So I have an HP mini and when I boot up it says
So I have an HP mini and when I boot up it says "Failed to initialize HAL!" After this I can't connect to wifi or use any USB ports or access system configuration
    Scholar:
  • 56 Answers
Best I could find is on this site, as you didn't specify what operating system you are trying to use: http://www.reviversoft.com/blog/2012/12/hal-initialization-failed/info. This usually only happens if you are using Linux or Windows 8.
Posted on Feb 12, 2014
pcrepairh
  • 43 Answers
SOURCE: Cant connect usb mini adapter/ hid data stopped working error
Hi, My Name is Henry. I am one of the technicians here.
What windows are you using?
Please do not forget to rate my solutions to you.
Regards
Henry
http://www.clickpcrepair.com
Posted on Mar 19, 2009
SOURCE: usb ports quit working on my hp netbook 1151nr mini
Hey, i have the same problem except my usb ports work with otherdevices plugged in. Just not when I plug in a printer to the usb
Posted on Mar 19, 2010
  • 163 Answers
SOURCE: accidentally removed wireless connection of my hp
You will need to go on your New internet connection wizard and set up a new wireless connection
Posted on Apr 12, 2010
  • 47 Answers
SOURCE: HP MINI WILL NOT BOOT FORM USB PORT
change your boot order in the bios
Posted on Apr 30, 2010
  • 62 Answers
SOURCE: I have hP mini 1000 that won't boot up
Did it came across blue screen of death or BOOTMGR is missing/ NTLDR is missing ?
Use Last Known Good Configuration
You can also try to boot the operating system with the LastKnown Good Configuration feature.
This feature will allow you to undo anychanges that caused problems in the CurrentControlSet
registry key, whichdefines hardware and driver settings. The Last Known Good Configuration
featurereplaces the contents of the CurrentControlSet registry key with a backup copythat was
last used to successfully start up the operating system. To use the Last Known Good
Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you
see the message Please select the operating system to start or hear the single beep, press
[F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration
item from the menu and press [Enter].Keep in mind that you get only one shot with the Last
KnownGood Configuration feature. In other words, if it fails to revive your WindowsXP on the
first attempt, the backup copy is also corrupt.
If the method above can't help you, you can learn how to recover data when windows won't start
Posted on Dec 27, 2012
Dvd not working to initiate repair disk- no boot on hard drive
If the internal DVD drive worked previously, try changing the boot order in your BIOS. Depending on your computer, you will need to press Esc, Del, F1, F2 or F10 to access the BIOS. Save the new boot order when you exit the BIOS. If your DVD isn't listed, replace the SATA cable with a new one and make sure that the power cable is fully seated. You can try connecting the data cable to another SATA port on the motherboard. It's possible that the DVD drive failed as well; you can try a different optical driver.
All of the SATA ports should be able to support a boot device unless there is a specific controller/bandwidth sharing issue involved.
If you are using a USB DVD drive, you need to make sure that your motherboard supports booting from USB.
Please add a comment with your computer make/model or motherboard. I can provide more assistance with changing the boot order or determining the limitations of your SATA ports on your system.
Dec 16, 2012 | Computers & Internet
HAL.DLL is missing or corrupted, xp doesn't boot
If you can enter safe mode, run the command prompt as administrator. Enter the command: sfc /scan now
Then hit enter. It should replace missing files or repair corrupt files. It is a lengthy scanning of every file on the computer. Chkdsk would NOT replace a missing file.
.If you can not boot XP, change the boot setup to boot a CD/DVD at startup by entering the BIOS before windows pops up with a loading screen (rather than the hard drive) and have it boot a CD/DVD or USB that you have burned/installed Reimage upon. That is a commercial product. Check it out at MajorGeeks or its own website. Alternatively, take a look at method 3 on this page: http://www.wikihow.com/Make-a-USB-Bootable
May 29, 2017 | Microsoft Windows XP Professional...
I plug it into usb port, i downloaded driver from manufactors website, yet nothing happens. The mouse will not work.
No need for a mouse to have a driver, friend. Try to insert into other usb port...wait till the computer initialize and configure your mini mouse...
If the problem still exist...restart your pc to initialize the mouse...Done!
If still nothing happen...besides you try all the usb port in your pc. I think you need to buy new good mouse...Done
Sep 23, 2011 | Belkin MiniScroller Mouse
Sir, i have hp mini 210-1000 laptop without cd/dvd. while installing windows xp i have deleted the partitions & tried to install xp from usb but failed. please help me to install windows xp .
Check the BIOS to see if you can make the USB as the first boot device, if you can then you will be able to install XP from the USB flash memory stick.
The reason why your XP installation failed is because in most older laptops, the USB port does not work until Windows XP has been installed.
Your hard disk may have an Windows XP install partition that you can access to reinstall Windows, provided you have not deleted this partition.
Jul 10, 2011 | HP Mini 1000 XP Notebook
How to install internet connection on my HP mother board
Hi.
If your motherboard have USB ports.available gadget USB LAN and USB WIFI gadget.
Just install driver software and search internet provider for internet access.
See sample picture USB LAN and USB wireless type gadget.
Jun 15, 2011 | HP Compaq Motherboard
I want to reset the settings on my hp mini to its factory settings.
Hello try to download the files on another computer running a Windows operating system and restore your
device, follow these steps:
1. From your computer, go to http://www.hpmini.com and download the
HP MIE Restore Image Creator utility and the HP Mini MIE recovery image.
2. Insert a USB flash drive into a USB port on the computer.
3. Launch the HP MIE Restore Image Creator utility from the Start menu.
4. Click the Browse button and select the HP Mini MIE recovery image.
– or –
Select HP Netbook Recovery Image to download the latest HP Mini MIE recovery image from
http://www.hpmini.com.
5. Click Start.
6. When the process is complete, remove the USB flash drive.
7. Insert the USB flash drive into a USB port on your HP MINI.
8. Change the boot order by turning on or restarting the device, and then pressing f9 while the “F9 =
Change Boot Device Order” message is displayed in the lower-left corner of the screen.
9. Use the arrow keys to select the USB flash drive, and then press enter.
10. Press enter again to begin restoring the device.
11. Follow the on-screen instructions to install the operating system and programs.
12. After the operating system and programs are installed, remove the USB flash drive(the device will automatically restart)
13. Restore your personal files and you are done
Good luck
Jan 20, 2010 | HP Computers & Internet
USB ports not working, slow computer
The error you are getting is the USB port driver. I suggest disconnecting ALL of the items you have connected to ALL of the USB ports and rebooting. If the computer reboots normally, go back and install ONE and ONLY one USB device. Restart your machine. If it boots OK, shut down, remove that device and connect another one, restart again. Do this for EACH of the USB devices until you find one that causes the computer to boot slowly and/or generates the error message. That one is the culprit and needs to be repaired before reattaching to your system.
If, however, after removing all of the USB devices initially and rebooting, you still get the error message, then you have a USB driver problem. You will need to remove the USB driver and reinstall from a known good location (like HP's website) to fix the driver problem.
Jan 07, 2010 | HP Pavilion a1210n (ED895AA) PC Desktop
My computer freezes when connecting WIFI adapter
Does this happen if you try connecting it into all USB ports? Try another USB port. Do you know if your USB ports are 2.0?
Mar 30, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Hal.dll file missing, can't boot from xp disc as error states hard drive cannot be detected
Issue : Blue screen - Missing HAL.DLL error message
Solution :
1) Insert your windows XP CD into your CD/DVD drive.
2) Restart your computer.
3) Press the F12 key to access the one time boot menu.
4) Select Onboard or USB CD-ROM Drive.
Press any key when prompted.
5) The Windows XP Setup will launch.
6) Press R to choose the Repair option and enter recovery console on the Welcome to Setup Page.
7) bootcfg /rebuild
8) Enter Y and press enter
9) Type Microsoft Windows XP Home Edition or Microsoft Windows XP Professional Edition.
10) Type /fastdetect
11) Type Exit
Nov 15, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
