Question about Samsung RS2630SH Side by Side Refrigerator
Samsung refrigerator rfg297aars ice dispenser flap does not shue
I need to know how to get access to the flap
  • 9 Answers
SOURCE: I need to replace the Ice dispenser lever in ny
Unless the old one actually broke, you can re-install it if it merely fell off. Use a mirror and a flashlight to see the hole on the side toward you so that you can re-insert the lever that goes towards the front, then re-insert the lever into the back hole. If the lever actually broke, the new lever will come with directions on how to install it.
Posted on May 14, 2009
SOURCE: My Samsung refrigerator ice maker
I have the same problem. I just called custormer support and they are shipping me a new ice bucket to resolve the issue (I'm still under warranty). Based on the agent's quick response, it seems that this is not an uncommon problem.
Posted on Nov 12, 2010
  • 146 Answers
SOURCE: I have a samsung rfg297aars refrig. I believe the
you need to check the flapper in the door where the ice comes out,, if you take the ice bin out look down in the hole where the ice comes out,, if it is not sealing good it will let warm air come up the chute and melt the ice,, if it is sealing good,, then you need to check and see if the water fill tube( the one that goes into the icemake) is not froze up or has asomething blocking it
Posted on Jan 19, 2011
richroth
  • 9472 Answers
SOURCE: when dispensing ice rubber flapper on door must
You will need to replace the "fountain assembly" on the unit. Here is a link to the part.
Posted on Mar 28, 2011
jademacdonal
SOURCE: The ice maker on my Samsung RFG297AARS does not ever seem to fill the ice bin. Can this be fixed?
do you have the lever down? i know in my fridge theres a bar off to the side where if you put it down, it makes ice. if its up it will not. im not sure if yours will have that bar though, because its not the same type of fridge but it might.
Posted on Aug 18, 2012
Ice switch dispenses water
If the refrigerator water dispenser is not working correctly the water supply tube in the door may be blocked. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on or may just dispense one item. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
Apr 27, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Aug 18, 2012 | Samsung RFG297AARS (285 cu ft) Bottom...
I have a Kenmore Elite side-by-side refrigerator with ice and water in the door, Model No. 106.58963701. The ice flap is staying open and letting warm air into the freezer and freezing up the ice maker...
Here is a large diagram and a PDF of the parts. Most likely you have a broken door flap spring broken or the hinge. Click Here=> 8201649 Dispenser Door Flap Kit
Click Here=> W10224328 Spring Here s a PDF of all parts related to your models dispenser=>
KENMORE_106.58963701_REFRIGERATOR_SIDE_x_SIDE_Dispenser_Components
Click here for=> 106.58963701 Dispenser Components
If you need instructions on how to take the dispenser apart please let me know. You really will not see the true problem until you have the dispenser disassembled. Hope this has helped answer your questions, Thanks, Sea Breeze
May 04, 2011 | Refrigerators
I have a samsung rfg297aars refrig. I believe the water is leaking from the ice maker into the cube tray and running out and freezing in the cube dispenser and it is freezing the cubes together and...
Jan 19, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
I can see that the flap to the ice chute is not closing but I do not know how to fix it. How do I access this?
pull front plastic very carfully and clean this will usually fix the problem... if flap is in really bad shape replace ////////
Jul 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Apr 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frosty Ice dispenser
you need the flap in the dispenser replaced ,,, you can get a door flap kit to fix it ,,, i know cause i still have one here from when i closed my shop ,,, if flap isnt closing tight the air goes in and it frost up the opening and dispenser / larry
Dec 08, 2008 | Frigidaire FRS3R5EMB Side by Side...
FLAP IN DOOR FOR ICE WILL NOT STAY CLOSE
The ice maker may need to be reset or the ice dispenser lever pulled. You posted on the samsung unit page, so I'm giving you the site to purchase anything from: samsungparts .com. The troubleshooting for pulling the lever is basically to watch the flap to see if it moves when lever is pulled. If it doesn't move, write here for more troubleshooting or call samsung.
Feb 26, 2008 | Samsung RM255LASH Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
24 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
