Question about Sharp MX-2300N Color Copier
No output tray is allowed - Sharp MX-2300N Color Copier
Says paper out or paper jam which nither are happening
  1. Unplug the power cord.
  2. Check to see if the print carriage moves freely from one side of the printer to the other. ...
  3. Remove the print cartridges. ...
  4. Gently move the print cartridge to the far right of the printer.
  5. Remove the paper from the paper In tray, but do not remove the drawer.
  6. Step one: Clear the paper jam from the output tray
    1. Carefully remove any loose paper from the output tray.
    2. Check the rollers in the output tray for jammed paper.
    3. Use a flashlight to see the rollers in the printer.
      Figure : Use a flashlight
    4. Gently remove any jammed paper or bits of torn paper from the output tray rollers. Use both hands to pull out any whole sheets of paper to avoid tearing them.
    5. Remove any bits of paper or torn pieces of paper from the output tray rollers.
    Step two: Clear the jam from the input tray
    1. Press the Power button to turn off the printer.
    2. Disconnect the power cord from the rear of the printer.
    3. Remove all paper from the output tray.
    4. Raise the output tray.
      Figure : Raise the output tray
    5. Grasp any jammed paper in the input tray with both hands, and then pull the paper slowly but firmly toward you to remove it.
      CAUTION: Remove paper from the tray as carefully as possible. If any torn pieces of paper remain inside the printer, more paper jams are likely to occur, and this could damage the print mechanism.
    6. Lower the output tray.
    7. Reconnect the power cord to the rear of the printer.
    8. Press the Power button to turn off the printer.
    If you are not satisfied with this answer then for detail answer please read here > http://www.brotherprintersupportnumber.com
Feb 14, 2016 | Epson WorkForce Pro WP-4540 Color Ink-jet
Error message "push output tray
PowerCycle your Printer. Unplug all cables and push the power button for 5 seconds. Plug the cables back and try again.
-please thumps-up if you find this helpful
Mar 28, 2011 | HP Photosmart C6280 Printer
Machine is saying "output tray full" no faxes
Open the fax. There is a small door that allows access to the fuser for jams. There is a little black tab to the right on the door. Reseat it so it is level and pivots freely. Close up machine should start faxing. This tab is a flag for a photointerupter. Is easily knocked out nof place.
Feb 17, 2011 | Canon LaserClass 2050 Plain Paper Fax
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have a TASCAM CD-450 that the CD Tray will stick closed on quite frequently. I can open the cover (out of warranty) and manually press down on the lens mounting tray and it will open with power. The...
I have the same Tascam cd-450 with the same problem. I replaced the tray motors drive belt and it didn't fix the issue. I measured the voltage output to the motor after pushing the eject button and it was about 1.7 vdc with the tray motor plugged into the main board and about 2.5 vdc with the tray motor unplugged from the main board. I'm beginning to think that the rf-500tb-14415 motor is weak but I don't know the original main board output voltage spec for this motor. I do know that this motor is rated from 1.5 vdc to 9 vdc (3 vdc or 6 vdc nominal)depending on the application and torque requirement.
Sep 27, 2010 | Tascam CD-450 CD Player
Paper Jam HP LaserJet 1300
I hope this will be of Help for the HP LaserJet 1300 Paper Jam Trouble Shooting:
  1. See the product user guide for information about clearing jams from the printer.
  2. Make sure that the paper guides are adjusted properly. Slide the guides against the sides of the stack in the main input tray or the priority input tray to center the page. Make sure that the guides are not adjusted too tightly.
  3. The media input tray might be too full. Remove some of the sheets.
  4. Make sure that the media being used meets specifications. Click here to refer to "Media specifications" for more information .
  5. Make sure that the media being used is not wrinkled, folded, or damaged.
  6. Make sure that the printer is clean. See the product user guide for information about cleaning the printer.
  7. If printing to the straight-through output path, close and open the door again to make sure that the green release levers are closed.
  8. The paper might not have been removed from the main input tray before the tray was refilled. Always remove paper form the main input tray before refilling it.
  9. Output capacity might have been exceeded in the paper output bin. Do not allow more than 125 sheets of 20-lb (75 g/m2) bond weight paper to fill the paper output bin (less for heavier paper).
  10. The pickup roller or printer separation pad might be dirty or damaged. Clean or replace the part. (See the product user guide for information about cleaning and replacing the pickup roller and printer separation pad.)
Apr 03, 2010 | HP LaserJet 1300 Printer
Canon ip4300 printer says paper output tray is closed. wont prin
Its a defective printer you have that cant get out of paper output tray is close or that the paper output tray is not properly placed into the printer.
Try to reseat the output tray and let me know. If it does not work, you may need to send printer to repairs.
Mar 19, 2010 | Canon PIXMA™ iP4300 InkJet Photo Printer
Photo Tray Problem
When nothing worked, I reexamined the trays, and there is a small plastic hook about half an inch long under the left side of the D7460 output tray. The tray below had a small hole. So I clicked the two together, and the printer started printing. Probably like many of you I had elevated the output tray as the printer spews onto the floor. Apparently it needs this connection. So much time lost....
Apr 11, 2009 | HP Photosmart D7460 Printer
HP c7180 message "Push output photo tray all the way down"
I have the HP C7280 and I was able to fix the problem.
HP seems to have 3 trays. The bottom tray is for the paper. The middle one has a small blue tray for the photos and the top tray is where the paper comes out.
Well I lifted the top tray where the paper comes out (it can angle up) and then I clicked OK on the problem. I may have even rebooted, but then I got a new error message which is good. It said to push photo tray (the small blue tray) all the way in which I pulled out and pushed back in. Then I pushed the top tray down so all is flat again. I clicked OK and it re-calibrated with no more error messages! Hope this helps.
Feb 16, 2009 | HP Photosmart C7180 All-In-One InkJet...
Sharp MX-2300N Color Copier Logo
209 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
