Question about Ricoh 3320L Laser Fax
Error message clear misfeed
Clear misfeed
5 Suggested Answers
CopierOne
  • 30 Answers
SOURCE: How do I clear misfeed.
In most cases where the machine says there is a jam, and there is no paper in the paper path, it's because the paper never got out of the paper drawer and didn't reach the 1st jam sensor. If you can open the machine and it resets, then chances are the paper feed roller is either slipping or in some cases not turning at all. If you can't clear the jam by turning off the machine, and back on, then you have a bad jam setect sensor or perhaps a small piece of paper lodged on the jam sensor. This will take some additional troubleshooting on your part. Need to know if the jam indicator goes away when you restart the machine. Let me know and I'll try to guide you from that point. Aloha, Bill Monroe
Posted on Sep 17, 2007
  • 1297 Answers
SOURCE: Ricoh Aficio 250, clear misfeeds at w and finisher
Clean the sensors in this parts and try reset the SC codes:Enter in the SP mode press 5-810 (SC code reset)select 1.Then hold down the Photo mode key and the +key at the same time for at least 4 sec.
Posted on Sep 26, 2009
ic0729
  • 212 Answers
SOURCE: MY PRINTER STOPPED PRINTING AND GIVES A ERROR
You need to consult your manual for all the paper paths that you may have missed.
Check all paths and go out and buy paper path cleaner, follow the instructions on the package and completely clean out the paper paths.
This should loosen or remove the stuck paper and get the printer printing again.
Please write back results (good or bad)
Posted on Mar 16, 2010
SOURCE: how to repair!!! misfeed error...when
This can be caused by a sensor (if he is mechanic) displaced the movable mechanism of the same and when it passes the leaf is joined, (if is optical, can be dirty the surface towards where it points the sensor, if he is not this, then the sensor is defective.
It disassembles the parts of exit, and verifies that the sensors are in good state and clean.
Posted on Oct 26, 2012
I have a Panasonic Workio DP3030 showing error code J93 paper misfeed in ADF. I have followed the manual and there is no paper jammed but I can't get rid of the error message.
Generally a paper misfeed is not a paper jam. The rubber pickyp rollers probably need a clean but turning the printer off for 10 minutes and turning back on should eliminate the message.
Nov 03, 2013 | Panasonic Workio DP-3030 Printer
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Sharp AL 800 Copier
Bizhub C35 misfeed error
This video will show some of the most common causes for Bizhub C35 misfeeds
https://www.youtube.com/watch?v=Sbo0gon8EIY
Feb 26, 2012 | Konica Minolta bizhub C351 All-In-One...
IT IS GIVING ME CLEAR MISFEED (A) I DID THAT AND IT STILL TELLS ME TO CLEAR MISFEED, I EVEN TURNED AND UNPLUGGED IT AND CLEARED AND CLEANED AND STILL HAS THAT MESSAGE
you may have a bad switch. sometimes paper hides behind the drawer. remove your paper cassettes and look begind them for a paper
Jan 06, 2011 | Office Equipment & Supplies
I have a Sharp Al-2040cs when I turn it on the misfeed indicator is blinking. I checked it there no misfeed paper or piece of paper inside. How can I fix this problem?
The MISFEED Indicator blinks when a MISFEED has occurred. Remove the misfed paper referring to the the description of MISFEED REMOVAL beginning on page 65 of the pdf Manual at:
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
When the MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
Remember after removing jammed paper, you need to press the clear key to clear the MISFEED error.
If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if this resolves issue.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Sharp AL2040CS Digital Laser Copier,...
I have a Ricoh Aficio AP410N printer and it displays a message that says "remove misfeed internal path" error message. I checked the paper path and there is nothing there. I checked the manual and there...
Did you take out the toner cartridge and paper trays and open all the covers to try to find the misfeed? If there is really nothing there, you can try turning the printer off and back on to see if it clears itself.
Oct 06, 2009 | Ricoh Aficio AP410N Laser Printer
Sep 23, 2009 | Ricoh Aficio 250 Copier
Printer feeds through blank piece of A4 fast, followed by another one, slowly
Service error 6A00 Cancel printing and turn the printer off and then back on.
If this doesn’t clear the error, see the printer manual for more detail.
Jun 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Misfeed and PDF failure
Thewre could be even a small piece of paper stuck. Try looking even closer, and even open a close the access lids to reset the triggered switch. Even a minute pice of paper in the wrong location can cause a sensor to be triggered and until it is reset it will not work.
Mar 31, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh 3320L Laser Fax Logo
66 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
