Question about HP DeskJet 5150 InkJet Printer
HP DeskJet F2400 InkJet Printer reset ink level
aicaxz
  • 511 Answers
SOURCE: I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
Posted on May 31, 2009
bob_computer
  • 3153 Answers
SOURCE: How do I reset the ink levels on a HP Deskjet
First try the information below
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
Posted on Sep 07, 2009
cns assoc
  • 677 Answers
SOURCE: how do I check ink levels on my HP deskjet D4160
Here is what I found on the Web. You can click on the link below, to see Full Instructions. If you find this helpful, pls rate me.
http://h10032.www1.hp.com/ctg/Manual/c00687555.pdf
View estimated ink levels
Follow these instructions to view the estimated ink levels of the print cartridges that are installed in the printer:
1. Open the printer Toolbox.
2. Click the Estimated Ink Level tab.
Note If the print cartridges were used before being installed in the printer, the
estimated ink levels will not appear on the Estimated Ink Level tab.
The Estimated Ink Level tab also contains print cartridge ordering information. To view
this information, click the Print Cartridge Information button.
Thanks and good luck.......
Pls rate me
Posted on Jan 01, 2010
SOURCE: I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
Posted on Jan 28, 2010
SOURCE: Deskjet f4185 reset ink level...
for colored is only 3ml and the black is 8ml
Posted on Apr 28, 2010
There is no icon on the taskbar, and I cannot figure out how to check the ink level.
The HP Toolbox can be used to check ink Levels
  1. Right-click the taskbar printer icon .
  2. Click Open HP Deskjet 5550 Series Toolbox .
  3. Click the Estimated Ink Level tab.
  4. Check ink levels (estimate only, actual ink levels may vary)
Sep 23, 2010 | HP DeskJet 5550 InkJet Printer
Hii need to reset the hp deskjet 680c printer.i don`t know how to do this. thanks for you attention. regards.
h10032.www1.hp.com/ctg/Manual/c00256077.pdf -
Above is your user manual.
Turn off your HP DeskJet printer. Turn it back on and connect it to your computer using the USB cable.
To reset the INK Counter, see below.
Click open the "Start" menu on your computer. Click on "Control Panel," and double-click "Printer and Faxes."
Locate the icon of your HP DeskJet Printer along with its model number. Right-click this icon and click on "Properties" from the pop-up list.
Click the "Services" tab and select "Service This Device."
Select the "Estimated Ink Level" tab. Click the option "Reset Ink Level." The printer will then show a refreshed ink cartridge level for your printer.
To reset all settings and print test page. see below.
* Press and hold the Power button.
* While holding the Power button, press and release the Resume button four (4) times.
* Release the Power button. A self-test page will print.
Jun 17, 2010 | HP DeskJet 680c InkJet Printer
DeskJet 960c InkJet Printer: where do i find my ink level for hpdeskjet 960c?...
us the utility to choose tools, service my printer, and click the tab with the ink levels on it.
May 16, 2010 | HP DeskJet 960c InkJet Printer
Ink level didn't change
s.gif Deskjet 5100 series
  1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
  2. Click Utilities .
  3. Click View ink levels .
    • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
    • If the cartridges contain a sufficient amount of ink, continue to the next step.
  4. Click Printer Maintenance .
  5. Click Clean Cartridges .
  6. Follow the on-screen instructions.
ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
May 29, 2009 | HP Photosmart D5160 InkJet Printer
May 28, 2009 | HP DeskJet D1460 InkJet Printer
Printer says out of ink, won't print
Greetings,
Try this In service mode.
Put Stop/reset 4 times orange => reset waste ink.
Put stop/reset 8 times orange => set level ink.
This isn't set level but it disable ink check. The LED warning still blink but no error code appear anymore.
Regards,
TechSup1
Apr 30, 2009 | HP Deskjet 5940 Photo InkJet Printer
Can't find ink levels for my HP Deskjet 5940
The installation disk for your printer has a setup wizard that monitors your ink levels in your printer. Go through the installation again as it will not hurt anything and you should find it on one of your pop up screens that it leads you to.
Jan 14, 2009 | HP Deskjet 5940 Photo InkJet Printer
I have a new HP Deskjet F4280 bought 3 weeks ago & the blank ink cartridge was empty & I refilled it in a store & placed it back but printer recognise that the cartridge is empty & it does not have a chip.
You cannot reset the ink level for the HP 60 ink cartridge. Simply ignore the ink level indicator if you refill your cartridges. It is only an estimate of the ink level anyway. See pg 72 of the user manual.
Jan 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Aug 03, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
220 people viewed this question
Seeker5211
Seeker5211
