51" sanyo flat screen tv act like it is on a timer and wants to shut down. It comes up with a small blue box in low left that says your tv will turn off in 1 min. but if I hit the volume it continues
This problem happens approx every hour. Blue box pops up in lower left of screen and says your tv will shut off in 1 min.
  • nodule3477
    nodule3477 Feb 15, 2014
    Sleep mode is turned off, but thank you for your suggestion
  • nodule3477
    It was suggested I add more info but you got it all. Don't know what to add. When I say I hit vol control and it goes away or rests it's because I am using a sat. remote. If I use the TV remote I can hit any key to reset it. I have gone into every setting and all that have to do with time that I can find are turned off.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Look for "sleep" in menu, set for "0".
Posted on Feb 15, 2014
3 Suggested Answers
mumma_1
  • 903 Answers
SOURCE: Screen color is blue
A blue screen normally comes on in AV or EXT mode, try changing the tv settings back on the controls in TV mode
I hopethis helps
Posted on Nov 20, 2008
SOURCE: my plasma tv has blue or black spots (scattered on
I am facing the same problem with my LG 32 inch plasma TV. There is also a big 2inchX4inch oval black spot at the top centre of the screen. Please suggest any remedy and also the cause. mbkhurshid@gmail.com
Posted on Dec 30, 2010
My Sanyo flat screen TV will not turn on. I go to turn it on and it acts like it will then it cuts off suddenly. Then a green light blinks three times. Any ideas or advice?
3 blinks to Sanyo brand FPTs, denotes a fault with its T'Con board. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Nov 01, 2013 | Sanyo Televison & Video
My Sanyo flat screen acts like t will turn on then cuts off and the green light blinks 3 times. Any ideas what this is?
3 blinks indicates a fault to its main board. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Blinking codes details to many brand TVs are given.
Nov 01, 2013 | Sanyo DP26649 26 in. TV
Tv will not turn on i push power on button and blue lights click on an tv acts like it will come on but then tv shuts off and no picture appears
The blue light merely indicates power is getting to the TV. When you press the power on button, the defective power supply shuts the TV down immediately
Jan 06, 2013 | JVC LT42P789 42 in. LCD TV
I have a Sanyo 42" LCD tv model DP42649. The
The problem i'm having is, when you turn the tv on it has a split screen with the left side shaken off a little bit. if you give it a tap on the left side it will flicker and the whole screen will come on.
Dec 29, 2010 | Sanyo 42 in. LCD TV
I have a Sony kp-51ws500 I had the tubes fixed 3 years ago!! Now the blue screen flashes & shuts down the tv!! Also the red timer lite is blinking at the same time!!! I dont have the timer set!! Please...
The Blue CRT has shorted and shutting the set down. You can verify this by simply sliding the Blue CRT drive board off the neck without unplugging any of its wires, Just let it hang suspended and then try powering up the set. If the set stays on you will know the Blue CRT needs replacement.
Sep 19, 2010 | Sony KP-51WS500 51" Rear Projection...
No pic or sound
First unplug set and let set for several minutes the plug in and turn on. Could be in a serv mode.
Jul 13, 2009 | Hitachi 51F59 51" HDTV Projection...
TV shutdown
As it was a new purchase, I returned it to the store!!!
Feb 08, 2009 | Sanyo DP23625 23 in. LCD Television
Sony kp51hw40 projection tv screen turns blue
The blue CRT needs replacement. You can get a replacement CRT at the following link.
http://servicemanuals.vstore.ca/
Feb 02, 2009 | Sony KP-51HW40 51" Rear Projection...
Flashes blue and then the tv shuts down
The tech is correct about the internal short inside the blue CRT. There is a way to remove that short by applying a small amount of current to burn the short but that might damage the CRT even more. At this point the CRT needs to be replace.
I will post the instructions on how to remove that short but you will need to have a good regulated power supply and limit the amount of current to 1 to 2 amps.
Apr 24, 2008 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
