Question about Suunto Ambit Ambit Black hr Watches
Display frozen showing Suunto
I was trying to update my Ambit 2, but the interned died so the update failed. Now the watch is stuck showing just Suunto on the screen. Whenever i try to connect with my computer it doesn't recognise that the watch it connected. None of the buttons do anything now. Please help!!
SOURCE: suunto t3C. Had it for about 3 months. Went to
I took the battery out and then replaced it and the watch started to function properly again!
Posted on Oct 15, 2009
SOURCE: Suunto Cobra Computer Console, battery replacement
Hey scuba2man, I have the same problem. Did you ever work out what was going on? My console didn't register any depth for first couple of dives (I had to turn it on every 5 mins to check air). Next couple of dives it told me I was between 98 and 103 metres deep (whatever that is in feet). I was at a maximum depth of 22m!!
I will let you know if I find solution. If not then I'll just get a new one!!!
Posted on Jan 05, 2010
  • 2501 Answers
SOURCE: Spare parts??
If you approach a watch repairer, he should have a range of standard pins, one of which should fit your watch.
Posted on Jan 08, 2010
Testimonial: "Thanks for the idea, probably best to try the easiest first! "
  • 2501 Answers
SOURCE: I don't know how to set my suunto watch
You can get a manual from their web site http://www.suunto.com/en-us/Support/Download-Center--User-Guides/ .
Scroll trough the list to find yours and dwonload.
Posted on May 09, 2010
watchmacher
  • 302 Answers
SOURCE: I replaced the battery as
Tough one but here goes. 1 New battery does not necessarily mean good battery 2 Determine the battery is inserted with the correct side up. 3 Is there a reset. Possibly a small hole that you poke a paper clip into. 4 Try holding all the buttons in at the same time for a couple seconds 5 Go see a watchmaker,
good luck
Posted on Mar 11, 2011
Suunto Core watch - my watch is locked in the compass mode. How to I get it unlocked
RTFM
Suunto Core User Guide
ns.suunto.com/Manuals/Core/Userguides/Suunto_Core_Userguide_EN.pdf
This User Guide explains the Suunto Core features, how they work, and how ... nearest watch store to get the needed adjustments correctly done for you.
How to Set Up a New Suunto Core - YouTube
? 6:49
https://www.youtube.com/watch?v=_zywJcNNowU Jun 13, 2015 - Uploaded by Wearable4U
Great tutorial, clear and precise (beats reading the manual) many thanks ;-) ... Hi there. Just bought a suunto core ...
SUUNTO CORE USER MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core user manual online. Suunto Core: User Guide. Core Watch pdf manual download.
SUUNTO CORE QUICK MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Suunto Manuals > Watch > CORE View and Download Suunto Core quick manual online. Suunto Core: Quick Start. Core Watch pdf manual download.
[PDF]Quick Guide - Trekkinn
www.trekkinn.com/images/pdf/especificaciones/eng_suunto_spec_10086.pdf Suunto Core brings together an altimeter, barometer and an electronic compass ... Please refer to the User Guide for detailed information on setting these. Suunto Core watch Google Search
Jun 17, 2017 | Suunto Watches
The ascent reading seems to be very inaccurate and the battery shows low after only a couple rides after installing a new battery. Anyone have a solution for the acent issue?
You need to send the watch into Suunto for service. The watch is obviously having an issue if it will not hold charge with a new battery and the Altimeter is not working correctly.
The Altimeters are Barometric pressure related and occasionally something goes wrong.
My experience is that Suunto is very good about fixing and/ or replacing when this issue arises.
Jan 24, 2011 | Suunto T6c Heart Rate Monitor and Fitness...
I have a suunto pc pod. my suunto t3d watch can connect to the pod but the pod cannot connect to the software installed (training manager lite) since my pc cannot find any drivers to install for the...
I found out that this is because the wrong drivers are installed.
When you install the suunto software the usb drivers are stored under C:\Program Files\Suunto\USBDriver. This contains more than one driverset. See if you can find this.
Then go to Control Panel\Hardware and Sound\Devices and Printers and find your Suunto device. You probably have only one device and will miss Suunto Usb Serial Port.
Now open the deve and change the drivers, via manually select . Select browse and go to C:\Program Files\Suunto\USBDriver. Press Enter. The program will see that there is more than one driver set and offers you a choice.
Previously it has automatically selected the newest one, which unfortunately did not work in my case. Select the oldest set and the program will install the drivers,
Now you will see in Control Panel\Hardware and Sound\Devices that you have 2 devices suunto pc pod and suunto usb serial port. And the program will run and be able to connect to the watch
Good luck
Timco
Oct 02, 2010 | Suunto Pc Pod Wireless Transmitter
May 09, 2010 | Suunto Core Wristop Computer Wrist Watch
Locked screen , need button combo for suunto core
If you enter the following into your search engine, you will see a list of instruction manuals.
www.suunto.com/en/Support/Download-Center--User-Guides/
Download the one for your watch.
Feb 18, 2010 | Suunto Core Wrist Top Computer with...
T6C failed after working OK for 1 day
Try re-pairing the belt pod with the wrist-watch computer. Below text comes from page 37 of the T6c users manual.
If you replace the belt battery or are having troubles with the signal reception, you need to re-pair your belt with your Suunto t6c.
To re-pair the belt:
1. Remove the belt battery
2. Push the (new) battery into the compartment positive side down.
3. In your Suunto t6c, enter the settings menu and enter GENERAL.
4. Scroll to PAIR with [Lap +] and [Light -] and enter with [Mode].
5. Scroll to HR BELT with [Lap +] and [Light -].
6. Activate pairing with [Mode].
7. Put the battery in with the positive side up and close the cover.
Dec 13, 2009 | Suunto T6c Heart Rate Monitor and Fitness...
I'm trying to reset the altimeter and sea pressure but the watch. I've followed the instructions but the watch more often that not reverts back to default settings or does not respond to the calibrations...
http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
If you continue to have problems with your watch, and the instructions in the user manual don't resolve your problem, you may have to return the watch to Suunto.
Your watch must be registered with them, you'll need the serial number of the watch, which is located on the back case. You'll have to get an RMA from Suunto in order to send it back to them.
Here's their warranty info: http://www.suunto.com/en-us/Support/Warranty-information/
Oct 11, 2009 | Suunto Vector Wristwatch
Suunto Ambit Ambit Black hr Watches Logo
1,008 people viewed this question
Top Suunto Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Suunto Measuring Tool and Sensor Expert? Answer questions, earn points and help others
