Question about Bell & Howell Photography
I have an old sears pro am slide projector it doesn't seem to want to advance to next slide
  • 33 Answers
SOURCE: slides advance continusly
I can solve this i think but am pretty busy right now. It's also cheap and usually easy. If you can carefully open the shell (body) , with it unplugged of course,note where all the thin wires belong for when you put it together again. Assuming you have the projector open and on its back, look near the top, centre roughly. You'll see a white, thick gear that gets driven by a long worm gear/pulley that is driven by the motor belt. Above the thick gear is a silver-grey metal catch or "trigger" and resting on - or near it- will be a (usually) copper coloured thin metal "finger.
in normal operation this finger catches on the grey metal trigger which flips into position and catches the clutch built into that thick gear. When you activate the slide advance, the solenoid, for a moment, pulls the finger off the trigger which moves the triger which allows the clutch to engage and turn the thick gear, driving the mechanism. What's happening is that over time the light grease has thickened and the trigger is not engaging properly.
In some cases, all you need to do is just activate that slide advance a couple of dozen times, or let it keep advancing a few dozen times. You might try this before takign it apart. It selldom is enough but might be. usually though you'll need to look carefully to the pivot point of that grey metal trigger. If you have any contact cleaner for electronics (degreaser) get a little on and behind the rivent that holds that trigger and let's it pivot. With your finger, getnly rock the trigger back and forth. Repeat a few times if necessary as that cleaner evaporates quickly. If you don't have such cleaner, you can use a bit of WD-40 or alcohol can sometimes do the trick. Rubbing, not whiskey! Whatever you use to clean out the old, dried lubricant there, be careful not to let it get into other areas of the mechanism! Especially the WD 40 whihc has both grease cutter and oil. Oil in the wong places will give you bigger problems.
Eventually the trigger should move very easily and return to position quickly when you release it. Now you want to put a drop or two only on that pivot point, of the lightest oil you can find. Most easily accessed is light sewing machine oil.
You may decide to plug in the projector now -remove the lamp first. it is dnagerous at this point so be careful, or before you plug it in, put the shell cover back on. If you cover it hough, you can't see what's happening. In any case, run it, advance the slides via the remote preferably, a few times and unplug it.Hopefully it's stopped advancing continuously by now.
Take a look at the point where the "finger" engages the "trigger". You want to be careful not to bend the finger or things'll get out of whack.But IF you can (unplugged again!) spare just a tiny bit of grease from that thick gear, put just a bit on the trigger where the finger rests. If you can locate a clear coloured teflon added lubricant called Super-lube (also sold under at elast one other brand name I can't recall), that is the stuff Kodak used.
Reassemble carefully and try 'er out. If you run into any problems, give me a shout at bytebackkw@yahoo.ca . Put Kodak in the heaidng so you don't get spammed out.
Posted on Feb 19, 2009
  • 412 Answers
SOURCE: my slide projector carousel does not advance
Does the projector run in reverse?? If so, then what you are facing is a timing adjustment.
If it does not cycle in either direction, then there is a high probability that the solenoid "link" is broken. The "link" connects the cycle solenoid plunger to the slide change mechanism.
The good news: There are still parts available (www.micro-tools.com). The less-than-good-news: both fixes are difficult and best handled by a factory-trained repair dealer.
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: I just purchased an older Kodak slide projector
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
  • 412 Answers
SOURCE: Automatic slide changer is stuck in
The problem is continuous cycle (like you don't know that already...). It indicates that an adjustment to the cycle contact is necessary. To open the projector, first unplug it and remove the lamp module from the rear of the projector. Turn the projector upside down. Remove the 6 - T15 TORX screws from the bottom (5 around the perimeter and one in the channel next to the cord wrap). CAREFULLY pull the bottom off (the power wires connect the bottom cover & top together!!). Once you have it open, leave the projector upside down, put on your safety glasses & plug the projector into the wall. At the center of the projector you should see a hub rotating about every second or so. Above it you should see a "J"-shaped wire. See the attached illustration.
You will have to, in repeated steps, unplug the projector, bend the "J"-shaped wire GENTLY & SLIGHTLY, plug the projector back in and cycle it a few times. Check for the position of the "J"-shaped wire to the pad, and GENTLY repeat until you achieve the position shown in the illustration.
  • 412 Answers
SOURCE: Slides won't advance or reverse
The AF-2 is suffering from old age! The problem you are experiencing is "continuous cycle", and is caused by the cycle contact either being bent or worn to the point it can't stop the cycle camstack at the end of a slide change. If you are familiar with projector repair, I can give you specific instructions. Otherwise, I suggest you locate an authorized repair dealer. Even though the projector is old, all the necessary parts are available from: www.micro-tools.com
Good Luck !! Jim
Posted on Dec 26, 2011
Kodak carousel AV900 projector
This projector is at least 50 years old. Parts will be a real adventure to find at this point. More than likely the cause of the failure is the Cycle Solenoid, the Link that attaches the plunger of the cycle solenoid to the slide change mechanism, or both. I am unsure if the parts you can buy from www.micro-tools.com
will fit in your projector, as I do not have any repair documents that old..... Sorry I can't be of more help!! Jim
Mar 22, 2012 | Kodak Office Equipment & Supplies
Good Luck !! Jim
Dec 15, 2011 | Kodak Office Equipment & Supplies
Why doesn't the slides advance?
I can only guess, but it is most likely caused by a worn or mis-adjusted cycle contact. I have attached an illustration to show you the proper orientation of the cycle contact. Good Luck !! Jim7390f9e7-725d-4085-9769-5537112e57b1.jpg
Aug 10, 2011 | Kodak Ektagraphic III-E-Plus 35mm 140...
Slides will not advance.buttons do not seem to work
1. Does the SELECT button work? If so, hold it & remove the tray (if one is present). Skip to step 3.
2. If the SELECT button doesn't work, remove the slide tray (if one is on the projector) using the emergency tray release in the center hub of the projector. 3. 3. Turn the projector on & try to cycle a few times in reverse. This is how you clear a slide change mechanism jam in the projector.
4. If that didn't work, then either you have a broken cycle circuit wire (usually an orange wire within the projector) or the release wire is trapped under the cycle pad. Refer to the following diagram for the correct "at-rest" position of these 2 contacts. (If you don't feel comfortable doing this, then contact a factory-trained repair dealer).
Good Luck !!
Feb 15, 2011 | Kodak Carousel 4400 Slide Projector
The reverse forward feature doesn't work
To advance the slides forward just tap the advance button. To revers it hold the advance button down. If that doesn't do it it will need service.
Nov 12, 2010 | Braun Novamat 330 Slide Projector
I have a 760 H Carousal projector which will nor advane the tray to the next sidle. Souation?
If your projector neither advances or reverses the slide tray, then you most likely have a broken "link". This "link" connects the slide change solenoid to the slide change mechanism. Over time this part becomes brittle & cracks, rendering slide change non-functional. This repair needs to be made by an authorized repair dealer.
Sep 05, 2010 | Kodak Carousel 4400 Slide Projector
I just purchased an older Kodak slide projector with a carousel on top. Everything works fine but the carousel won't advance. When you click the next button, the plastic arm that should advance the...
Nov 14, 2009 | Kodak Carousel 5600 Slide Projector
Will not advance although nothing is stuck in the machine.
Sounds like what your projector needs is a cycle contact adjustment.
Remove the slide tray & lamp module. Unplug the projector. Turn the projector upside down to remove the bottom cover (6 - T-15 TORX screws). Pry the bottom cover off from the handle side (Be careful!! The power cord is physically secured to the bottom cover!). I have attached an illustration for reference. Near the center of the projector you will find a contact as shown in the illustration. That contact needs to be in the position shown on the pad. You will have to slightly bend the "J"-shaped wire carefully(!!). Then plug the projector in, turn it on & cycle it a few times. The 2 contacts should look like the illustration when at rest. If they don't look like that, unplug the projector, "tweak" the contact wire a little bit more, plug the projector in & try again. This adjustment can take a factory-trained repair tech several bends to get it right (without breaking off the wire!!). Repeat until you are successful! jauburn_8.jpg
Apr 19, 2009 | Kodak Carousel 4400 Slide Projector
Slide/tray advancement
http://www.fixya.com/support/t1564949-slides_advance_continusly
This link talks specifically about a Kodak slide projector. However the faulty mechanism in your Telex works in a similar way if you feel up to taking it apart. If you do, mark every screw and piece you remove, in a diagram. Though your symptom is sporadic advancing and the other link is continuous advancing, it's essentially the same cause, as sticking trigger mechanism in the clutch release.
Jan 27, 2009 | Telex 3280 Caramate 80 Slides Rotary...
Tiffen Pro-Corder System II
ALL I KNOW POLICE USE TO USE THIS DEVICE
IT REDUCES NOISE FROM THE BACKGROUND AND RECORDS
BUT I DON'T KNOW WHAT ELSE IT DOS
Jul 02, 2008 | Audio Players & Recorders
Photography Logo
49 people viewed this question
Top Bell & Howell Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Bell & Howell Photography Expert? Answer questions, earn points and help others
