Question about Denon Audio Players & Recorders
Denon d60 disc tray
The disc tray is stuck. I've opened the unit and can see the components that are malfunctioning, a plastic piece and metal piece that get caught on one another, but have no idea how to fix them. It is an old unit, but precious. Any help woul dbe greatly appreciated
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 161 Answers
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
Try spraying with electronic cleaner denon d60 disc tray - b3203b06-4ced-4fda-befd-44f385f97b7e.jpg this stuff is great for lots of different electrical cleaning problems. it may help lubricate the mechanical components and allow them to move more freely
Good luck
Posted on Feb 11, 2014
4 Suggested Answers
  • 119 Answers
SOURCE: Denon AVR-587 Television input stopped - no sound
try plugging another device into the tv input and mank sure you have the input mode is set to auto if you still have no sound those inputs are gone
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-587&imageField.x=106&imageField.y=8
Posted on Feb 25, 2009
SOURCE: Placed a CD in tray
Straighten up a paper clip and use the sharp pointed edge to push a tiny hole located next to the tray that mounts your discs. This is your emergency eject button.The disc tray should open immediately when you push this emergency button.
Posted on Feb 25, 2011
alpug
  • 1961 Answers
SOURCE: Denon Precision Audio Component AM-FM
The display of your reciever is controlled by a small processor IC it is mounted right at the back of the display.there are several reason why the display blacks out.
1.loose connector of voltage supply to the display board- open the cover and check the connectors from the main board to the face panel re set connectors and make sure it fits the terminal properly.
2.back light bulb are busted-just replace the bulb.
3.the display processor IC is bad--replace the IC..use IC replacement with the same part number.
Posted on Jul 04, 2011
Denon dvm-1815 changer drawer won't open. Stuck.
Hello
There is a belt that drives the chager tray. It is engaged with its loading motor pully and gear set that drives the tray mechnism. To replace the belt, you have to disassemble the mechanism. Actually it is a skilled work, and without knowing its disassembly method, it is almost impossible to repalce the belt by yourself. I've the dissasambly and reassembly method, described wiht help of pictures and all other details. If you have an interest to get it, you have to buy one amoung my audio services, advertised in Fixya site. Unlike previous Fixya site, this new site is different. With old site, I've the facility to send you pictures and PDF files, but with the new, I can't send any of such documents to you.
The document I've with me is an original published by Denon, Japan.
If you want to do this work by yourself, and want to get this document, do the needy. OK.
Nov 23, 2011 | Denon DVM-1815 Multi-disc DVD Player
A DVD is stuck in the player and the door will not open, it makes a grinding noise when you try to open it.
well looks like the disc is lodged into the track thats why you cant open it, the grinding noise is the track slipping on the motor gears as it forces to attempt to open and fails..
what we need to do is open this up and remove the disc manually..
  1. unplug the device (dont wanna get electrocuted)
  2. remove the screws to the back and under the player
  3. lift the cover off by sliding it back then raising it up , prying with a bladed screw driver helps.
  4. you will now see the disc stuck under this metal / plastic piece if you can see the disc at all.
  5. remove the screws holding the disc tray top in place. remove the disc and reassemble.
that should solve the problem, let me know how it turns out of if you need more help if you ran into a tight spot.
Apr 05, 2011 | Oritron Televison & Video
I bought the cd changer with my unit & two cds are stuck in it. This happened the third time I used the unit.
this is a mechanism problem. Also, maybe something might have hooked the cd tray and made it stuck.
What you have to do now is to open the player by unscrewing the cover, so that you can gain access to the mechanism inside the player.
After you must have opened the cover, plug the cd changer to light, power it on and use you hand to pull out the tray while you press open button.
Also make observations on the disc tray while you press the open button and check the disc tray and look for what is making it stuck and refuse to open. This is why you need use your hand to support the disc tray by pushing it open from the inside.
I wish you good luck.
Feb 25, 2010 | Bose Wave Radio
CANNOT REMOVE DISC GAME STUCK IN PLAYER UNABLE TO REMOVE DISC FROM PLAYER
open up your ps3 you tray might have broke or the game is stuck up to where it wont let you open it.
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
I have a denon 3500 cd player my cd is stuck
Open the top cover of your CD using a screw driver, (usually a star screw driver),. Then, manually turn the driving gear of the CD tray to free the stucked tray and until to the point where you can take the disc from the tray. Be careful so the setting of the tray and the laser eye is not change. Then, close the close the cover and play. You can send your e-mail thru fix ya to let me know.
Sep 25, 2009 | Sony CDP-C910 10-Disc CD Changer
Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
Ice Maker does not work
My husband repaired our ice maker after our repairman failed to show to replace the entire unit. He removed the front panel and then the next panel fastened by 2 screws. A white plastic piece can be seen as the ice exits the unit, which is poorly designed and literally gets stuck to the left. He slid the piece to the right and vuala! It works. He is looking for a rubber piece or something that will keep the piece pushed to the right, as it seems due to the poor design that this type of malfunction will happen again... good luck!
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Just need to get disc out...
Looking at the front, flip the unit over. Near the top middle you will see a narrow ****.You will see a white piece of plastic under the ****. If you have a dvd tray pinhole tool, use the bent end and insert it into the **** and use it to push the plastic piece to the left and if you push it far enough, the tray should open. I also used a very small screwdriver at an angle to open the tray.
Dec 25, 2008 | Philips DVP642 DVD Player
CD tray not opening on Denon RCD-M35DAB
there are tthere are two transparent plastic switches under the tray
there (a gray plastic piece, intcasing the loading motor is nonot rotated enough, not allowing the necessry pressure on the switch.
you must in either case disassemble the reading module comprising the tray, otics annd spindle, so you gain access to the underside of it, from ence coperatrepositioning the tray or the lrotating the trigger\eloading motor.
May 14, 2008 | Audio Players & Recorders
Sony DVP-NC85H Multi-disc DVD Tray locked
Look on the bottom of the unit. There is a hole with the letters ex and op. Shine a light in the hole and you will see a white plastic object with a slot for a slot screwdriver. You can turn this either way but be careful. If you feel resistance and the object does not turn, turn the other direction and the unit will open. Remember if the disc loaded the clamping of the disc is in place so you must turn it the proper way to let the current disc loose hence the op and the ex. Op is open. Ex is exchange.
JC
Nov 23, 2007 | Sony DVP-NC85H Multi-disc DVD Player
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
