Question about HP Pavilion MX70 17" CRT Monitor
My HP MX70 monitor will not come on - HP Pavilion MX70 17" CRT Monitor
How to reset HP monitor p2330h?
It will be slightly different on all monitors, but generally on the menu button on the screen, use the arrow buttons on the screen to navigate, find reset.
Jun 14, 2014 | HP Pavilion MX70 17" CRT Monitor
I have an hp pavilion a720n desktop with an hp pavilion mx70 monitor and windows xp home. There is a problem with the color displayed on the monitor. I see mainly black and white, but blue shows up fine....
First of all you can check the computer by connecting another monitor to it to see if the problem goes away...if so then the problem would be in the monitor. If not , then I would try to change the video grafics card in the computer(assuming you don't have built in video). If you have built in video on the mother board then you will either need to replace the motherboard or disable the onboard video and install a video card
Dec 19, 2010 | HP Pavilion MX70 17" CRT Monitor
Dark Screen
Hi
Not cleaning per sey but a tune up. CRT monitors have alot of things going on inside (high voltage and high heat). This causes parts to change value. You can send this to my company for a tuneup or take it to a local serviceman. The average price price should be +- $100.00.
Thanks
Jul 23, 2009 | HP Pavilion MX70 17" CRT Monitor
My color monitor (hp pavilion mx70) is having graphics problems
Need to download correct graphics drivers and then you will be able to change the options. If you already have up to date drivers then you need to Right Click on desktop and select properties and then click on the Settings Tab and change it from 16 color to Highest (32 bit). Oh, go to manufacturers web site to download drivers.
Jun 30, 2009 | HP Pavilion MX70 17" CRT Monitor
Computer flashes on tv for 1/2 second then goes away using s-video hp vista
if you are loading up on the monitor first then switching over to s video that would be the problem you must load up in s video and the monitor unpluged
Jun 26, 2009 | HP Pavilion MX70 17" CRT Monitor
Monitor won't come on right away
Sounds like the CRT is starting to go bad cause its taking longer and longer for it to boot up. CRT's aren't available now so a new monitor would be the only option.
Apr 09, 2009 | HP Pavilion MX70 17" CRT Monitor
Monitor is missing pins?
If the monitor is working correctly, there is no problem. Not all 15 pins are used, therefore there is usually two missing.
Jan 24, 2009 | HP Pavilion MX70 17" CRT Monitor
Possilbe to reset monitor?
This document pertains to MX50, MX70, MX75 and MX90 CRT monitors.
NOTE: To reset the monitor to factory settings:
  1. Turn off the monitor by pressing the POWER button.
  2. Press and hold the plus (+) button and then
  3. Whith the Plus (+) button pressed, press the power button to turn on the monitor.
  4. Release both buttons.
Jan 01, 2009 | HP Pavilion MX70 17" CRT Monitor
Hp pavillion mx70 stopped showing red, etc
Right-click on any open space on your desktop. Click on properties and the Display properties will come up. Click on settings and make sure the resolution slide is all the way to the right. And Color Quality is set to 32 bits on the small window.
I want to know if my monitor is Vista compatable
Yes, the monitor is Vista compatible. A monitor is just a display device, simply showing you what's coming from the computer's video card. That video circuitry is what would need to be compatible with Vista.
If you are upgrading an older computer by installing Vista, you might need to be concerned about video hardware compatibility. If you are upgrading by simply replacing the computer with a new one, it will already be Vista ready. In either case, the monitor will be fine.
Please take a moment to rate this solution if you've found it what you need, and thanks for asking here!
Dec 27, 2008 | HP Pavilion MX70 17" CRT Monitor
HP Pavilion MX70 17" CRT Monitor Logo
26 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
