Question about Coby Tfdvd3299 32" Lcd Hdtv/dvd Combination
No power getting to it won't come on - Coby Tfdvd3299 32" Lcd Hdtv/dvd Combination
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
My asb light comes on when starting and stays on. Lights won't come on , power locks won't work, power windows won't work, radio won't work. All fuses are good and car runs fine.
Those are all really common symptoms of the alternator going bad on those cars. I would have it checked to make sure it's charging properly.
Dec 15, 2012 | 1996 Oldsmobile Cutlass Ciera
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
My plymouth breeze won't start, won't make a sound, but my lights and horn still works , help me.
any real answer yet? did the problem ever get resolved? i have the same problem with my sister's car. too cold to diagnose tonight, but will post the solution probably tomorrow. since the lights and heater works, but ignition and radio arent getting power, my first guess is there's probably a fried fusible link which controls the 2nd accessory power to the ignition switch. will post a solution soon.
Jul 17, 2012 | 1999 Plymouth Breeze
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
1990 Accord electric windows won't close
If you own a Honda Accord, you know they rarely give any trouble. ... My 1995 Honda Accord Window Won't Close ... are a bundle of complicated electronics, lots of wiring and more computing power than the average computer from 1990. That ...
http://www.ehow.com/how_4520901_fix-power-windows-honda-accord.html
Read more: 1990 honda accord electric windows won't close ' eHow.com http://www.ehow.com/search.html?s=1990+honda+accord+electric+windows+won%27t+close+&skin=corporate&t=all#ixzz1kZmevV9g
Jan 26, 2012 | 1990 Honda Accord
Truck wont crank. we have put new distributor cap, rotor button, coil pack, plugs, wires, and fuel pump. we also checked our firing order.
you said you repl dist cap that means you don't have a crank sensor you have electronic ing module. remove your elec ing module have it tested most auto parts stores could test your module, or check your coil at the neg terminal. should have power. if not you lost your primary volt from your batt.your secondary power is coming from your electronic ing module from the module to the pos terminal on the coil, when the eng cranks,from the coil to the dist cap , from the dist cap center to the rotor then out to the plugs,this all happen pervided the timing belt or timing chain is ok. the cumbustion chainber needs 3 things , thats fuel, air, and spark.
Apr 17, 2011 | 1996 Chevrolet K1500
1997 pontiac grand prix key won t turn ignition
well does the key go in does it turn to the start pos? if the dash dost power up its because the switch is bad if it will power up but not start it can be becuse of the resitor chip depends on what is going on if you cant get power its becuse of the switch
May 06, 2010 | 1997 Pontiac Grand Prix
Motor turns over but won,t start, i'm not getting
check the fuses and ralays, check to see if your getting 12v from the battery
Jul 19, 2009 | 1995 Chevrolet C1500
Coby Tfdvd3299 32" Lcd Hdtv/dvd Combination Logo
14 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
