Question about Radio Communications
Cant pair my bluenext h&h-006 to htc phone - Radio Communications
4 Suggested Answers
carrese04
  • 92 Answers
SOURCE: i cant pair my samsung wep460 to my htc touch.the
make sure that your bluetooth headset is charged and it is on while pairing
Posted on Jan 10, 2010
  • 638 Answers
SOURCE: I cant get my JABRA bluetooth headset to pair with
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Posted on Jul 30, 2010
SOURCE: i cant pair my headset with my new phone htc .lost
If your new phone cannot find you hedset the easiest solution is to hold the button volumen when the bluetooth in your phone is activated. After that phone should to find your headset
Posted on Dec 11, 2011
Cant pair htc one m8 to play music
Be aware most phones need other connection for a wireless (bluetooth) head phone for music as they need for a headset with microphone, to make calls. The phone will use different protocols, what works for the one, will not work for the other.
Feb 27, 2015 | HTC Cell Phones
Why I can't bluetooth pair with veho VSS-006-360
Hope it helps.
Power off your N8.
Remove battery from your N8 and reinsert again and then power it back on.
Activate Bluetooth settings and program it to become discoverable
Power off your bluetooth speaker
Remove battery from your Bluetooth speaker and reinsert.
Power it on again
Allow the pairing to proceed for both devices. Check and confirm/test whether operational
Oct 17, 2017 | Veho Audio Players & Recorders
Cant pair my htc wildfire smart phone to my parrot v5 10c
My boss has one I think the password is 0000 that's how I paired his. He had he same problem a while back and that's what got it working
Apr 19, 2012 | HTC Wildfire S Smartphone
Just brought a HTC wildfire and I cant find bluetooth to turn it on .
Bell;
Important:
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so HTC Wildfire S can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press howtoimage.aspx?id=106492, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. HTC Wildfire S will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. HTC Wildfire S then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to HTC Wildfire S, the Bluetooth connected icon howtoimage.aspx?id=106796 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Mar 28, 2012 | HTC Wildfire Cell Phone
Av always found it difficult pairing my htc hd7 bluetooth with other htc smartphones & other devices
The only thing that you can pair a WP7 handset to is a headset, everything else is not supported, hence your problem! There is no fix as this is not a fault but a feature and we are not sure yet whether this feature will be included in further updates. Thanks
Dec 30, 2010 | HTC HD2 Smartphone
I cant pair my samsung wep460 to my htc touch.the phone cant search my bluetooth
Jan 10, 2010 | Samsung WEP460 Bluetooth Headset
My htc hero pairs but then says paired but not connected. It cannot then be found so i cant send or receive any thing through bluetooth also the phone dosen't connect wirelessly 2 my livebox (orange...
The Hero has a rather crippled Bluetooth which is one of the reasons I'm sending mine back.
For security, when you set the phone to be discoverable it only stays that way for 90 seconds. This cannot be altered unless someone works out how to bypass it with an app but I understand from HTC that this feature is built in at the firmware level.
Look down at the devices list in the Bluetooth menu and you'll see what's paired with the phone; press menu and you'll have the option to connect.
Bluetooth on this phone cannot be used for file transfers of any kind. It's only there to enable connection of devices like headsets and external keyboards and that's about it. You can't even take a photo and Bluetooth it to another phone. There is no way around this at present.
Not connected with your question, but have you discovered the annoyingly expensive and non-alterable trick which it does when you want to send/forward long SMS messages yet?
Oct 07, 2009 | HTC Hero Smartphone
Bluetooth Handsfree headset not clear.
You can tweak the bluetooth to give best results from the bluetooth option. But by doing this your battery charge will fireup very fast... :-)
Jul 11, 2009 | HTC Touch Viva Cell Phone
I have bought a bluetooth headset but I have no idea how to connect it to my phone (Nokia 6131). The make is Bluenext Bluetooth Wireless Headset HH-006. The only thing I can find on my nokia is 'Search for...
Press the MFB button on the bluetooth headset for about 8 seconds until the blue and red light flash together.
Please note, after pressing MFB button for about 5 seconds, the blue light flashes. Do not release the button and keep pressing until the blue and
red light flash together, which indicates that the headset is now in paring mode.
You will then do the search from your headset. You may be prompted for a passkey, it should be 0000
For the manual to your headset go to http://res.bluenext.co.uk/download/HH006.pdf
Apr 20, 2009 | Nokia 6131 Cellular Phone
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
