Question about Video Game Consoles & Games
Digram for a 1994 honda accord fuse box is it inside the hood my wind shield stop running and you can still hear the motor running do you thank its a fuse problem or a moor problem
  • 740 Answers
SOURCE: fuse box diagram 98 honda civic
Get a fuse tester you don't have to pull every fuse to check
Posted on Dec 19, 2008
Fleetw00d
  • 31 Answers
SOURCE: windsheld wiper motor fuse? for 93 accord
10 amp fuse No. 5, middle of the 2nd row from the bottom in the under dash fuse box.
Posted on Jan 27, 2009
dr_greg
  • 192 Answers
SOURCE: How do I open the fuse box under the hood? Are there any other fuse boxes?
theres 3, one under the hood, 2 inside the vehicle ..the interior fuse boxes are on the sides of the dashboard on both drivers and passenger sides. open the doors and look for the removable panels on the dash between the drivers and passengers dashboard.remove the panel....u will see the 2 interior fuse boxes...these 2 interior fuse boxes house the vehicles multiplex control units..
Posted on Apr 16, 2009
  • 164 Answers
SOURCE: cant find fuse box to change the radio fuse
check below your stering wheel ore on the passanger side for box also hanes books help you on this
Posted on Jul 21, 2009
  • 1619 Answers
SOURCE: I have a 1994 Mercedes E320. My blower fan doesn't work.
The "strip" fuse is in a tootsie roll sized black container on the drivers side strut mount. pop it open and there it is. 2 philips screws hold it in place. Breaks in the fuse are not easy to see.
Posted on May 26, 2010
Where is the main fuse box of signal lights and stop lights of a 1991 honda accord 4 cilinder.
HI. This vehicle contains a under the hood relay box near the front corner of the battery(which is labeled if not deteriorated), and there is also a fuse container box located below the left side of the instrument panel, as well(inside the vehicle on driver side).
The under-hood fuse box generally contains fuses and relays for engine and major electrical systems such as air conditioning, headlights (left and right respectively), fuel injection components, etc. The in-car fuse-box holds fuses for the cabin circuits such as wipers, cigarette lighter, rear defogger, signal lights etc.
Under hood Relay box:
Inside/Driver side panel:
Oct 30, 2011 | 1991 Honda Accord
Wind shield motor was good but replaced think a bad fuse fuse guide in car is no help need fuse # car is 2003 bmw xi
Hello, check under the engine hood. There could be a couple of black boxes with lids on them. Inside of these boxes are some fuses and relays. Under the lids of these boxes will be description of what fuses and relays are located in the box. Also, look around and see if you can locate the wind shield wipers electric plugs. Check this plug for corrosion, if it is corroded then clean the contact and use some dielectric grease on this plug. GB...stewbison
Sep 22, 2011 | BMW 325 Cars & Trucks
Have a 1994 honda accord, no heater blower motor inside of the car and no cooling fan motor at radiator . Are they tied together by a relay or fuse? Why do they not work?
I think there is a fuse box under the hood and also under the dash. Check the fuses.
Make sure you get the cooling fan motor at the radiator fixed asap! I had a 94 accord and didn't know that one of the 2 motors went out. When the second one went out my transmission fried. Very costly!
Mar 22, 2011 | 1994 Honda Accord
1991 honda accord EX - windshield wipers stopped working during my morning commute. I can hear the motor trying to work when I turn them on, but they won't move. I can see one fuse box under the hood of...
Here is a diagram of the fuse box in the interior. This is where the wiper relay is located, #6. Although if you hear sounds from the motor something might be restricting your blades and or the motor is shot and needs to be replaced.
Mar 14, 2011 | 1991 Honda Accord
Wind shield wipers not working
The wind shield wipers not working could mean either the wiper motor is faulty or the fuse, relay or switch in the steering column is faulty.
You will need an auto electrician to have a look.
Feb 12, 2011 | 1994 Honda Accord
Wind shield wipers stop have way up The wipers are on the wind shield it just stops in the middle but you can still hear the motor running
Under the bottom of the outside windshield you will see a grate with slots that let you look down inside. One of the arms connected to the wiper motor must have come loose. Might be as simple as a clip keeping the arm on slipped off and then the arm too. There should be screws to remove the grating in view either if you lift the hood and look on the firewall or even on top on the corners of the grating. You can take that off and get into the wiper motor area. Let me know if this helped and ppppplease leave me a good thumbs up for the effort. I need to keep my score up. Thanks, The Raz Shack
Apr 21, 2010 | 1997 Ford Windstar
Where is wind shield wiper fuse
Interior fuse box. Fuse number 9 (30A) WIPER, WASHER
Hope this helps you find it.
Dec 02, 2009 | 1996 Honda Accord
My wind shield whippers do not work, whats wrong with it?
Chech the Fuses, wiper motor, and on/off switch (all need to be checked out) on/off swith can wear thin and no longer make contact inside the switch and wiper blades need to be in good working condition. Refer to you owners manual in the glove box for info on fuses, their relations to other systems and locations in the fuse box.
Oct 13, 2009 | 1995 Honda Accord
Trying to find fuse for wind shield wiper
look in fuse box under the hood
Jun 04, 2009 | 1996 Honda Accord
Car won't start
Have you checked your starter? You should take it out and take it to Kragen and have them do a electrical test on it. It is free and they will be able to tell you if that is the problem
Feb 06, 2009 | 1992 Honda Accord
Video Game Consoles & Games Logo
67 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
