Question about JVC FS-2000 Shelf System
Replace the fs-2000 square belts - JVC FS-2000 Shelf System
Remote control for fs-2000
Try www.jvc.com and contact customer support, also! check www.ebay.com type make and model and scroll through the list.
Aug 13, 2012 | JVC Audio Players & Recorders
Need to replace serpentine belt on 2000 dodge caravan,,6 cyl,,air,,,, email cntrywv1@ayhoo.com
OK, do you have a specific question? You'll need to jack up the front right tire and remove it. Pull the wheel well cover off to expose the belt. Use a vice-grip in the tensioner pulley (look for a 1.2 in square on the end of the pulley) to remove tension. Install as the sticker under the hood shows.
Jan 24, 2010 | 2000 Dodge Grand Caravan
Won't power on
I had the same problem. I just took it into a certified repair place. cost me 50 bucks to learn what part needed to be replaced and that it isn't available any more. Recyle it.
Nov 07, 2009 | JVC FS-2000 Shelf System
Where can I find a subwoofer replacement.....for the JVC FS 8000 or FS 2000?
Contact JVC directly. They will refer you to their parts rep for your area. If the parts are available, you may find the parts to be rather expensive in relation to buying a new one.
Jerry G.
Aug 06, 2009 | JVC FS-8000 Shelf System
How do you keep the tension pulley down to take the belt off a 2000...
It will have either a nut on it for a wrench, or a square hole for a 3/8 or 1/2 inch ratchet to fit into. They also make a belt tool kit that makes this easier. With a tool hooked to it, you pull on it to overcome the spring, and hold it. It doesn't latch, so you may need help removing and replacing the belt.
Jul 10, 2009 | 2000 Dodge Grand Caravan
2000 Lincoln How do you adjust the tension on the motor serpintine belt ?
You don't...I mean you can't adjust the serpentine belt because there is automatic self tensioner which loaded by a very high compression spring. Now, there should be a square hole on the tensioner which is a 1/2 inch. You simply put a half inch breaker bar in the square hole to gain leverage in order to change your belt. Hopefully this helps
Jul 07, 2009 | 2000 Lincoln Continental
Waterpump belt
you have a serpentine belt, which is one belt drives all, so the routing of this belt is very specific also it matters whether or not you have a/c. Locate your belt routing chart under the hood before beginning. There is a tensioner pulley mounted on a spring arm, the spring arm should have a square drive hole in it, either 3/8" or 1/2" drive size you will need a ratchet of the proper size to insert into this square hole. Using the ratchet move the tension arm (away from belt) to loosen the belt and remove, route and install the new belt and move tensioner the same way place the belt over it and release. Hope this helps, let me know
May 16, 2009 | 2000 Ford Contour
Replacing serpentine belt, does the arm thats attached to the tension have to be removed?
To release the tension on the adjuster requires a wrench on the wheel bolt or there is a 3/8 square hole near the wheel that can take a 3/8 rachet.
Apr 26, 2009 | 2000 Ford Contour
REPLACING BELT ON MY 2000 TAURUS.HAVE BELT OVER ALL PULLYS,BUT LAST ONE ,DON'T KNOW HOW TO PULL BACK PULLY AND GET BELT ON AT THE SAME TIME.
locate the tensioner... you need a "breaker" bar with a 3/8 inch socket head... a rachet would do with a long enough handle. there is a square hole in the tensioner... you need to release pressure on the tensioner long enough to get the belt on.
Mar 06, 2009 | 2000 Ford Taurus
JVC FS-2000 Shelf System Logo
96 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
