How to load staples in a bostitch model b5 stapler
SOURCE: LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Posted on Dec 07, 2008
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
  • 40 Answers
SOURCE: Nothing happens when you load paper to staple.
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
  • 6 Answers
SOURCE: Where can I download a manual for Bostitch T5 Staple Gun
If you want to know how to load the staples, lift the wee flap at the end with the inscription " lift to insert staples".....
Posted on Feb 01, 2010
  • 34 Answers
SOURCE: how to remove staples from bostitch T5 model
Lift the hinged guard on the front of the stapler and while open use a pencil or similar object to depress the striker (above the staples). This will release the spring catch and the staples will move forward. Use caution and catch the staples as they come out under spring pressure.
Posted on Aug 07, 2010
Open and load staples b660
Hold on to the chrome part near where the staples come out and lift up on the top plastic part. There is a video link on the Bostitch site to the right midway down the page
Stanley Bostitch No Jam Premium Stapler B660 Black
Feb 08, 2015 | Stanley Bostitch B660-BK: NoJam Full Strip...
How do i load the Stanley Bostitch 00540
Hi Diane,
If you look at the back of the stapler, there's a bright red button. Push this in and slightly lift up at the same time, then magazine is withdrawn. Feed a strip of staples in and replace the pusher unit.
Bostitchtools co uk Bostitch Nailers Staplers Fasteners Coil Nails Staples
Jan 29, 2015 | Stanley Bostitch 00540: 00540 AntiJam ?...
How do I refill the stapler model #02210 with new staples?
I have a similar model. When you push the button on top, the "drawer" pops out. Pull the drawer out until it is fully extended and you will be able to load staples. When you fave finished loading staples, push the drawer in until it latches.
Nov 02, 2014 | Stanley Bostitch 02210 Electric Stapler...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
I HAVE A BOSTITCH NARROW CROWN AIR STAPLER AND THE STAPLES ARE NOT GOING FOREWARD FOR THE ROD TO DRIVE THEM IN. IS THERE SUPPOSED TO BE A SPRING BEHIND THE STAPLES TO MOVE THEM FOREWARD. PLUNGER COMES...
There is a spring to push the staples into place. Bostitch was purchased by Dewalt and moved their parts lists to the web address below. Enter your model number and order the parts needed. Good luck with your future projects.
http://servicenet.bostitch.com/
Sep 02, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
140 people viewed this question
jasbo
jasbo
