laptop processor has died
IF LIGHTS COM ON AND BLACK SCREEN, MAY BE THE GRAPHIC CHIP IS THE PROBLEM YOU CAN FIX IT WITH A HEAT GUN http://www.youtube.com/watch?v=bnkQNmKauEc&feature=pyv&ad=5823851286&kw=video%20fix
I EVER RECOMMENDED A REPAIR SHOP TO DO IT. IF U USE TO MUCH THE HEAT GUN MOTHERBOARD WILL FRIED
Nov 25, 2010 | HP Pavilion dv61361sb (VR108UA) PC...
I just bought a new Senco Nail gun "Washer Firing Valve" Part LB3500 but can't figure how to get it into the groove. Do I need to heat it in hot water so it will "give" a little allowing me to "stretch"...
I use a heat gun similar to hair dryer and get it pretty warm. The part is pretty tough and can be forced on but better to take your time and apply heat. Good luck with your repair
Aug 28, 2010 | Senco Tools & Hardware - Others
Can I buy a new heating element for a weller 6966c heat gun?
The only possibility would be to contact weller but my experience tells me it'll most likely not be worth the cost to repair it.
Jun 24, 2010 | Weller 6966C: Ultralight Heat Gun
TRYING TO GET SOMEONE TO REPAIR A WELLER SOLDERING GUN
Try tightening the screws that hold the copper element, light corrsion can develop and make a resistance.This can cause the gun to over heat.
Dec 09, 2009 | Weller Welding Tools
Digital heat gun won't run
Maybe its only the thermal overload switch , probably faulty and giving a false reading , they are designed to protect the motor from overheating , not really sure if you can fix it yourself though you might have to get it replaced if under warranty or repaired if not too expensive
Mar 21, 2009 | Ace Hardware Ace Digital Heat Gun
CAN i USE THE HEAT GUN TO WELD VYNAL TOGETHER
You need the proper type of heat gun and the proper type of filler. It is mainly used for thicknesses over 1/4". The vinyl on a lounge would melt away from the ambient heat created by the gun.
Mar 11, 2009 | Master Appliance 650DG F MASTERMITE MASTER...
Do Not Use A Heat Gun On Your Xbox 360! Send It In To Microsoft! Find Out Why Here!
If you are looking for an Xbox 360 3 Red Lights Fix do not use any guide that suggest a heat gun fix!
Although a heat gun is used sometimes you are better sending it in to Microsoft to do the work!
If you buy any guide with the heat gun fix ask for a full refund you will need it!
If you still want to fix it yourself then click the link below and get a FREE preview of an easy 30 minute fix that does not use a heat gun:
Xbox 360 Repair
Mar 15, 2008 | Microsoft Xbox 360 Console
Tools & Hardware - Others Logo
51 people viewed this question
Top Wagner Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Wagner Tool and Hardware - Other Expert? Answer questions, earn points and help others
