Question about Kyocera Fs-1300d Printer
Blinking data light, wont print - Kyocera Fs-1300d Printer
Blinking green light
Try disconnecting the computer from the printer and shutting it down by removing the power cord and then also shut down the computer for a minute or so and then reboot it and check in "Printers" and see if it has anything waiting to be printed and if so clear out the queue. Flashing green light indicates that the printer is receiving data from the computer and/or printing so you shut it all down and cold reboot to clear out the computer confusion in both the computer and the printer.
Sep 19, 2014 | Brother HL Office Equipment & Supplies
Printing data light is blinking
Check if the machine print is put to paused, go to status and make sure you it is on resume not paused.
Dec 12, 2013 | Copystar Sharp MX-3100N Copier : Sharp...
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
I have Windows 7, I have a 5p (was just given) and the test page will not print. The green light at the bottom is continuously blinking. Suggestions?
bottom light blinking means it is receiving data try to unhook cable power cycle and try test print with data cable unhooked if you wait should error out if does not print
Jul 29, 2010 | HP LaserJet 5p Printer
Yellow light keeps on blinking
one of the cartridges is dead and must be changed. buy new one and the problem will be solved.
Aug 02, 2009 | HP DeskJet 640c InkJet Printer
Not printing
Please open the manual feed and try to print using manual feed if you are able to print fine using manual feed that check pickup roller of Tray 2.
First of try to print using Manual feed and let me know if it is printing from Manual feed or not.
Jun 30, 2009 | HP LaserJet P2015 Printer
Zebra S500 no print
You can find the manual in www.zebra.com, and try reset, pressing FEED and PAUSE keys and turn on printer, release keys until move labels.
Mar 12, 2009 | Zebra Stripe S600 Thermal Label Printer
Print Data light blinking
-try converting the PDF file
-the driver may need to be reloaded
if you print from Word does it go trough? if yes then that particular file is the problem
Jul 29, 2008 | Toshiba e-Studio 350 Copier
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Apr 21, 2008 | Brother HL 1440 Laser Printer
Kyocera Fs-1300d  Printer Logo
83 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
