Question about Lisle 91000 LISLE DRILL GRINDER U.S.A
Need parts for lisle 91000 drill grinder - Lisle 91000 LISLE DRILL GRINDER U.S.A
Brushes for drillmaster grinder
looking for carbon brushes for a drill master model#69079
Jun 09, 2012 | Master Heaters Drill Master 412" Angle...
I want to use flap disc's on my grinder with out the threaded portion attached. What do I have to do to install them on the grinder.
flap discs can be used on a grinder the same as grinding disc and cut off wheels . You may need a centre adaptor as some flap discs are larger in the centre hole
Aug 31, 2011 | Dewalt D28402 412" (115mm) Small Angle...
Beans do not feed anymore. I have to shake the grinder to get them to feed.
- it is happening from time to time at all brands, you need to:
  1. remove upper burr holder
  2. unscrew lower burr holder bolt
  3. go with bolt in some metal workshop and ask for one peace of drill above bolt to be attached
  4. explain the way of rotation of burrs to metal workshop master so he wont mistake to do the drill in opposite way
  5. come with drill attached bolt at home , clean good the grinder, assemble the drill attached bolt.
  6. assemble upper holder and the plastic bean container (inspect does the drill touch the tongue for closing the beans at bean container)
Feb 12, 2011 | La Pavoni Coffee Makers & Espresso...
When grinding coffee beans the grinder is not dropping the beans into the grinder part. I have to stay and shake or bang the grinder on counter to get the beans to fall through.
you must screw off the burr holder plate screw (in center) you will order one special screw, drill shaped, when the burrs roll it will mix and take down the coffee beans. That is solution i applied to many grinders. PS: beware the direction of burrs must be coordinated with new screw.
Feb 07, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
Need parts for the lisle 91000 grinder
I need the drill bit holding assy. And a dressing tool assy.
Sep 15, 2010 | Lisle 91000 LISLE DRILL GRINDER U.S.A
Schematic diagram of kango breaker 900x
The 900 is a hammer only, the 950 is a hammer drill. the newer ones 950s used spline bits. Unfortunately new parts are no longer available for these great machines. What is your problem.
May 20, 2010 | Hobby Drill
I need to find a manual for the makita 18v lxt angle grinder. my problem being that when i put the battery on the lights flash up red and during use the lights do not work at all. please help.
Hi, Don't stress, its working fine. The grinder has a sort of self test when you put the battery in, it blinks. What you don't want is the light to come on when you are using it. That means that you are bogging it down and if on for 30 seconds ( if I remember right) it will shut the grinder off until you reset it by turning it off and then on again. So no worries!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 26, 2009 | Makita 18V LXT Lithium Ion Cordless 3/8...
Bench Grinders Objects
our bench grinder can be used to keep your chisels, knives, gouges and other similar cutting tools sharp, which every woodworker knows is vitally important. Also, bench grinders are handy for sharpening lawn mower blades, drill bits, gardening shears and more. Additionally, a bench grinder can be used for honing and shaping metal objects when modifications are needed. For instance, perhaps you need to modify a door hinge to make it fit in a certain application. No tool is better for this task than a bench grinder.
Aug 27, 2008 | Dewalt 6" 5/8 Hp Heavy Duty Bench Grinder
Lisle 91000 LISLE DRILL GRINDER U.S.A Logo
47 people viewed this question
Top Lisle Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Lisle Saw Expert? Answer questions, earn points and help others
