Question about Xerox ColorQube 8900X
Xerox Colorqube Tray 1 paper alert.. can this be disabled?
We have quite a few ColorQube 8900s in the field and many of our end users are confused by the alert that shows "Tray 1 is empty. User intervention is required to add paper to the tray. Print service can continue if the correct paper is available in other paper trays." I realize that the last line says it all but in the interest of simplicity, I was hoping to disable the alert all together. Is there a way to disable the tray 1 paper alert through settings or through physical manipulation? My thought was that you could disable the "tray 1 sensor" -- that which tells the printer that tray 1 exists -- and it would no longer alert the user. Is anyone familiar with either fix for this?
2 Suggested Answers
  • 393 Answers
SOURCE: printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
Posted on Jun 26, 2009
HOW TO FIX ERROR CODE 094-534
Make Sure the Paper Trays Are Configured With the Correct Paper Size, Type, and Color
To configure settings for Paper Trays 1 and 2
  1. Open the paper tray.
  2. Make sure that the required paper stock is loaded in the paper tray, and that the paper edge guides are adjusted properly to fit the size of the paper.
  3. Close the paper tray. The Printer Settings screen will be displayed on the Touch Screen.
  4. Select [Size], and then select the size of paper loaded in the tray. If this is a standard size paper, the correct size will be selected automatically if the paper guides are adjusted correctly. If necessary, select [Custom] to enter the paper size if the required size is not displayed and then enter the required X and Y values.
  5. Select [Save].
  6. Select [Type], and then select the type of paper loaded in the tray.
  7. Select [Color], and then select the color of paper loaded in the tray.
  8. Select [Confirm].
Nov 11, 2016 | Xerox ColorQube 9201P
Xerox 8570 tray2 issue pickarm stuck
the problem of your machine is mechanical you must change your gears found on your machine.
Sep 06, 2016 | Xerox Corporation Xerox ColorQube 8570DT...
What is Xerox 8570 ColorQube error 93 984.00:3683
93,984 means: Cyan obstructed, reservoir not filled
• Check for ink spills around the Printhead.
• Check the Ink Loader for bent melt tips.
• Check the Ink Loader power cable misrouting around melt tips.
• Check height of ink levels in the head reservoir.
Mar 15, 2015 | Xerox Office Equipment & Supplies
Reset maintenance kit on a xerox colorqube 8570?
There is no "reset", except to replace the Maintenance Kit. That will reset the life back to 100%
Apr 10, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
If it's brand new send it back to the store. It seems to be a faulty item, which would be covered under the manufacturer's warranty/
Apr 18, 2013 | Xerox ColorQube 9303 Printer
Does not detect tray
Look inside the machine, down the back of the paper tray, can you see any sensors that could detect if the tray has been installed.
Has there been any external damage to your paper tray, does the paper lift when you turn the paper lift gear by hand.
Try those points first.
Good Luck.
Jan 16, 2013 | Xerox Corporation COLORQUBE INK MAGN...
Xerox ColorQube 8900X Logo
165 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
