Question about Emerson NR303TT CD Shelf System
Cd doesn't read the cd
I can hear the cd spin, but it will not read the cd.
  • 31 Answers
Are these store-bought CD's, or ones that somebody made for you?
If the latter, they might not have finalized the session, which is why they're not reading.
When is the last time you cleaned your CD player with a lens cleaner?
If you can't recall, then perhaps now is a good time to do just that.
Best of luck!
Posted on Apr 07, 2014
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
I have a dvd player built into my tv and until a few weeks ago worked fine. Now when I put a dvd in it tries reading it, i can hear it spin, then after a few minutes stops and says "incorrect...
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jul 11, 2011 | Sharp Televison & Video
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
I am trying get to firmware for my samsung sc- 140b. My cdrom can't read a cdrom and. i can't hear nothing.
If you insert a disk, and you don't hear it "spin" the disk, then the motor that spins the disks has FAILED. Replace the CD-ROM drive -- it's less expensive than paying a technician to try to repair it.
Feb 26, 2011 | Computers & Internet
The cd gets ejected without being read.
As long as it does that on more than 1 disc, it can be a couple of things. The lid has to be taken off so you can see and listen to what is happening. #1 If it takes it all the way in and spins the disc, it most likely cannot read the disc usually because the laser lens needs to be cleaned or the laser is defective. You will hear the lens going up and down, making a clicking noise over and over and then it ejects it. #2 If it cannot load it all the way in and does not even spin the disc, it is usually a rubber loading belt is slipping and needs to be cleaned or replaced. You will hear the motor running and running without taking the disc all the way in. It will never spin the disc, then eject it. Other things can cause it also but those 2 are the first things to look at. :)
May 19, 2010 | Audio Players & Recorders
Yamaha dvr-s120 can not read dvd or cd. Drive is not spinning.
The CD motor could be faulty if you cannot hear any spinning noises from it from it loading or the lens could be faulty resulting in not enabling the dvd to register its prescence in the player to spin the disk.
Nov 04, 2009 | Yamaha DVR-S120 DVD Player
Wont read any disc
The problem is quite common.
When your console does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the PS start losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the PS, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
before doing tis, contact Sony to check if the unit can be replaced or repaired by Sony, you find the number on the Console documentation.
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
Cd/dvd drive on my Dell latitude D810 will not read
Try to clean the laser within the dvd drive with a soft material. If this doesn`t work, try to hear if the cd or dvd is rotating in the drive. If not, the drive should be repaired b specialists.
Jul 29, 2009 | Computers & Internet
Prism DVD-352P not loading any disks
What you are hearing is the attempt to read the disk. The unti detects that a disc is present and attempts to read it by spinning it first at CD speeds then at DVD speeds. It will attempt this a number of times before giving up and reporting "no disc". If you can get at the optics, try cleaning the lens using a cotton swab and alcohol. Next try to read a CD. If you can read a music CD and not a DVD, it indicates that the optics are starting to fail and need to be replaced.
Dan
Dec 18, 2008 | Televison & Video
B&o sound system not working
try buying an ordinary cd lense cleaning (CD), if you are brave you can try adjustind the pick up of the laser on the laser board pot inside the cd player. it might just need a service
Nov 27, 2007 | Bang and Olufsen Beosound 2000 Shelf...
Emerson NR303TT CD Shelf System Logo
103 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
