Question about HP Computers & Internet
Audio fades as soon as I start using the keyboard.especially if i have to use the shift key
  • 62 Answers
Sounds like there maybe a key that is stuck down or something. I looked up hot keys to see what button it may be, but I have no idea here is what I was looking at Windows 8 Accessibility Options
Try cleaning out your keyboard. maybe something sticky got in it.
Posted on Feb 11, 2014
Fn key
the "Fn" key is used as a function to enable other keys on the keyboard. Hold down the "Fn" key and then use the other keys with faded or other colour features on them such as volume buttons. As you would with using the "shift" key to produce CApItaL LetTErs
Apr 24, 2013 | Toshiba Computers & Internet
What is "FN" key
Most laptop keyboards have a key marked "FN" or "fn". This is just another shift key, like the shift, control, and alt keys. If the instructions say something like "Press fn+F1" then press and hold the fn key, press and release the F1 key, then release the fn key. Exactly the same type of procedure as when the instructions say something like "Press Control+P".
Mar 19, 2013 | Computers & Internet
My upper case S KEY WILLL only work if I have cap locks on. can you help me? ' Im using the MX5500 keyboard. thank you. Greg
Have you tried cleaning the keyboard, especially blowing it out with compressed air. Have you tried to use both shift button to see whether or not the problem is isolated to one shift button or both.Have you tried other letter with the same shift button that the letter "s" is having problems with. If this is islolated to just the letter "s" with the shift buttons then more than likely you will just have to use caps lock or buy another keyboard.
Nov 18, 2010 | Logitech MX5500 Keyboard/Mouse
Both of my shift keys stick in the "up" position,
Hi Brown551967,
Its the dust & dirt in the keyboard problem. If you have a powerful vacuum cleaner, try cleaning your keyboard with that. But before that use a long bristled brush between the keys to loosen out any stubborn dust particles. Concentrate more on the affected keys. If this helps the fine else you might need to disassemble the keyboard and do a thorough cleaning. Please DON'T try it if you're not confident of doing it. Just cleaning it thoroughly will do the job.
Hope this solves your problem.
Nov 06, 2010 | Sakar 62150 Keyboard
Can't type: hello folks... my Dell 630m won't let me type or click unless I am holding the shift key. When I turn it on the machine makes a beeping noise (sometimes one beep, sometimes 20 ) before Ubuntu...
Sounds like a bad keyboard.
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Sep 20, 2010 | Dell Inspiron 630M Notebook
The Shift Lock is stuck in the CAPS position. When I turn it off it goes off CAPS but as soon as I hit the shift lock for caps which I need to do, I can't get it back to where I can type numbers, which I...
Sounds like the shift key isn't entering. Try both shift keys and see if one will turn the light off. If so tou need a keyboard rebuild. It may be cheaper to replace it.
DickyO
Aug 16, 2010 | Brother EM-530 Typewriter
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
Dell inspiron1521 bios reset
It seems that you wish to load bios defaults on your system.
You can try the steps below for the same.
1.Turn the system off.
2.Turn it back on and as soon as you turn it on start tapping the F2 key along the top of the keyboard once every 2 seconds (especially when you see Dell logo on the screen).
3. This will lead you to system bios. Go to “mainteinence”, using the down arrow key on your keyboard and hit enter.
4. Go to “Load defaults” and hit enter. Highlight continue and press enter.
5. Exit by just pressing the escape key on the keyboard (please do not forget to save the changes before you exit).
Please do not forget to rate the solution.
Regards,
Musheer.
Jun 08, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
Keyboard locked in upper case
Try reseating the key board.
Check whether the keys are stuck especially the shift,alt,caps lock.
Hav you spilled any liquid on the keyboad.
Try uninstalling any software you installed for the keyboard and remove it from Device Manager (Click Start-Run-Type devmgmt.msc and click OK).
Reboot and see if that helps anything. Also, check the right shift and make sure it isn't stuck and check the keyboard settings in the Control Panel
Update the keyboad software from the microsoft website.
Pleae mntion the model  number of the keyboard to help us know more about the keyboard.
You can try holding down function key and press f11.
Control Panel -> Regional and language settings -> Tab: Languages,
Button: Details, and add a US Keyboard.
Check this to know the functions
http://support.microsoft.com/default.aspx?scid=kb%3ben-us%3b894513
Check the keyboard settings.
Try using other keyboard to know the keyboard is fine or not.
This will help you i hope.
Good Luck.
Live, Love, Laugh.
May 06, 2008 | Microsoft Windows XP Home Edition
30 seconds down the road and no bass and lot of smoke
Well, it burned up. Too much power.
It is repairable, however, that is not covered by any warranty.
Oct 19, 2006 | MA Audio HK2000D Car Audio Amplifier
Computers & Internet Logo
23 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
