Question about Samsung RSG257AARS (241 cu ft) Side by Side Refrigerator
How to repair the ice dispenser flap
Flap will not shut
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: when dispensing ice rubber flapper on door must
You will need to replace the "fountain assembly" on the unit. Here is a link to the part.
Posted on Mar 28, 2011
The ice flap on my freezer will not stay open. If I reach up and grab the flap as it's opening, the ice will flow freely. But if I don't grab the flap and keep it open, the ice won't dispense. It's no
Kristen,
Thank you for giving more information. I believe you will need to replace the flapper on the ice dispenser. I based this answer on the following: you mentioned when the door is held open ice comes out. Let me know if this helps. As you may know, there are several different things that could cause this issue, but this is the most common one of them. Here is a how to video on this type of repair:
Jul 21, 2014 | Frigidaire Refrigerators
Ice dispenser flap won't close
Good Afternoon W. Miller,
I understand the ice dispenser flap will not close on your Frigidaire refrigerator, model# FRS26H7. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and see if the flap has closed. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire FRS26H7 26 Cu. Ft. Side By Side...
I have a Kenmore Elite side-by-side refrigerator with ice and water in the door, Model No. 106.58963701. The ice flap is staying open and letting warm air into the freezer and freezing up the ice maker...
Here is a large diagram and a PDF of the parts. Most likely you have a broken door flap spring broken or the hinge. Click Here=> 8201649 Dispenser Door Flap Kit
Click Here=> W10224328 Spring Here s a PDF of all parts related to your models dispenser=>
KENMORE_106.58963701_REFRIGERATOR_SIDE_x_SIDE_Dispenser_Components
Click here for=> 106.58963701 Dispenser Components
If you need instructions on how to take the dispenser apart please let me know. You really will not see the true problem until you have the dispenser disassembled. Hope this has helped answer your questions, Thanks, Sea Breeze
May 04, 2011 | Refrigerators
Ice will not dispence thru door.
Without knowing the brand and model # I can offer the most common solution.
On most "pass the ice through the door" models there is a flapper door where the ice dispenses. The spring which holds this door closed when you are not dispensing ice becomes weak allowing the flap to stay open jsut a bit. This open space will create an ice dam in teh dispenser thus not allowing the ice to dispense. The repair is generally made by replacing the flap assembly.
All the best.
Nov 21, 2010 | Refrigerators
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker flap don't shut all the time
The flap may be getting stuck on the ice guide which is mounted on the arm you push in th dispense the ice . ( pt # 2180224 ) . Try pushing the arm in and look to see if the flap is catching on the clear plastic piece .
Aug 24, 2009 | Whirlpool Freezers
Flap for ice dispenser does not work
Most likely the flap has frozen pull the Ice maker out and operate the ice dispenser push the dispenser flap and see if it it is free, if not pour warm water on it to free the flap.
Jun 21, 2009 | GE Refrigerators
Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Apr 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
LG LFX29560 Ice Dispenser
You may need a service call as the ice dispenser flap is operated by a solenoid which is controlled by a small pwb board which is located by the dispenser.
Sgt 48
Nov 30, 2007 | LG LRFC25750 Refrigerator French Door
Ice Dispenser - in door
Yes that repair is quite common and not too difficult you need a Maytag Fountain door Kit dont have the part# hear but can be researched available at all appliance part retailers........comes with the solonoid, new flapper door and outher redesigned pieces also an instrunction sheet A solved rating is great motivation to continue giving priceless advise........
Oct 03, 2007 | Jenn-Air JSD2488G Side by Side...
Samsung RSG257AARS (241 cu ft) Side by Side Refrigerator Logo
21 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
